【泰凌微TLSR9系列开发套件试用体验】TLSR9 蓝牙BLE参数设置
本文来源电子发烧友社区,作者:性感的· , 帖子地址:https://bbs.elecfans.com/jishu_2286218_1_1.html
泰凌微的代码结构和Nrf52832的芯片代码差异性还是比较大的,很多代码define go to 你会发现是库,看不到底层代码了。经过一番学习后,总结几点共大家借鉴吧。对初学蓝牙的朋友还是有些帮助的,如果大神,就请直接划走吧。
BLE的设置大多都在app_att.c和app_att.h里面。
比如更改名字 在这个数组里更改 static const u8 my_devName[] = {'e','S','a','m','p','l','e'};
后面有函数会调用my_devName,这个数组
更改最大最小广播时间等参数my_periConnParameters 。同理,相比Nrf52832的代码来说,这并不是宏定义出来,大多数参数都是用结构体,或者数组来设置。Search,注意不要用Ctrl+F,使用Keil的朋友习惯了这个,Ctrl+F是只能在文件搜索的,无法在工程内搜索。
    基本这些蓝牙设置的参数,更改UUID UI,服务的添加,属性更改的东西都可以找到
泰凌微
快速go to define 的快捷键是Ctrl+鼠标左键。
下面来讲一下app的设置
  1. /********************************************************************************************************
  2. * @file        app_config.h
  3. *
  4. * @brief        This is the header file for BLE SDK
  5. *
  6. * @author        BLE GROUP
  7. * @date        2020.06
  8. *
  9. * [url=home.php?mod=space&uid=1930556]@par[/url]     Copyright (c) 2020, Telink Semiconductor (Shanghai) Co., Ltd. ("TELINK")
  10. *          All rights reserved.
  11. *
  12. *          Redistribution and use in source and binary forms, with or without
  13. *          modification, are permitted provided that the following conditions are met:
  14. *
  15. *              1. Redistributions of source code must retain the above copyright
  16. *              notice, this list of conditions and the following disclaimer.
  17. *
  18. *              2. Unless for usage inside a TELINK integrated circuit, redistributions
  19. *              in binary form must reproduce the above copyright notice, this list of
  20. *              conditions and the following disclaimer in the documentation and/or other
  21. *              materials provided with the distribution.
  22. *
  23. *              3. Neither the name of TELINK, nor the names of its contributors may be
  24. *              used to endorse or promote products derived from this software without
  25. *              specific prior written permission.
  26. *
  27. *              4. This software, with or without modification, must only be used with a
  28. *              TELINK integrated circuit. All other usages are subject to written permission
  29. *              from TELINK and different commercial license may apply.
  30. *
  31. *              5. Licensee shall be solely responsible for any claim to the extent arising out of or
  32. *              relating to such deletion(s), modification(s) or alteration(s).
  33. *
  34. *          THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
  35. *          ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
  36. *          WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  37. *          DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDER BE LIABLE FOR ANY
  38. *          DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
  39. *          (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  40. *          LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
  41. *          ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
  42. *          (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
  43. *          SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  44. *
  45. *******************************************************************************************************/
  46. #pragma once
  47.
  48.
  49.
  50. /////////////////// FEATURE SELECT /////////////////////////////////
  51. /**
  52. *  [url=home.php?mod=space&uid=2666770]@Brief[/url]  Feature select in bLE Sample project
  53. */
  54. #define BLE_APP_PM_ENABLE                                        1
  55. #define PM_DEEPSLEEP_RETENTION_ENABLE                1
  56. #define TEST_CONN_CURRENT_ENABLE            0 //test connection current, disable UI to have a pure power
  57. #define APP_SECURITY_ENABLE                              1
  58. #define APP_DIRECT_ADV_ENABLE                                1
  59. #define BLE_OTA_SERVER_ENABLE                                1
  60. #define BATT_CHECK_ENABLE                                        0
  61.
  62.
  63.
  64. /**
  65. *  @brief  flash firmware check
  66. */
  67. #define FLASH_FIRMWARE_CHECK_ENABLE                        0
  68.
