在Systemverilog中,union可以被声明为tagged unions。
union tagged {
int a;
byte b;
bit [15:0] c;
} data;
tagged union包含一个隐式成员,该成员存储tag,也就是标记,它表示这个union最终存储的到底是哪一个成员。
tagged union 是一种类型检查(type-checked)union.
这意味着你不能写入union中的一个成员,而读取另外一个成员。因为在这期间,tagged union会进行读写类型检查
data = tagged a 32'hffff_ffff;
如果从不同的union成员中读取值,仿真器则会报错:
module tagged_union_example;
logic [31:0] x;
typedef union tagged {
int a;
byte b;
bit [15:0] c;
} data;
data d1;
initial begin
d1 = tagged a 32'hffff_ffff; //write to 'a'
//read from 'b'. Since 'a' was written last, cannot access
//'b'. - Error
x = d1.b;
$display("x = %h",x);
end
endmodule
在上面的例子中,我们创建了一个tagged union " data ",并声明" d1 "为" data "类型。然后我们写入成员a:
然后我们读取值“d1.b”。因为读写的成员类型不同,所以会打印错误信息:
Error-[TU-INVMEMUSG] Invalid member usage of a tagged union. testbench.sv, 15 Member of a tagged union referred is not valid since a different member is in use. The expected tag is 'a', but tag 'b' is used. Please check which member of the tagged union is in use. V C S S i m u l a t i o n R e p o r t
审核编辑:刘清
