Radio-Tech’s ecosense is an intelligent temperature
and humidity sensor. Available for internal, external
or surface (temperature only), the ecosense allows
you to monitor temperature and humidity indoor or
out as well as providing a solution for weather proof
data collection.
The sensor chirps at regular intervals, typically every
five minutes (unless a different specification is
requested) and sends the data to the RT:Wi5 data
hub. This information is then sent directly to the
server.