  69.
  70. /**
  71. *  @brief  firmware signature check
  72. */
  73. #define FIRMWARES_SIGNATURE_ENABLE                        0
  74.
  75.
  76.
  77. /**
  78. *  @brief  DEBUG  Configuration
  79. */
  80. #define UART_PRINT_DEBUG_ENABLE                          0
  81. #define DEBUG_GPIO_ENABLE                                        0
  82. #define JTAG_DEBUG_DISABLE                                        0
  83.
  84.
  85.
  86. /**
  87. *  @brief  UI Configuration
  88. */
  89. #define UI_LED_ENABLE                                           1
  90. #define UI_BUTTON_ENABLE                                        0
  91. #if (TEST_CONN_CURRENT_ENABLE) //test current, disable keyboard
  92.                 #define        UI_KEYBOARD_ENABLE                        0
  93. #else
  94.                 #define        UI_KEYBOARD_ENABLE                        1
  95. #endif
  96.
  97.
  98.
  99. //SAMPLE SELECT EVK BOARD
  100. #if (UI_KEYBOARD_ENABLE)   // if test pure power, kyeScan GPIO setting all disabled
  101.                 //---------------  KeyMatrix PB2/PB3/PB4/PB5 -----------------------------
  102.                 #define        MATRIX_ROW_PULL                                        PM_PIN_PULLDOWN_100K
  103.                 #define        MATRIX_COL_PULL                                        PM_PIN_PULLUP_10K
  104.
  105.                         #define        KB_LINE_HIGH_VALID                                0   //dirve pin output 0 when keyscan, scanpin read 0 is valid
  106.
  107.
  108.
  109.                         #define                        CR_VOL_UP                                0xf0  ////
  110.                         #define                        CR_VOL_DN                                0xf1
  111.
  112.
  113.                         /**
  114.                          *  @brief  Normal keyboard map
  115.                          */
  116.                         #define                KB_MAP_NORMAL        {        {CR_VOL_DN,                VK_1},
  117.        {CR_VOL_UP,                VK_2}, }
  118.
  119.
  120.
  121.                         //////////////////// KEY CONFIG (EVK board) ///////////////////////////
  122.                         #define  KB_DRIVE_PINS  {GPIO_PC2, GPIO_PC0}
  123.                         #define  KB_SCAN_PINS   {GPIO_PC3, GPIO_PC1}
  124.
  125.                         //drive pin as gpio
  126.                         #define        PC2_FUNC                                AS_GPIO
  127.                         #define        PC0_FUNC                                AS_GPIO
  128.
  129.                         //drive pin need 100K pulldown
  130.                         #define        PULL_WAKEUP_SRC_PC2                MATRIX_ROW_PULL
  131.                         #define        PULL_WAKEUP_SRC_PC0                MATRIX_ROW_PULL
  132.
  133.                         //drive pin open input to read gpio wakeup level
  134.                         #define PC2_INPUT_ENABLE                1
  135.                         #define PC0_INPUT_ENABLE                1
  136.
  137.                         //scan pin as gpio
  138.                         #define        PC3_FUNC                                AS_GPIO
  139.                         #define        PC1_FUNC                                AS_GPIO
  140.
  141.                         //scan  pin need 10K pullup
  142.                         #define        PULL_WAKEUP_SRC_PC3                MATRIX_COL_PULL
  143.                         #define        PULL_WAKEUP_SRC_PC1                MATRIX_COL_PULL
  144.
  145.                 //scan pin open input to read gpio level
  146.                 #define PC3_INPUT_ENABLE                1
  147.                 #define PC1_INPUT_ENABLE                1
  148.
  149.         #if (UI_LED_ENABLE)
  150.                 /**
  151.                  *  @brief  Definition gpio for led
  152.                  */
  153.                 #define        GPIO_LED_WHITE                        GPIO_PB6
  154.                 #define        GPIO_LED_GREEN                        GPIO_PB5
  155.                 #define        GPIO_LED_BLUE                        GPIO_PB4
  156.                 #define GPIO_LED_RED                        GPIO_PB7
  157.                 #define LED_ON_LEVAL                         1                 //gpio output high voltage to turn on led
  158.
