OOM Killer机制学习
当系统内存不足以分配时,Linux内核会使用一种OOM Killer(Out-Of-Memory Killer)机制释放内存,该机制通过一系列比较选择出最适合的进程并将其kill掉,从而达到保障系统稳定运行的目的。那么在内核中,OOM Killer具体是怎么运转的呢?
一、触发过程
在申请内存时,必然会调用alloc_page(),在__alloc_pages中有以下调用关系:
内核
其中,在__alloc_pages_slowpath中,当反复尝试reclaim和compact后仍不成功,就会调用__alloc_pages_may_oom进行内存释放。
   * If we failed to make any progress reclaiming, then we are
   * running out of options and have to consider going OOM
if (!did_some_progress) {
  if (oom_gfp_allowed(gfp_mask)) {
    if (oom_killer_disabled)
      goto nopage;
    /* Coredumps can quickly deplete all memory reserves */
    if ((current->flags & PF_DUMPCORE) &&
        !(gfp_mask & __GFP_NOFAIL))
      goto nopage;
    page = __alloc_pages_may_oom(gfp_mask, order,
        zonelist, high_zoneidx,
        nodemask, preferred_zone,
        classzone_idx, migratetype);
如果定义了oom_killer_disabled,就会直接goto到nopage,不会触发OOM机制(此值默认为0).
二、工作过程(基于Linux-3.18)
当内核检测到内存不足,执行到out_of_memory时,OOM Killer会选择一个进程并把他kill掉:
p = select_bad_process(&points, totalpages, mpol_mask, force_kill);
具体的选择过程在select_bad_process中进行:
 * Simple selection loop. We chose the process with the highest
 * number of 'points'.  Returns -1 on scan abort.
 * (not docbooked, we don't want this one cluttering up the manual)
static struct task_struct *select_bad_process(unsigned int *ppoints,
    unsigned long totalpages, const nodemask_t *nodemask,
    bool force_kill)
  struct task_struct *g, *p;
  struct task_struct *chosen = NULL;
  unsigned long chosen_points = 0;
  rcu_read_lock();
  for_each_process_thread(g, p) {
    unsigned int points;
    switch (oom_scan_process_thread(p, totalpages, nodemask,
            force_kill)) {
    case OOM_SCAN_SELECT:
      chosen = p;
      chosen_points = ULONG_MAX;
      /* fall through */
    case OOM_SCAN_CONTINUE:
      continue;
    case OOM_SCAN_ABORT:
      rcu_read_unlock();
      return (struct task_struct *)(-1UL);
    case OOM_SCAN_OK:
      break;
    points = oom_badness(p, NULL, nodemask, totalpages);
    if (!points || points < chosen_points)
      continue;
    /* Prefer thread group leaders for display purposes */
    if (points == chosen_points && thread_group_leader(chosen))
      continue;
    chosen = p;
    chosen_points = points;
  if (chosen)
    get_task_struct(chosen);
  rcu_read_unlock();
  *ppoints = chosen_points * 1000 / totalpages;
  return chosen;
select_bad_process会选择一个points数值最高的进程并返回。在宏for_each_process_thread循环里,通过switch和oom_scan_process_thread对一些进程做特殊化处理,如一些进程不适合被结束,就跳过本次循环。如果该进程没有特殊状态,oom_scan_process_thread返回OOM_SCAN_OK,继续向下进行判断。这里使用了oom_badness对其points值进行计算。
 * oom_badness - heuristic function to determine which candidate task to kill
 * @p: task struct of which task we should calculate
 * @totalpages: total present RAM allowed for page allocation
 * The heuristic for determining which task to kill is made to be as simple and
 * predictable as possible.  The goal is to return the highest value for the
 * task consuming the most memory to avoid subsequent oom failures.
unsigned long oom_badness(struct task_struct *p, struct mem_cgroup *memcg,
        const nodemask_t *nodemask, unsigned long totalpages)
  long points;
  long adj;
  if (oom_unkillable_task(p, memcg, nodemask))
    return 0;
  p = find_lock_task_mm(p);
  if (!p)
    return 0;
  adj = (long)p->signal->oom_score_adj;
  if (adj == OOM_SCORE_ADJ_MIN) {
    task_unlock(p);
    return 0;
   * The baseline for the badness score is the proportion of RAM that each
   * task's rss, pagetable and swap space use.
  points = get_mm_rss(p->mm) + atomic_long_read(&p->mm->nr_ptes) +
     get_mm_counter(p->mm, MM_SWAPENTS);
  task_unlock(p);
   * Root processes get 3% bonus, just like the __vm_enough_memory()
   * implementation used by LSMs.
