图2显示效果
CLK ---PB0
DIN ---PB1
DC ---PB2
RST ---PB3
CS ---PB4
为驱动的方便,这里仍使用GPIO口来模拟SPI接口来实现,其输出高低电平的语句定义为:
#define LCD_CLK_L GPIO_Write(GPIOB,PIN0,GPIO_RESET)
#define LCD_CLK_H GPIO_Write(GPIOB,PIN0,GPIO_SET)
#define LCD_DIN_L GPIO_Write(GPIOB,PIN1,GPIO_RESET)
#define LCD_DIN_H GPIO_Write(GPIOB,PIN1,GPIO_SET)
#define LCD_DC_L GPIO_Write(GPIOB,PIN2,GPIO_RESET)
#define LCD_DC_H GPIO_Write(GPIOB,PIN2,GPIO_SET)
#define LCD_RST_L GPIO_Write(GPIOB,PIN3,GPIO_RESET)
#define LCD_RST_H GPIO_Write(GPIOB,PIN3,GPIO_SET)
#define LCD_CS_L GPIO_Write(GPIOB,PIN4,GPIO_RESET)
#define LCD_CS_H GPIO_Write(GPIOB,PIN4,GPIO_SET)
对LCD5110的初始化函数为:
void LCD5110_Init(void)
Delay32M_ms(800);
LCD_reset_hard;
LCD_write_cmd(0x21);
LCD_write_cmd(0x06);
LCD_write_cmd(0x13);
LCD_write_cmd(0xc8);
LCD_write_cmd(0x20);
LCD_write_cmd(0x0c);
LCD_write_cmd(Y_Page_Addr);
LCD_write_cmd(X_Col_Addr);
LCD_clr_scr();
复制代码
实现字节数据发送的函数为:
void LCD_write_byte(unsigned char wbyte, unsigned char dat_cmd)
unsigned char i;
LCD_CS_L;
if(dat_cmd)
LCD_DC_H;
else
LCD_DC_L;
for(i = 8; i; i--)
if(wbyte & 0x80)
LCD_DIN_H;
else
LCD_DIN_L;
Delay_us(2);
LCD_CLK_L;
wbyte <<= 1;
Delay_us(2);
LCD_CLK_H;
LCD_CS_H;
复制代码
清除显示屏的函数为:
void LCD_clr_scr(void)
unsigned int i;
for(i = 504; i; i--) LCD_write_dat(0x00);
复制代码
实现图示效果的主程序为:
int main(void)
int16_t i;
CLIC_Init();
System_Clock_Init();
GPIO_MODE_Init(GPIOB,PIN0,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOB,PIN1,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOB,PIN2,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOB,PIN3,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOB,PIN4,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOA,PIN8,GPIO_MODE_OUTPUT);
GPIO_Write(GPIOA,PIN8,GPIO_SET);
LCD5110_Init();
LCD_prints(0,0,"CSM32RV20");
LCD_prints(0,1,"LCD5110 ");
LCD_prints(0,2,"jinglixixi");
while(1)
GPIO_Toggle(GPIOA,PIN8);
for(i=0;i<10;i++)
Delay32M_us(50000);
复制代码
对于另一款0.96寸的彩色LCD屏,它也是使用SPI接口工作。相较于LCD5110显示屏,该显示屏可以显示彩色的图片。
该显示屏的初始化函数为:
void OLED_Init(void)
OLED_SCLK_Set();
OLED_SDIN_Set();
Delay32M_ms(800);
OLED_WR_Byte(0xAE,OLED_CMD);
OLED_WR_Byte(0x02,OLED_CMD);
OLED_WR_Byte(0x10,OLED_CMD);
OLED_WR_Byte(0x40,OLED_CMD);
OLED_WR_Byte(0x81,OLED_CMD);
OLED_WR_Byte(0xff,OLED_CMD);
OLED_WR_Byte(0xA1,OLED_CMD);
OLED_WR_Byte(0xC8,OLED_CMD);
OLED_WR_Byte(0xA6,OLED_CMD);
OLED_WR_Byte(0xA8,OLED_CMD);
OLED_WR_Byte(0x3f,OLED_CMD);
OLED_WR_Byte(0xD3,OLED_CMD);
OLED_WR_Byte(0x00,OLED_CMD);
OLED_WR_Byte(0xd5,OLED_CMD);
OLED_WR_Byte(0x80,OLED_CMD);
OLED_WR_Byte(0xD9,OLED_CMD);
OLED_WR_Byte(0xF1,OLED_CMD);
OLED_WR_Byte(0xDA,OLED_CMD);
OLED_WR_Byte(0x12,OLED_CMD);
OLED_WR_Byte(0xDB,OLED_CMD);
OLED_WR_Byte(0x20,OLED_CMD);
OLED_WR_Byte(0x8D,OLED_CMD);
OLED_WR_Byte(0x14,OLED_CMD);
OLED_WR_Byte(0xA4,OLED_CMD);
OLED_WR_Byte(0xAF,OLED_CMD);
复制代码
其图片显示函数为:
void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
if(y1%8==0) y=y1/8;
else y=y1/8+1;
for(y=y0;y;y++)
OLED_Set_Pos(x0,y);
for(x=x0;x;x++)
OLED_WR_Byte(BMP[j++],OLED_DATA);
复制代码
相应的显示主程序为:
int main(void)
CLIC_Init();
OLED_ShowString(20,0,"CSM32RV20",16);