  159.                 #define PB7_FUNC                                AS_GPIO
  160.                 #define PB6_FUNC                                AS_GPIO
  161.                 #define PB5_FUNC                                AS_GPIO
  162.                 #define PB4_FUNC                                AS_GPIO
  163.
  164.                 #define        PB7_OUTPUT_ENABLE                1
  165.                 #define        PB6_OUTPUT_ENABLE                1
  166.                 #define PB5_OUTPUT_ENABLE                1
  167.                 #define        PB4_OUTPUT_ENABLE                1
  168.         #endif
  169.
  170.
  171. #elif (UI_BUTTON_ENABLE)
  172.                 //SAMPLE SELECT DONGLE BOARD
  173.                 #undef  PM_DEEPSLEEP_RETENTION_ENABLE
  174.                 #define PM_DEEPSLEEP_RETENTION_ENABLE                                0    //dongle demo no need deepSleepRetention
  175.                 //---------------  Button -------------------------------
  176.                 /**
  177.                  *  @brief  Definition gpio for button detection
  178.                  */
  179.                 #define        SW1_GPIO                                GPIO_PB2
  180.                 #define        SW2_GPIO                                GPIO_PB3
  181.                 #define PB2_FUNC                                AS_GPIO
  182.                 #define PB3_FUNC                                AS_GPIO
  183.                 #define PB2_INPUT_ENABLE                1
  184.                 #define PB3_INPUT_ENABLE                1
  185.                 #define PULL_WAKEUP_SRC_PB2     PM_PIN_PULLUP_10K
  186.                 #define PULL_WAKEUP_SRC_PB3     PM_PIN_PULLUP_10K
  187.
  188.         #if (UI_LED_ENABLE)
  189.                 /**
  190.                  *  @brief  Definition gpio for led
  191.                  */
  192.                 //---------------  LED ----------------------------------
  193.                 #define        GPIO_LED_RED                        GPIO_PB4
  194.                 #define        GPIO_LED_WHITE                        GPIO_PB1
  195.                 #define        GPIO_LED_GREEN                        GPIO_PB0
  196.                 #define        GPIO_LED_BLUE                        GPIO_PB7
  197.                 #define        GPIO_LED_YELLOW                        GPIO_PB5
  198.
  199.                 #define PB4_FUNC                                AS_GPIO
  200.                 #define PB1_FUNC                                AS_GPIO
  201.                 #define PB0_FUNC                                AS_GPIO
  202.                 #define PB7_FUNC                                AS_GPIO
  203.                 #define PB5_FUNC                                AS_GPIO
  204.
  205.                 #define        PB4_OUTPUT_ENABLE                1
  206.                 #define        PB1_OUTPUT_ENABLE                1
  207.                 #define PB0_OUTPUT_ENABLE                1
  208.                 #define        PB7_OUTPUT_ENABLE                1
  209.                 #define        PB5_OUTPUT_ENABLE                1
  210.
  211.                         #define LED_ON_LEVAL                         1                 //gpio output high voltage to turn on led
  212.         #endif
  213. #endif
  214.
  215.
  216.
  217.
  218. /////////////////// DEEP SAVE FLG //////////////////////////////////
  219. #define USED_DEEP_ANA_REG                   DEEP_ANA_REG1 //u8,can save 8 bit info when deep
  220. #define        LOW_BATT_FLG                                            BIT(0) //if 1: low battery
  221. #define CONN_DEEP_FLG                            BIT(1) //if 1: conn deep, 0: adv deep
  222. #define IR_MODE_DEEP_FLG                                         BIT(2) //if 1: IR mode, 0: BLE mode
  223. #define LOW_BATT_SUSPEND_FLG                                BIT(3) //if 1 : low battery, < 1.8v
  224.
  225.
  226.
  227. #if (BATT_CHECK_ENABLE)
  228. #define VBAT_CHANNEL_EN                                                0
  229.
