一份最新的3Gpp频段表
整理了一份最新的3Gpp 频段表,今天分享给大家。
FR1 Bands
Uplink (UL) operating band Base Station (BS) receive
Downlink (DL) operating band Base Station (BS) transmit
User Equipment (UE) transmit
User Equipment (UE) receive
LTE Operating Band NR Operating Band FDL_Low FDL_High FDL_Low FDL_High Duplex Mode
1 n1 1920 MHz  1980 MHz  2110 MHz   2170 MHz FDD
2 n2 1850 MHz  1910  MHz 1930 MHz  1990 MHz FDD
3 n3 1710 MHz  1785 MHz 1805 MHz  1880 MHz FDD
4   1710 MHz 1755 MHz  2110 MHz  2155 MHz FDD
5 n5 824 MHz 849 MHz 869 MHz  894MHz FDD
7 n7 2500 MHz 2570 MHz 2620 MHz  2690 MHz FDD
8 n8 880 MHz 915 MHz 925 MHz   960 MHz FDD
9   1749.9 MHz 1784.9 MHz 1844.9 MHz   1879.9 MHz FDD
10   1710 MHz 1770 MHz 2110 MHz  2170 MHz FDD
11   1427.9 MHz  1447.9 MHz 1475.9 MHz   1495.9 MHz FDD
12 n12 699 MHz 716 MHz 729 MHz 746 MHz FDD
13   777 MHz 787 MHz 746 MHz 756 MHz FDD
14 n14 788 MHz 798 MHz 758 MHz 768 MHz FDD
17   704 MHz  716 MHz 734 MHz 746 MHz FDD
18 n18 815 MHz 830 MHz 860 MHz  875 MHz FDD
19   830 MHz 845  MHz 875 MHz 890 MHz FDD
20 n20 832 MHz 862 MHz 791 MHz 821 MHz FDD
21   1447.9 MHz 1462.9 MHz 1495.9 MHz 1510.9 MHz FDD
22   3410 MHz 3490 MHz 3510 MHz 3590 MHz FDD
24   1626.5 MHz 1660.5 MHz 1525 MHz 1559 MHz FDD
25 n25 1850 MHz  1915  MHz 1930 MHz  1995 MHz FDD
26 n26 814 MHz 849 MHz 859 MHz  894MHz FDD
27   807 MHz 824 MHz 852 MHz 869 MHz FDD
28 n28 703 MHz 748 MHz 758 MHz 803 MHz FDD
29 n29 N/A N/A 717 MHz 728 MHz SDL
30 n30 2305 MHz 2315 MHz 2350 MHz 2360 MHz FDD
31   452.5 MHz 457.5 MHz 462.5 MHz 467.5 MHz FDD
32   N/A N/A 1452 MHz 1496 MHz SDL
65 n65 1920 MHz  2010 MHz 2110 MHz 2200 MHz FDD
66 n66 1710 MHz 1780 MHz 2110 MHz 2200 MHz FDD
67   N/A N/A 738 MHz 758 MHz SDL
68   698 MHz 728 MHz 753 MHz 783 MHz FDD
69   N/A N/A 2570 MHz  2620 MHz SDL
70 n70 1695 MHz 1710 MHz 1995 MHz 2020 MHz FDD
71 n71 663 MHz 698 MHz 617 MHz 652 MHz FDD
72   451 MHz 456 MHz 461 MHz 466 MHz FDD
73   450 MHz 455 MHz 460 MHz 465 MHz FDD
74 n74 1427 MHz 1470 MHz 1475 MHz 1518 MHz FDD
75 n75 N/A N/A 1432 MHz 1517 MHz SDL
76 n76 N/A N/A 1427 MHz 1432 MHz SDL
  n77 3300 MHz 4200 MHz 3300 MHz 4200 MHz TDD
  n78 3300 MHz 3800 MHz 3300 MHz 3800 MHz TDD
  n79 4400 MHz 5000 MHz 4400 MHz 5000 MHz TDD
  n80 1710 MHz 1785 MHz N/A N/A SUL
  n81 880 MHz 915 MHz N/A N/A SUL
  n82 832 MHz 862 MHz N/A N/A SUL
  n83 703 MHz 748 MHz N/A N/A SUL
  n84 1920 MHz 1980 MHz N/A N/A SUL
85   698 MHz 716 MHz 728 MHz 746 MHz FDD
  n86 1710 MHz 1780 MHz N/A N/A SUL
87   410 MHz 415 MHz 420 MHz 425 MHz FDD
88   412 MHz 417 MHz 422 MHz 427 MHz FDD
  n89 824 MHz 849 MHz N/A N/A SUL
  n90 2496 MHz 2690 MHz 2496 MHz 2690 MHz TDD
  n91 832 MHz 862 MHz 1427 MHz 1432 MHz
  n92 832 MHz 862 MHz 1432 MHz 1517 MHz
  n93 880 MHz 915 MHz 1427 MHz 1432 MHz
  n94 880 MHz 915 MHz 1432 MHz 1517 MHz
  n95 2010 MHz 2025 MHz N/A N/A SUL
33 n33 1900 MHz 1920 MHz 1900 MHz 1920 MHz TDD
34 n34 2010 MHz 2025 MHz  2010 MHz  2025 MHz TDD
35 n35 1850 MHz  1910 MHz 1850 MHz  1910 MHz TDD
36 n36 1930 MHz  1990 MHz 1930 MHz  1990 MHz TDD
37 n37 1910 MHz  1930 MHz 1910 MHz  1930 MHz TDD
38 n38 2570 MHz  2620 MHz 2570 MHz  2620 MHz TDD
39 n39 1880 MHz  1920 MHz 1880 MHz  1920 MHz TDD
40 n40 2300 MHz  2400 MHz 2300 MHz  2400 MHz TDD
41 n41 2496 MHz 2690 MHz 2496 MHz 2690 MHz TDD
42 n42 3400 MHz 3600 MHz 3400 MHz 3600 MHz TDD
43 n43 3600 MHz 3800 MHz 3600 MHz 3800 MHz TDD
44 n44 703 MHz 803 MHz 703 MHz 803 MHz TDD
45 n45 1447 MHz 1467 MHz 1447 MHz 1467 MHz TDD
46 n46 5150 MHz 5925 MHz 5150 MHz 5925 MHz TDD
47 n47 5855 MHz 5925 MHz 5855 MHz 5925 MHz TDD
48 n48 3550 MHz 3700 MHz 3550 MHz 3700 MHz TDD
49 n49 3550 MHz 3700 MHz 3550 MHz 3700 MHz TDD
50 n50 1432 MHz 1517 MHz 1432 MHz 1517 MHz TDD
51 n51 1427 MHz 1432 MHz 1427 MHz 1432 MHz TDD
52 n52 3300 MHz 3400 MHz 3300 MHz 3400 MHz TDD
53 n53 2483.5 MHz 2495 MHz 2483.5 MHz 2495 MHz TDD
    2545 MHz 2575 MHz 2545 MHz 2575 MHz TDD
FR2 Bands Uplink (UL) operating band Downlink (DL) operating band
Base Station (BS) receive Base Station (BS) transmit
User Equipment (UE) transmit User Equipment (UE) receive
  n257 26.5 GHz  29.5 GHz  26.5 GHz   29.5 GHz TDD
  n258 24.25 GHz  27.5 GHz 24.25 GHz  27.5 GHz TDD
  n260 37 GHz  40 GHz 37 GHz  40 GHz TDD
  n261 27.5 GHz 28.35 GHz  27.5 GHz  28.35 GHz TDD
审核编辑 :李倩