OLED_ShowString(20,2,"OLED TEST",16);
Delay32M_ms(2000);
OLED_DrawBMP(0,0,128,8,BMP1);
while(1);
复制代码
经编译与下载,其显示效果如图3和图4所示。
图3显示字符串
图4显示图像
对于TFT显示屏,它相较于0.96寸LCD显示屏其显示尺寸要更大,故显示的内容也更多。
该显示屏的初始化函数为:
void LCD_Init(void)
LCD_REST_Low();
Delay32M_ms(20);
LCD_REST_High();
Delay32M_ms(20);
LCD_CS_Low();
LCD_WR_REG(0xCB);
LCD_WR_DATA8(0x39);
LCD_WR_DATA8(0x2C);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x34);
LCD_WR_DATA8(0x02);
LCD_WR_REG(0xCF);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0XC1);
LCD_WR_DATA8(0X30);
LCD_WR_REG(0xE8);
LCD_WR_DATA8(0x85);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x78);
LCD_WR_REG(0xEA);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0xED);
LCD_WR_DATA8(0x64);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0X12);
LCD_WR_DATA8(0X81);
LCD_WR_REG(0xF7);
LCD_WR_DATA8(0x20);
LCD_WR_REG(0xC0);
LCD_WR_DATA8(0x23);
LCD_WR_REG(0xC1);
LCD_WR_DATA8(0x10);
LCD_WR_REG(0xC5);
LCD_WR_DATA8(0x3e);
LCD_WR_DATA8(0x28);
LCD_WR_REG(0xC7);
LCD_WR_DATA8(0x86);
LCD_WR_REG(0x36);
LCD_WR_DATA8(0x48);
LCD_WR_REG(0x3A);
LCD_WR_DATA8(0x55);
LCD_WR_REG(0xB1);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x18);
LCD_WR_REG(0xB6);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x82);
LCD_WR_DATA8(0x27);
LCD_WR_REG(0xF2);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0x26);
LCD_WR_DATA8(0x01);
LCD_WR_REG(0xE0);
LCD_WR_DATA8(0x0F);
LCD_WR_DATA8(0x31);
LCD_WR_DATA8(0x2B);
LCD_WR_DATA8(0x0C);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x4E);
LCD_WR_DATA8(0xF1);
LCD_WR_DATA8(0x37);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x09);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0XE1);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x14);
LCD_WR_DATA8(0x03);
LCD_WR_DATA8(0x11);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x31);
LCD_WR_DATA8(0xC1);
LCD_WR_DATA8(0x48);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x0F);
LCD_WR_DATA8(0x0C);
LCD_WR_DATA8(0x31);
LCD_WR_DATA8(0x36);
LCD_WR_DATA8(0x0F);
LCD_WR_REG(0x11);
Delay32M_ms(120);
LCD_WR_REG(0x29);
LCD_WR_REG(0x2c);
复制代码
其字符界面显示函数为:
void xianshi()
LCD_Clear(RED);
BACK_COLOR=RED;
POINT_COLOR=WHITE;
LCD_ShowString(20,80,160,16,16,"CSM32RV20");
LCD_ShowString(20,120,200,16,16,"2.4 SPI_TFT 240*320");
LCD_ShowString(20,240,160,16,16,"jinglxixi ");
LCD_ShowString(20,280,200,16,16,"2022.1.16 ");
复制代码
相应的图片显示函数为:
void show_image(void)
int i,j,k;
unsigned char picH,picL;
Address_set(0,0,79,79);
k=0;
for(i=0;i<80;i++)
for(j=0;j<80;j++)
picH=gImage_cgq[k*2];
picL=gImage_cgq[k*2+1];
LCD_WR_DATA8(picH);
LCD_WR_DATA8(picL);
k++;
复制代码
实现显示效果的主程序为:
int main(void)
int16_t i;
CLIC_Init();
GPIO_MODE_Init(GPIOA,PIN10,GPIO_MODE_OUTPUT);
GPIO_MODE_Init(GPIOA,PIN12,GPIO_MODE_OUTPUT);
GPIO_Write(GPIOB,PIN0,GPIO_SET);
GPIO_Write(GPIOB,PIN1,GPIO_SET);
GPIO_Write(GPIOA,PIN10,GPIO_SET);
GPIO_Write(GPIOA,PIN12,GPIO_SET);
LCD_Init();
LCD_Clear(RED);
xianshi();
Delay32M_ms(2000);
LCD_Clear(BLACK);
show_image();
while(1)
for(i=0;i<10;i++)
Delay32M_us(50000);
return 0;
复制代码
经编译与下载,其显示效果如图5和图6所示。
图5显示字符串
图6显示字符串