  230. #if VBAT_CHANNEL_EN
  231.         /**                The battery voltage sample range is 1.8~3.5V    **/
  232. #else
  233.         /**         if the battery voltage > 3.6V, should take some external voltage divider        **/
  234.         #define GPIO_BAT_DETECT                                GPIO_PB0
  235.         #define PB0_FUNC                                                AS_GPIO
  236.         #define PB0_INPUT_ENABLE                                0
  237.         #define PB0_OUTPUT_ENABLE                                0
  238.         #define PB0_DATA_OUT                                        0
  239.         #define ADC_INPUT_PIN_CHN                                ADC_GPIO_PB0
  240. #endif
  241. #endif
  242.
  243.
  244.
  245.
  246. #if (JTAG_DEBUG_DISABLE)//2-wire jtag mode
  247.
  248. #define PE6_FUNC                        AS_GPIO
  249. #define PE7_FUNC                        AS_GPIO
  250.
  251. #define PE6_INPUT_ENABLE        0
  252. #define PE7_INPUT_ENABLE        0
  253.
  254. #endif
  255.
  256.
  257.
  258. /////////////////////////////////////// PRINT DEBUG INFO ///////////////////////////////////////
  259. #if (UART_PRINT_DEBUG_ENABLE)
  260.         //the baud rate should not bigger than 115200 when MCU clock is 16M)
  261.         //the baud rate should not bigger than 1000000 when MCU clock is 24M)
  262.         #define PRINT_BAUD_RATE                             115200
  263.         #define DEBUG_INFO_TX_PIN                           GPIO_PC6
  264.         #define PULL_WAKEUP_SRC_PC6                         PM_PIN_PULLUP_10K
  265.         #define PC6_OUTPUT_ENABLE                                 1
  266.         #define PC6_DATA_OUT                             1 //must
  267. #endif
  268.
  269.
  270. /**
  271. *  @brief  Definition for gpio debug
  272. */
  273. #if(DEBUG_GPIO_ENABLE)
  274.
  275.
  276.         #define GPIO_CHN0                                                        GPIO_PE1
  277.         #define GPIO_CHN1                                                        GPIO_PE2
  278.         #define GPIO_CHN2                                                        GPIO_PA0
  279.     #define GPIO_CHN3                                                        GPIO_PA4
  280.         #define GPIO_CHN4                                                        GPIO_PA3
  281.         #define GPIO_CHN5                                                        GPIO_PB0
  282.         #define GPIO_CHN6                                                        GPIO_PB2
  283.         #define GPIO_CHN7                                                        GPIO_PE0
  284.
  285.         #define GPIO_CHN8                                                        GPIO_PA2
  286.         #define GPIO_CHN9                                                        GPIO_PA1
  287.         #define GPIO_CHN10                                                        GPIO_PB1
  288.         #define GPIO_CHN11                                                        GPIO_PB3
  289.
  290.
  291.         #define GPIO_CHN12                                                        GPIO_PC7
  292.         #define GPIO_CHN13                                                        GPIO_PC6
  293.         #define GPIO_CHN14                                                        GPIO_PC5
  294.         #define GPIO_CHN15                                                        GPIO_PC4
  295.
  296.
  297.         #define PE1_OUTPUT_ENABLE                                        1
  298.         #define PE2_OUTPUT_ENABLE                                        1
  299.         #define PA0_OUTPUT_ENABLE                                        1
  300.         #define PA4_OUTPUT_ENABLE                                        1
  301.         #define PA3_OUTPUT_ENABLE                                        1
  302.         #define PB0_OUTPUT_ENABLE                                        1
  303.         #define PB2_OUTPUT_ENABLE                                        1
  304.         #define PE0_OUTPUT_ENABLE                                        1
  305.
  306.         #define PA2_OUTPUT_ENABLE                                        1
  307.         #define PA1_OUTPUT_ENABLE                                        1
  308.         #define PB1_OUTPUT_ENABLE                                        1
  309.         #define PB3_OUTPUT_ENABLE                                        1
  310.         #define PC7_OUTPUT_ENABLE                                        1
  311.         #define PC6_OUTPUT_ENABLE                                        1
  312.         #define PC5_OUTPUT_ENABLE                                        1
  313.         #define PC4_OUTPUT_ENABLE                                        1
  314.
