WIFI-IoT上收到消息后反转对应LED 状态的相关代码,参阅
一、相关的软件和python库安装
ubuntu20.04中搭建MQTT Broker的指令如下
sudo apt-get install mosquitto
sudo apt-get install mosquitto-clients
sudo apt-get install mosquitto-dev
复制代码
Ubuntu下用python搭建web会用到的库安装指令如下
pip3 install paho.mqtt
pip3 install web.py
复制代码
如果是在windows下mqtt的包安装要换成如下
pip install web.py
pip install paho-mqtt
复制代码
二、用html写个简单的页面"key.html"如下
Wifi-loT测试页面
Soon-Wifi-loT
tion="/RedLED" method="POST">
复制代码
页面比较简洁只有标题和三个按键三、Python相关代码如下
import web
import paho.mqtt.client
import time
HOSTNAME ="xxxxxx"#请填入你的Broker地址/可以是你局域网ubuntu虚拟机IP,或者云服务器地址
MQTTPORT = 1883#默认1883 具体看你Broker配置
USERNAME ="xxxxxx" #请填入用户名
PASSWD="xxxxxx"#请填入用密码
HTML_PAGE = "key.html"
TOPICE = "ledstatus"
mqtt = paho.mqtt.client
urls = (
'/RedLED', 'RedLED',
'/YellowLED', 'YellowLED',
'/GreenLED', 'GreenLED',
'/(.*)', 'Wifi_lOT_home'
app = web.application(urls, globals())
client_id = time.strftime('%Y%m%d%H%M%S',time.localtime(time.time()))
client = mqtt.Client(client_id) # ClientId不能重复,所以使用当前时间
# publish 消息
def on_publish(topic, payload, qos):
client.username_pw_set(USERNAME, PASSWD) # 必须设置,否则会返回「Connected with result code 4」
client.connect(HOSTNAME, MQTTPORT, 60)
client.publish(topic, payload, qos)
class Wifi_lOT_home:
def GET(self, name):
file = open(HTML_PAGE, "rb+")
return file.read()
def POST(self):
print ("test soon")
class RedLED:
def POST(self):
print ("RedLED POST")
on_publish(TOPICE, "RedLED".encode(),0)
return file.read()
class YellowLED:
def POST(self):
print ("YellowLED POST")
on_publish(TOPICE,"YellowLED".encode(),0)
return file.read()
class GreenLED:
def POST(self):
print ("GreenLED POST")
on_publish(TOPICE,"GreenLED".encode(),0)
return file.read()
if __name__ == "__main__":
app.run()
复制代码
四、运行指令和效果运行指令python3 -u xxxxxx.py 端口 ,如 python3 -u keyEvent.py 8080然后在浏览器输入http://localhost:8080/ 或者http://(ubuntu IP/server IP):8080/ 就能看到以下页面
附相关代码下载
