点击蓝字 ╳ 关注我们
巴延兴
深圳开鸿数字产业发展有限公司
资深OS框架开发工程师
一、简介
二、目录
├── frameworks #框架代码
│ ├── js
│ │ ├── player
│ ├── native
│ │ ├── player #native实现
│ └── videodisplaymanager #显示管理
│ ├── include
│ └── src
├── interfaces
│ ├── inner_api #内部接口
│ │ └── native
│ └── kits #外部JS接口
├── sa_profile #服务配置文件
└── services
├── engine #engine代码
│ └── gstreamer
├── etc #服务配置文件
├── include #头文件
└── services
├── sa_media #media服务
│ ├── client #media客户端
│ ├── ipc #media ipc调用
│ └── server #media服务端
├── factory #engine工厂
└── player #player服务
├── client #player客户端
├── ipc #player ipc调用
└── server #player服务端三、播放的总体流程
四、Native接口使用
void PlayerDemo::RunCase(const string &path)
player_ = OHOS::CreatePlayer();
if (player_ == nullptr) {
cout << "player_ is null" << endl;
return;
RegisterTable();
std::shared_ptr cb = std::make_shared();
cb->SetBufferingOut(SelectBufferingOut());
int32_t ret = player_->SetPlayerCallback(cb);
if (ret != 0) {
cout << "SetPlayerCallback fail" << endl;
if (SelectSource(path) != 0) {
cout << "SetSource fail" << endl;
return;
sptr producerSurface = nullptr;
producerSurface = GetVideoSurface();
if (producerSurface != nullptr) {
ret = player_->SetVideoSurface(producerSurface);
if (ret != 0) {
cout << "SetVideoSurface fail" << endl;
SetVideoScaleType();
if (SelectRendererMode() != 0) {
cout << "set renderer info fail" << endl;
ret = player_->PrepareAsync();
if (ret != 0) {
cout << "PrepareAsync fail" << endl;
return;
cout << "Enter your step:" << endl;
DoNext();
}void PlayerDemo::DoNext()
std::string cmd;
while (std::cin, cmd)) {
auto iter = playerTable_.find(cmd);
if (iter != playerTable_.end()) {
auto func = iter->second;
if (func() != 0) {
cout << "Operation error" << endl;
if (cmd.find("stop") != std::npos && dataSrc_ != nullptr) {
dataSrc_->Reset();
continue;
} else if (cmd.find("quit") != std::npos || cmd == "q") {
break;
} else {
DoCmd(cmd);
continue;
void PlayerDemo::RegisterTable()
(void)playerTable_.emplace("prepare", std::bind(&Player::Prepare, player_));
(void)playerTable_.emplace("prepareasync", std::bind(&Player::PrepareAsync, player_));
(void)playerTable_.emplace("", std::bind(&Player::Play, player_)); // ENTER -> play
(void)playerTable_.emplace("play", std::bind(&Player::Play, player_));
(void)playerTable_.emplace("pause", std::bind(&Player::Pause, player_));
(void)playerTable_.emplace("stop", std::bind(&Player::Stop, player_));
(void)playerTable_.emplace("reset", std::bind(&Player::Reset, player_));
(void)playerTable_.emplace("release", std::bind(&Player::Release, player_));
(void)playerTable_.emplace("isplaying", std::bind(&PlayerDemo::GetPlaying, this));
(void)playerTable_.emplace("isloop", std::bind(&PlayerDemo::GetLooping, this));
(void)playerTable_.emplace("speed", std::bind(&PlayerDemo::GetPlaybackSpeed, this));
}五、调用流程
左右滑动查看更多
int32_t PlayerImpl::Init()
playerService_ = MediaServiceFactory::GetInstance().CreatePlayerService();
CHECK_AND_RETURN_RET_LOG(playerService_ != nullptr, MSERR_UNKNOWN, "failed to create player service");
return MSERR_OK;
}std::shared_ptr MediaClient::CreatePlayerService()
std::lock_guard lock(mutex_);
if (!IsAlived()) {
MEDIA_LOGE("media service does not exist.");
return nullptr;