  315.
  316.         #define DBG_CHN0_LOW                gpio_write(GPIO_CHN0, 0)
  317.         #define DBG_CHN0_HIGH                gpio_write(GPIO_CHN0, 1)
  318.         #define DBG_CHN0_TOGGLE                gpio_toggle(GPIO_CHN0)
  319.         #define DBG_CHN1_LOW                gpio_write(GPIO_CHN1, 0)
  320.         #define DBG_CHN1_HIGH                gpio_write(GPIO_CHN1, 1)
  321.         #define DBG_CHN1_TOGGLE                gpio_toggle(GPIO_CHN1)
  322.         #define DBG_CHN2_LOW                gpio_write(GPIO_CHN2, 0)
  323.         #define DBG_CHN2_HIGH                gpio_write(GPIO_CHN2, 1)
  324.         #define DBG_CHN2_TOGGLE                gpio_toggle(GPIO_CHN2)
  325.         #define DBG_CHN3_LOW                gpio_write(GPIO_CHN3, 0)
  326.         #define DBG_CHN3_HIGH                gpio_write(GPIO_CHN3, 1)
  327.         #define DBG_CHN3_TOGGLE                gpio_toggle(GPIO_CHN3)
  328.         #define DBG_CHN4_LOW                gpio_write(GPIO_CHN4, 0)
  329.         #define DBG_CHN4_HIGH                gpio_write(GPIO_CHN4, 1)
  330.         #define DBG_CHN4_TOGGLE                gpio_toggle(GPIO_CHN4)
  331.         #define DBG_CHN5_LOW                gpio_write(GPIO_CHN5, 0)
  332.         #define DBG_CHN5_HIGH                gpio_write(GPIO_CHN5, 1)
  333.         #define DBG_CHN5_TOGGLE                gpio_toggle(GPIO_CHN5)
  334.         #define DBG_CHN6_LOW                gpio_write(GPIO_CHN6, 0)
  335.         #define DBG_CHN6_HIGH                gpio_write(GPIO_CHN6, 1)
  336.         #define DBG_CHN6_TOGGLE                gpio_toggle(GPIO_CHN6)
  337.         #define DBG_CHN7_LOW                gpio_write(GPIO_CHN7, 0)
  338.         #define DBG_CHN7_HIGH                gpio_write(GPIO_CHN7, 1)
  339.         #define DBG_CHN7_TOGGLE                gpio_toggle(GPIO_CHN7)
  340.         #define DBG_CHN8_LOW                gpio_write(GPIO_CHN8, 0)
  341.         #define DBG_CHN8_HIGH                gpio_write(GPIO_CHN8, 1)
  342.         #define DBG_CHN8_TOGGLE                gpio_toggle(GPIO_CHN8)
  343.         #define DBG_CHN9_LOW                gpio_write(GPIO_CHN9, 0)
  344.         #define DBG_CHN9_HIGH                gpio_write(GPIO_CHN9, 1)
  345.         #define DBG_CHN9_TOGGLE                gpio_toggle(GPIO_CHN9)
  346.         #define DBG_CHN10_LOW                gpio_write(GPIO_CHN10, 0)
  347.         #define DBG_CHN10_HIGH                gpio_write(GPIO_CHN10, 1)
  348.         #define DBG_CHN10_TOGGLE        gpio_toggle(GPIO_CHN10)
  349.         #define DBG_CHN11_LOW                gpio_write(GPIO_CHN11, 0)
  350.         #define DBG_CHN11_HIGH                gpio_write(GPIO_CHN11, 1)
  351.         #define DBG_CHN11_TOGGLE        gpio_toggle(GPIO_CHN11)
  352.         #define DBG_CHN12_LOW                gpio_write(GPIO_CHN12, 0)
