【赛昉科技昉·星光RISC-V单板计算机试用体验】用starfive做个直播流媒体服务器试试看
本文来源电子发烧友社区,作者:jf_06445065, 帖子地址:https://bbs.elecfans.com/jishu_2293191_1_1.html
经过评估,官方提供的fedora不适合做音视频编解码处理,但是可以尝试做一下server。所以可以做一下直播服务器。
首先安装下nginx-rtmp服务,方法如下:
wget https://nginx.org/download/nginx-1.18.0.tar.gz
tar zxvf nginx-1.18.0.tar.gz
git clone https://github.com/arut/nginx-rtmp-module.git
cd nginx-1.18.0
./configure --add-module=/home/riscv/nginx-rtmp-module
make && make install
然后配置nginx.conf,配置支持rtmp server,配置如下:
[riscv@fedora-starfive nginx]$ cat /usr/local/nginx/conf/nginx.conf
worker_processes  1;
events {
    worker_connections  1024;
rtmp {
    server {
        listen 1935;
        chunk_size 4000;
        application mytv {
            live on;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server {
        listen       80;
        server_name  localhost;
        location / {
        root   html;
        index  index.html index.htm;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
        root   html;
然后启动nginx即可 sudo /usr/local/nginx/sbin/nginx
不过需要放开1935的tcp端口,因为rtmp的server配置的是1935
然后在本地用ffmpeg推个流试一下ffmpeg -re -f lavfi -i testsrc2=1280x720:r=25 -vcodec libx264 -g 25 -b:v 500k -f flv rtmp://172.17.10.64:1935/mytv/hello
赛昉科技
推流完事后播放看一下效果:
赛昉科技