sptr object = mediaProxy_->GetSubSystemAbility(
IStandardMediaService::MEDIA_PLAYER, listenerStub_->AsObject());
CHECK_AND_RETURN_RET_LOG(object != nullptr, nullptr, "player proxy object is nullptr.");
sptr playerProxy = iface_cast(object);
CHECK_AND_RETURN_RET_LOG(playerProxy != nullptr, nullptr, "player proxy is nullptr.");
std::shared_ptr player = PlayerClient::Create(playerProxy);
CHECK_AND_RETURN_RET_LOG(player != nullptr, nullptr, "failed to create player client.");
playerClientList_.push_back(player);
return player;
}int32_t PlayerImpl::Play()
CHECK_AND_RETURN_RET_LOG(playerService_ != nullptr, MSERR_INVALID_OPERATION, "player service does not exist..");
MEDIA_LOGW("KPI-TRACE: PlayerImpl Play in");
return playerService_->Play();
int32_t PlayerImpl::Prepare()
MEDIA_LOGW("KPI-TRACE: PlayerImpl Prepare in");
return playerService_->Prepare();
int32_t PlayerImpl::PrepareAsync()
MEDIA_LOGW("KPI-TRACE: PlayerImpl PrepareAsync in");
return playerService_->PrepareAsync();
}int32_t PlayerClient::Play()
CHECK_AND_RETURN_RET_LOG(playerProxy_ != nullptr, MSERR_NO_MEMORY, "player service does not exist..");
return playerProxy_->Play();
}int32_t PlayerServiceProxy::Play()
MessageParcel data;
MessageParcel reply;
MessageOption option;
if (!data.WriteInterfaceToken(PlayerServiceProxy::GetDescriptor())) {
MEDIA_LOGE("Failed to write descriptor");
return MSERR_UNKNOWN;
int error = Remote()->SendRequest(PLAY, data, reply, option);
if (error != MSERR_OK) {
MEDIA_LOGE("Play failed, error: %{public}d", error);
return error;
return reply.ReadInt32();
}int32_t PlayerServiceStub::Play()
MediaTrace Trace("binder::Play");
CHECK_AND_RETURN_RET_LOG(playerServer_ != nullptr, MSERR_NO_MEMORY, "player server is nullptr");
return playerServer_->Play();
}std::shared_ptr PlayerServer::Create()
std::shared_ptr server = std::make_shared();
CHECK_AND_RETURN_RET_LOG(server != nullptr, nullptr, "failed to new PlayerServer");
(void)server->Init();
return server;
}int32_t PlayerServer::Play()
if (lastOpStatus_ == PLAYER_PREPARED || lastOpStatus_ == PLAYER_PLAYBACK_COMPLETE ||
lastOpStatus_ == PLAYER_PAUSED) {
return OnPlay();
} else {
MEDIA_LOGE("Can not Play, currentState is %{public}s", GetStatusDescription(lastOpStatus_).c_str());
return MSERR_INVALID_OPERATION;
int32_t PlayerServer::OnPlay()
auto playingTask = std::make_shared>([this]() {
MediaTrace::TraceBegin("PlayerServer::Play", FAKE_POINTER(this));
auto currState = std::static_pointer_cast(GetCurrState());
(void)currState->Play();
int ret = taskMgr_.LaunchTask(playingTask, PlayerServerTaskType::STATE_CHANGE);
CHECK_AND_RETURN_RET_LOG(ret == MSERR_OK, ret, "Play failed");
lastOpStatus_ = PLAYER_STARTED;
return MSERR_OK;
return server_.HandlePlay();
}int32_t PlayerServer::HandlePlay()
int32_t ret = playerEngine_->Play();
CHECK_AND_RETURN_RET_LOG(ret == MSERR_OK, MSERR_INVALID_OPERATION, "Engine Play Failed!");
return MSERR_OK;
}六、总结
(1)提供给应用调用的Native接口,这个实际上通过OHOS::CreatePlayer()调用返回PlayerImpl实例。
(2)PlayerClient,这部分通过IPC的proxy调用,向远程服务发起调用请求。
(3)PlayerServer,这部分是播放服务的实现端,提供给Client端调用。
(4)Gstreamer,这部分是提供给PlayerServer调用,真正实现媒体播放的功能。
原文标题:OpenHarmony 3.2 Beta多媒体系列——音视频播放框架
文章出处:【微信公众号:OpenAtom OpenHarmony】欢迎添加关注!文章转载请注明出处。
