3 激发态S1优化
荧光是冷光现象,一般指发生在自旋单重态之间的辐射过程。根据Kasha规则,它是最低激发态到基态的发射,一般为S1态到S0态。为了模拟荧光过程,还需要对激发态S1做结构优化和频率计算,得到log文件和fchk文件,为后续MOMAP的计算做准备。泛函和基组分别为M062x和Def2SVP,gjf文件如下:
%nprocshared=32
%mem=6GB
%chk=s1opt.chk
#P opt freq M062x/Def2SVP TD(nstates=3,root=1)
Title Card Required
0 1
C 1.565649 -4.134284 -0.176953
C 1.643599 -2.628388 -0.152751
C 2.886000 -2.003080 -0.112539
C 3.020859 -0.613479 -0.088550
N 4.325420 -0.044576 -0.036499
C 5.278240 -0.466495 -0.995386
C 4.884618 -0.626003 -2.332720
C 5.799622 -1.064339 -3.285338
C 7.121820 -1.335486 -2.928150
C 7.515238 -1.172730 -1.598991
C 6.603320 -0.752040 -0.633991
C 4.698175 0.744156 1.076980
C 4.091832 0.542012 2.325047
C 4.427797 1.352319 3.406784
C 5.379893 2.362883 3.271786
C 5.988191 2.561344 2.030562
C 5.647767 1.769732 0.937881
C 1.876752 0.211899 -0.120738
C 0.588755 -0.407573 -0.126231
C 0.473733 -1.832327 -0.148612
C -0.837555 -2.410247 -0.178205
C -1.959943 -1.640762 -0.161854
C -1.876694 -0.212016 -0.120592
C -0.588696 0.407452 -0.126517
C -0.473668 1.832190 -0.149905
C 0.837623 2.410088 -0.179888
C 1.960009 1.640614 -0.162984
C -1.643530 2.628249 -0.154622
C -2.885933 2.002973 -0.113981
C -3.020804 0.613392 -0.088992
N -4.325380 0.044559 -0.036541
C -4.698230 -0.743314 1.077511
C -4.091928 -0.540291 2.325457
C -4.428022 -1.349755 3.407783
C -5.380213 -2.360326 3.273499
C -5.988485 -2.559645 2.032401
C -5.647934 -1.768883 0.939143
C -5.278162 0.465750 -0.995788
C -4.884527 0.624147 -2.333249
C -5.799513 1.061738 -3.286228
C -7.121702 1.333222 -2.929264
C -7.515137 1.171550 -1.599978
C -6.603236 0.751616 -0.634632
C -1.565577 4.134127 -0.179894
H 2.565826 -4.573123 -0.163055
H 1.054624 -4.497512 -1.075888
H 1.015461 -4.526102 0.685940
H 3.789152 -2.604760 -0.095814
H 3.860188 -0.404796 -2.611283
H 5.478783 -1.182339 -4.316028
H 7.834889 -1.669709 -3.674725
H 8.537506 -1.389762 -1.303667
H 6.910123 -0.642734 0.399820
H 3.355698 -0.245579 2.436971
H 3.946094 1.182749 4.365139
H 5.642450 2.988231 4.118776
H 6.724707 3.349483 1.905053
H 6.110094 1.939850 -0.027830
H -0.934317 -3.489037 -0.217496
H -2.937842 -2.104213 -0.185630
H 0.934386 3.488850 -0.219935
H 2.937915 2.104041 -0.187063
H -3.789080 2.604673 -0.097685
H -3.355727 0.247315 2.436831
H -3.946346 -1.179515 4.366033
H -5.642871 -2.985014 4.120945
H -6.725084 -3.347795 1.907449
H -6.110250 -1.939666 -0.026456
H -3.860104 0.402673 -2.611627
H -5.478667 1.178888 -4.317013
H -7.834757 1.666861 -3.676114
H -8.537402 1.388848 -1.304838
H -6.910046 0.643140 0.399265
H -1.015334 4.526556 0.682686
H -2.565752 4.572979 -0.166245
H -1.054607 4.496714 -1.079120
作业完成后在log文件中找到最后一个Excited State 1为S1激发能,Total Energy为电子态能量。
4 激发态T2、T3优化
由于本案例后续会用MOMAP做T2→S1态和T3→S1态的反系间窜越速率计算,所以前期还需要量化软件做激发态T2和T3的结构优化和频率计算,得到log文件和fchk文件。泛函和基组分别为M062x和Def2SVP,T2.gjf文件如下:
%nprocshared=32
%mem=6GB
%chk=t2.chk
#P opt freq M062x/Def2SVP TD(triplets,nstates=6,root=2)
Title Card Required
0 1
作业完成后在log文件中找到最后一个Excited State 2为T2激发能,Total Energy为电子态能量。
同样对T3优化可得T3态能量。结果显示T3电子态能量小于T2态能量,这表示T2与T3态在远离Frank-Condon区优化的过程中可能存在势能面交叉,使得最终优化的T3极小点能量小于T2。