  353.         #define DBG_CHN12_HIGH                gpio_write(GPIO_CHN12, 1)
  354.         #define DBG_CHN12_TOGGLE        gpio_toggle(GPIO_CHN12)
  355.         #define DBG_CHN13_LOW                gpio_write(GPIO_CHN13, 0)
  356.         #define DBG_CHN13_HIGH                gpio_write(GPIO_CHN13, 1)
  357.         #define DBG_CHN13_TOGGLE        gpio_toggle(GPIO_CHN13)
  358.         #define DBG_CHN14_LOW                gpio_write(GPIO_CHN14, 0)
  359.         #define DBG_CHN14_HIGH                gpio_write(GPIO_CHN14, 1)
  360.         #define DBG_CHN14_TOGGLE        gpio_toggle(GPIO_CHN14)
  361.         #define DBG_CHN15_LOW                gpio_write(GPIO_CHN15, 0)
  362.         #define DBG_CHN15_HIGH                gpio_write(GPIO_CHN15, 1)
  363.         #define DBG_CHN15_TOGGLE        gpio_toggle(GPIO_CHN15)
  364. #else
  365.         #define DBG_CHN0_LOW
  366.         #define DBG_CHN0_HIGH
  367.         #define DBG_CHN0_TOGGLE
  368.         #define DBG_CHN1_LOW
  369.         #define DBG_CHN1_HIGH
  370.         #define DBG_CHN1_TOGGLE
  371.         #define DBG_CHN2_LOW
  372.         #define DBG_CHN2_HIGH
  373.         #define DBG_CHN2_TOGGLE
  374.         #define DBG_CHN3_LOW
  375.         #define DBG_CHN3_HIGH
  376.         #define DBG_CHN3_TOGGLE
  377.         #define DBG_CHN4_LOW
  378.         #define DBG_CHN4_HIGH
  379.         #define DBG_CHN4_TOGGLE
  380.         #define DBG_CHN5_LOW
  381.         #define DBG_CHN5_HIGH
  382.         #define DBG_CHN5_TOGGLE
  383.         #define DBG_CHN6_LOW
  384.         #define DBG_CHN6_HIGH
  385.         #define DBG_CHN6_TOGGLE
  386.         #define DBG_CHN7_LOW
  387.         #define DBG_CHN7_HIGH
  388.         #define DBG_CHN7_TOGGLE
  389.         #define DBG_CHN8_LOW
  390.         #define DBG_CHN8_HIGH
  391.         #define DBG_CHN8_TOGGLE
  392.         #define DBG_CHN9_LOW
  393.         #define DBG_CHN9_HIGH
  394.         #define DBG_CHN9_TOGGLE
  395.         #define DBG_CHN10_LOW
  396.         #define DBG_CHN10_HIGH
  397.         #define DBG_CHN10_TOGGLE
  398.         #define DBG_CHN11_LOW
  399.         #define DBG_CHN11_HIGH
  400.         #define DBG_CHN11_TOGGLE
  401.         #define DBG_CHN12_LOW
  402.         #define DBG_CHN12_HIGH
  403.         #define DBG_CHN12_TOGGLE
  404.         #define DBG_CHN13_LOW
  405.         #define DBG_CHN13_HIGH
  406.         #define DBG_CHN13_TOGGLE
  407.         #define DBG_CHN14_LOW
  408.         #define DBG_CHN14_HIGH
  409.         #define DBG_CHN14_TOGGLE
  410.         #define DBG_CHN15_LOW
  411.         #define DBG_CHN15_HIGH
  412.         #define DBG_CHN15_TOGGLE
  413. #endif  //end of DEBUG_GPIO_ENABLE
  414.
  415.
  416.
  417. #include "vendor/common/default_config.h"
  418.
复制代码
基础的官网的demo基本在这里,可以通过宏定义在屏蔽或开启编译,具体的事件是如何调度的,通过仿真也是非常容易理解了。到了这里,基本使用这款芯片完成底层驱动都没问题的。希望Telink的名气越来越大,以后更多产品都用到Telink的芯片吧。为国产芯片点赞。
