一个工程师打算在命令行里编译Xilinx SDK工程,以便集成进入其它自动化构建工具。Xilinx SDK工程都支持在命令行编译。在命令行里编译Xilinx SDK工程前,需要执行call
C:/Xilinx/SDK/2019.1/settings64.bat,设置编译环境。
在应用程序工程的Debug或者Release目录下,有文件makefile,objects.mk,sources.mk,执行make命令,就可以编译。
在BSP工程目录下,有文件makefile,执行make命令,也可以编译。在BSP工程目录下,有很多驱动程序。对于不打算使用的驱动程序,可以直接删除,不会影响编译。
下面是删除类似重复信息后的BSP编译记录。例子中,删除了dpdma,canps,axipmon,xilpm等驱动程序。
删除类似重复信息后的BSP编译记录
C:prjzcu106_fsbl_bsp2>call C:/Xilinx/SDK/2019.1/settings64.bat C:prjzcu106_fsbl_bsp2>make clean make -C psu_cortexa53_0/libsrc/bram_v4_3/src -s clean make -C psu_cortexa53_0/libsrc/clockps_v1_1/src -s clean ... ... make -C psu_cortexa53_0/libsrc/wdtps_v3_1/src -s clean rm -f psu_cortexa53_0/lib/libxil.a C:prjzcu106_fsbl_bsp2>make Running Make include in psu_cortexa53_0/libsrc/bram_v4_3/src make -C psu_cortexa53_0/libsrc/bram_v4_3/src -s include "SHELL=C:/tools/cygwin64/bin/sh.exe" "COMPILER=aarch64-none-elf-gcc" "ARCHIVER=aarch64-none-elf-ar" "COMPILER_FLAGS= -O2 -c" "EXTRA_COMPILER_FLAGS=-g -Wall -Wextra -Os -flto -ffat-lto-objects" ... ... Running Make libs in psu_cortexa53_0/libsrc/video_common_v4_6/src make -C psu_cortexa53_0/libsrc/video_common_v4_6/src -s libs "SHELL=C:/tools/cygwin64/bin/sh.exe" "COMPILER=aarch64-none-elf-gcc" "ARCHIVER=aarch64-none-elf-ar" "COMPILER_FLAGS= -O2 -c" "EXTRA_COMPILER_FLAGS=-g -Wall -Wextra -Os -flto -ffat-lto-objects" Compiling video_common Running Make libs in psu_cortexa53_0/libsrc/wdtps_v3_1/src make -C psu_cortexa53_0/libsrc/wdtps_v3_1/src -s libs "SHELL=C:/tools/cygwin64/bin/sh.exe" "COMPILER=aarch64-none-elf-gcc" "ARCHIVER=aarch64-none-elf-ar" "COMPILER_FLAGS= -O2 -c" "EXTRA_COMPILER_FLAGS=-g -Wall -Wextra -Os -flto -ffat-lto-objects" Compiling wdtps Finished building libraries C:prjzcu106_fsbl_bsp2>ls psu_cortexa53_0/lib libxil.a libxilffs.a libxilpm.a libxilsecure.a
审核编辑 :李倩