  if (has_capability_noaudit(p, CAP_SYS_ADMIN))
    points -= (points * 3) / 100;
  /* Normalize to oom_score_adj units */
  adj *= totalpages / 1000;
  points += adj;
   * Never return 0 for an eligible task regardless of the root bonus and
   * oom_score_adj (oom_score_adj can't be OOM_SCORE_ADJ_MIN here).
  return points > 0 ? points : 1;
在oom_badness的上半部分,对进程做了一些判断,排除了不可进行kill的进程以及oom_score_adj为OOM_SCORE_ADJ_MIN(-1000)的进程,进行了return 0。接着是进行比重计算,将rss、nr_ptes、swap空间使用量占RAM比重相加。如果是Root进程则去掉3%的比重points -= (points * 3) / 100;。之后对adj进行归一化并与points相加,在返回值计算时,使用了一个三目运算符,即当points大于0时,返回points,否则返回1。这里注释给出的原因是,对于有资格的进程(即可以被OOM Killer掉的进程),是绝不能返回0的。(这里我的理解是,如果points返回0,这个进程可能在之后的比较中就处于劣势,成为漏网之鱼)
内核
再回到select_bad_process中看,之后跟的一个if比较就是为了进行取最大值的判断,再之后判断该进程是否为thread_group_leader,若是则continue跳过本次循环,否则该进程就是被chosen的进程。
再回到out_of_memory中,得到p值后,需要对其进行判断:
if (!p) {
    dump_header(NULL, gfp_mask, order, NULL, mpol_mask);
    panic("Out of memory and no killable processes...
  if (p != (void *)-1UL) {
    oom_kill_process(p, gfp_mask, order, points, totalpages, NULL,
         nodemask, "Out of memory");
    killed = 1;
当p是0时,即没有找到可以kill掉的进程,内核发出一个panic。当p不是0时,即找到了可以kill掉的进程,则通过oom_kill_process将其kill。
在oom_kill_process中有个“有意思”的事是,在kill之前,会先遍历其子进程,重新通过oom_badness计算出一个最适合被kill掉的子进程,该子进程会有限考虑被kill掉,从而避免kill父进程导致的接管子进程的工作开销。并且最终被kill掉的进程的名字叫victim,这个单词的中文含义是牺牲者,有点是为了整个系统的稳定运转而牺牲的意思。在这之后OOM Killer会kill掉和victim使用相同虚拟内存的进程,并通过发送SIGKILL信号将其终止。
内核
三、到底为什么会发生Out Of Memory?
因为物理内存页的分配发生在使用的瞬间而非分配的瞬间。若某个进程申请了200MB内存,但实际上只使用了100MB,未使用到的100MB根本没有分配物理内存页。当进程需要内存时,进程从内核得到的只是虚拟地址的使用权,而不是实际的物理地址,实际的物理内存只有当进程真的去访问新获取的虚拟地址时,产生缺页异常,从而进入分配实际物理地址的过程,之后系统返回产生异常的地址,重新执行内存访问。虚拟内存需要物理内存作为支撑,当分配了太多虚拟内存,导致物理内存不够时,就发生了Out Of Memory。这种允许超额commit的机制就是overcommit。
overcommit即操作系统在应用申请内存空间时不去检查是否超出当前可用量,随意满足申请要求,应用也不管实际是否有足够多的内存可使用,认为我申请了2G,OS肯定就给我2G使用。最后,随着内存越用越多,OS发现内存不够用了,必须要收回一些内存才行,就触发了上述的OOM Killer机制回收内存。
Linux根据参数 vm.overcommit_memory设置overcommit:
0 ——默认值,启发式overcommit,它允许overcommit,但太明显的overcommit会被拒绝,比如malloc一次性申请的内存大小就超过了系统总内存。
1 ——Always overcommit. 允许overcommit,对内存申请来者不拒。
2 ——不允许overcommit,提交给系统的总地址空间大小不允许超过CommitLimit。(CommitLimit 就是overcommit的阈值,申请的内存总数超过CommitLimit的话就算是overcommit)
四、总结
由于物理内存的分配机制,以及overcommit的存在,导致了在物理内存不够时的OOM Killer。OOM Killer机制很有意思,它为了保护整个系统的安全稳定运行,需要找出一个最合适的进程kill掉。这是不得已而为之,内核必须在kill掉进程和系统崩溃之间选择其中一个。内核代码中out_of_memory注释中也体现了这种无奈。> * If we run out of memory, we have the choice between either
killing a random task (bad), letting the system crash (worse)
OR try to be smart about which process to kill. Note that we
don't have to be perfect here, we just have to be good.
在选择合适的进程时,OOM Killer会挑选一个占用内存最大的进程,这也很好理解,毕竟kill掉一个大的可以获得更多的物理内存,并且损失也比较小。如果kill掉多个小的,损失会比较大。Linux内核总是去选择更高效的方法。
  审核编辑:汤梓红
