香蕉派 BPI-R2 Pro开源路由器开发板采用瑞芯微(Rockchip) RK3568芯片方案设计
开发板
Banana Pi BPI-R2 Pro 开源路由器采用Rockchip RK3568芯片方案设计, 板载2GB LPDDR4内存和16GB eMMC存储,支持2个USB 3.0接口,5千兆网口。M.2 Key-e和mini PCIe接口,2 mipi DSI接口(可通过软件切换LVDS), 1个CSI摄像头接口,1个HDMI输出.支持Android,Linux,OpenWRT系统
BPI-R2 Pro 尺寸接口与
Banana Pi BPI-R2
 ,可以使用 BPI-R2 外壳.
BPI-R2 Pro 硬件接口示意图:
开发板
硬件规格:
Banana Pi R2 Pro
CPURockchip RK3568 Quad-core ARM Cortex-A55 CPU 2GHz
GPUMali-G52 1-Core-2EE OpenGL ES3.2 Vu1kn 1.1 OpenCL 2.0
Memory2G DDR3 SDRAM (option 4G)
StorageOnboard 16GB eMMC Flash, Micro SD-Card slot, SATA 2.0 Port,SPI flash
Network5 x 10/100/1000 Mbit/s Ethernet
Display(s)1 HDMI port, 2 DSI interface(1 DSI can change to LVDS by software)
Camera1 CSI camera interfact
Video decoder(s)H.265 HEVC/MVC Main10 Profile yuv420@L5.1 up to 4096x2304@60fps,H.264 AVC/MVC Main10 Profile yuv400/yuv420/yuv422/@L5.1 up to 4096x2304@60fps
Video encoder(s)H.264/AVC BP/MP/HP@level4.2,up to 1920x1080@100fps, H.265/HEVC MP@level4.1, up to 1920x1080@100fps (4096x4096@10fps with TILE)
Audio Output(s)HDMI & I2S & Speaker & Headphone
USB portUSB 3.0 PORT (x2), micro USB OTG (x1)
mini PCIE1 mini pcie interface & 1 M.2 key-e interface
RemoteIR Receiver (x1)
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). Some of I/O Pin can be used for specific functions as UART, I2C, SPI or PWM
SwitchesReset button, Power button, U-boot button
LEDPower Status and 8P8C
Power Source12 volt @2A via DC Power and/or Micro USB (OTG)
Size & Weight148 mm × 100.5mm 100g
OSOpenWRT, Linux and others OS
Online wiki development documents:https://wiki.banana-pi.org/Banana_Pi_BPI-R2_Pro
