MIMXRT1176支持8位列地址的SDRAM器件W9864G6
    MIMXRT1176的开发板配套的 SDRAM是W9825G6KH,对应的列地址是9位的。
SDRAM
    MIMXRT1176支持的列地址是 8/9/10/11/12位。
SDRAM
    SDRAM 替换成 W9864G6后,Column地址变为 8位的。
SDRAM
    SDK中例程目录 evkmimxrt1170driver_examplessemcsdramcm7,修改semc_sdram.c文件配置如下。
status_t BOARD_InitSEMC(void)
    semc_config_t config;
    semc_sdram_config_t sdramconfig;
    uint32_t clockFrq = EXAMPLE_SEMC_CLK_FREQ;
    /* Initializes the MAC configure structure to zero. */
    memset(&config, 0, sizeof(semc_config_t));
    memset(&sdramconfig, 0, sizeof(semc_sdram_config_t));
    /* Initialize SEMC. */
    SEMC_GetDefaultConfig(&config);
    config.dqsMode = kSEMC_Loopbackdqspad; /* For more accurate timing. */
    SEMC_Init(SEMC, &config);
    /* Configure SDRAM. */
    sdramconfig.csxPinMux           = kSEMC_MUXCSX0;
    sdramconfig.address             = 0x80000000;
    sdramconfig.memsize_kbytes      = 1 * 8 * 1024;       /* 8MB*/
    sdramconfig.portSize            = kSEMC_PortSize16Bit;
    sdramconfig.burstLen            = kSEMC_Sdram_BurstLen8;
    sdramconfig.columnAddrBitNum    = kSEMC_SdramColunm_8bit;
    sdramconfig.casLatency          = kSEMC_LatencyThree;
    sdramconfig.tPrecharge2Act_Ns   = 15; /* tRP 15ns */
    sdramconfig.tAct2ReadWrite_Ns   = 15; /* tRCD 15ns */
    sdramconfig.tRefreshRecovery_Ns = 70; /* Use the maximum of the (Trfc , Txsr). */
    sdramconfig.tWriteRecovery_Ns   = 2;  /* tWR 2ns */
    sdramconfig.tCkeOff_Ns =
        42; /* The minimum cycle of SDRAM CLK off state. CKE is off in self refresh at a minimum period tRAS.*/
    sdramconfig.tAct2Prechage_Ns       = 40; /* tRAS 40ns */
    sdramconfig.tSelfRefRecovery_Ns    = 70;
    sdramconfig.tRefresh2Refresh_Ns    = 60;
    sdramconfig.tAct2Act_Ns            = 2; /* tRC/tRDD 2ns */
    sdramconfig.tPrescalePeriod_Ns     = 160 * (1000000000 / clockFrq);
    sdramconfig.refreshPeriod_nsPerRow = 64 * 1000000 / 8192; /* 64ms/8192 */
    sdramconfig.refreshUrgThreshold    = sdramconfig.refreshPeriod_nsPerRow;
    sdramconfig.refreshBurstLen        = 1;
    sdramconfig.delayChain             = 6; /* For all tempeatures. */
    return SEMC_ConfigureSDRAM(SEMC, kSEMC_SDRAM_CS0, &sdramconfig, clockFrq);
static void SEMC_SDRAMReadWrite8Bit(void)
    uint32_t index;
    uint32_t datalen = SEMC_EXAMPLE_DATALEN;
    uint8_t *sdram   = (uint8_t *)EXAMPLE_SEMC_START_ADDRESS; /* SDRAM start address. */
    bool result      = true;
    PRINTF(" SEMC SDRAM Memory 8 bit Write Start, Start Address 0x%x, Data Length %d ! ", sdram, datalen);
    memset(sdram_writeBuffer, 0, sizeof(sdram_writeBuffer));
    memset(sdram_readBuffer, 0, sizeof(sdram_readBuffer));
    /* Prepare data and write to SDRAM. */
    for (index = 0; index < datalen; index++)
        sdram_writeBuffer[index] = index % 0x100;
        sdram[index]             = sdram_writeBuffer[index];
    PRINTF(" SEMC SDRAM Read 8 bit Data Start, Start Address 0x%x, Data Length %d ! ", sdram, datalen);
#if defined(CACHE_MAINTAIN) && CACHE_MAINTAIN
    DCACHE_InvalidateByRange(EXAMPLE_SEMC_START_ADDRESS, 4U * SEMC_EXAMPLE_DATALEN);
#endif
    /* Read data from the SDRAM. */
        sdram_readBuffer[index] = sdram[index];
    PRINTF(" SEMC SDRAM 8 bit Data Write and Read Compare Start! ");
    /* Compare the two buffers. */
    while (datalen--)
        if (sdram_writeBuffer[datalen] != sdram_readBuffer[datalen])
            result = false;
            break;
    if (!result)
        PRINTF(" SEMC SDRAM 8 bit Data Write and Read Compare Failed! ");
    else
        PRINTF(" SEMC SDRAM 8 bit Data Write and Read Compare Succeed! ");
    备注:在 MIMXRT1050 MCU 上只支持9/10/11/12位,不支持 8位的。
SDRAM
    SDRAM 配置参考文档:
https://www.nxp.com.cn/docs/en/nxp/application-notes/AN12026.pdf
审核编辑 :李倩
