【HarmonyOS HiSpark Wi-Fi IoT 套件试用连载】LED灯闪烁
本文来源电子发烧友社区,作者:跋扈洋, 帖子地址:https://bbs.elecfans.com/jishu_2006813_1_1.html
LED灯闪烁(开发板体验视频,详见作者原文章链接)
修改源码目录结构先在./applications/sample/wifi-iot/app路径下新建一个目录(或一套目录结构),用于存放业务源码文件。
本例程:在app下新增业务led,其中led.c为业务代码,BUILD.gn为编译脚本,具体规划目录结构如下:
  1. .
  2. └── applications
  3. └── sample
  4. └── wifi-iot
  5. └── app
  6. │── led
  7. │ │── led.c
  8. │ └── BUILD.gn
  9. └── BUILD.gn
  10.
复制代码
               HiSpark
业务代码。
新建./applications/sample/wifi-iot/app/led下的led.c文件,在led.c中新建业务入口函数led,并实现业务逻辑。并在代码最下方,使用HarmonyOS启动恢复模块接口SYS_RUN()启动业务。(SYS_RUN定义在ohos_init.h文件中)
  • BUILD.gn为编译脚本
  • led.c为业务逻辑代码所在文件
led.c
  1. [indent]
  2.
  3. #include
  4. #include
  5. #include "ohos_init.h"
  6. #include "cmsis_os2.h"
  7. #include "wifiiot_gpio.h"
  8. #include "wifiiot_gpio_ex.h"
  9. #define LED_ON_TIME_US 2000000
  10. #define LED_OFF_TIME_US 1000000
  11.
  12. static void Led(void)
  13. {
  14.
  15.     GpioInit();
  16.     IoSetFunc(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_IO_FUNC_GPIO_9_GPIO);
  17.     GpioSetDir(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_GPIO_DIR_OUT);
  18.     while (1) {
  19.         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 0);
  20.         printf("[DEMO] LED on.n");
  21.
  22.         usleep(LED_ON_TIME_US);
  23.
  24.         GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 1);
  25.
  26.         printf("[DEMO] LED off.n");
  27.
  28.         usleep(LED_OFF_TIME_US);
  29.     }
  30. }
  31. SYS_RUN(Led);
  32.
  33.
  34.
  35. [/indent]
复制代码
BUILD.gn(app/BUILD.gn)
static_library("bahuyang") {
    sources = [
        "led.c"
    include_dirs = [
        "//utils/native/lite/include",
        "//kernel/liteos_m/components/cmsis/2.0",
        "//base/iot_hardware/interfaces/kits/wifiiot_lite",
  • “bahuyang”:是生成静态库名称,可随意更改
  • “led.c”:代码文件
BUILD.gn()
# Copyright (c) 2020 Huawei Device Co., Ltd.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
import("//build/lite/config/component/lite_component.gni")
lite_component("app") {
    features = [
        #"startup",
        "led:bahuyang"
  • 将"startup"注释,运行我们自己的文件
  • “led”:工程目录
  • bahuyang:静态库文件
编译烧录编译
我在以前的文章里,详细讲解了怎样编译。大家可以回头看看。
我们进入终端面板下,在对应工程目录下,输入python build.py wifiiot
进行编译,当出现编译成功时,就代表编译完成。
HiSpark
烧录利用HiBurn工具进行烧录,我在以前的文章里,详细讲过。
HiSpark
选定文件后,点击connect,按下开发板复位按钮,进行烧录。
烧录完成后,再次按下复位按键。
观察现象
如视频中所示,LED灯进行闪烁。
