真实原因:原先是因为个人原因,需要研究新版鉴权服务,看到了spring-authorization-server
,使用过程中,想着能不能整合新版本cloud,因此此处先以springboot搭建spring-authorization-server
,后续再替换为springcloud2021。
官方原因:原先使用Spring Security OAuth
,而该项目已经逐渐被淘汰,虽然网上还是有不少该方案,但秉着技术要随时代更新,从而使用spring-authorization-server
Spring 团队正式宣布 Spring Security OAuth
停止维护,该项目将不会再进行任何的迭代
需要创建3张表,sql分别如下
CREATE TABLE `oauth2_authorization` (
`id` varchar(100) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`registered_client_id` varchar(100) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`principal_name` varchar(200) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`authorization_grant_type` varchar(100) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`attributes` varchar(4000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`state` varchar(500) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`authorization_code_value` blob NULL,
`authorization_code_issued_at` timestamp(0) NULL DEFAULT NULL,
`authorization_code_expires_at` timestamp(0) NULL DEFAULT NULL,
`authorization_code_metadata` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`access_token_value` blob NULL,
`access_token_issued_at` timestamp(0) NULL DEFAULT NULL,
`access_token_expires_at` timestamp(0) NULL DEFAULT NULL,
`access_token_metadata` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`access_token_type` varchar(100) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`access_token_scopes` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`oidc_id_token_value` blob NULL,
`oidc_id_token_issued_at` timestamp(0) NULL DEFAULT NULL,
`oidc_id_token_expires_at` timestamp(0) NULL DEFAULT NULL,
`oidc_id_token_metadata` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`refresh_token_value` blob NULL,
`refresh_token_issued_at` timestamp(0) NULL DEFAULT NULL,
`refresh_token_expires_at` timestamp(0) NULL DEFAULT NULL,
`refresh_token_metadata` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
PRIMARY KEY (`id`) USING BTREE
) ENGINE = InnoDB CHARACTER SET = utf8mb4 COLLATE = utf8mb4_unicode_ci ROW_FORMAT = Dynamic;
CREATE TABLE `oauth2_authorization_consent` (
`authorities` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
PRIMARY KEY (`registered_client_id`, `principal_name`) USING BTREE
CREATE TABLE `oauth2_registered_client` (
`client_id` varchar(100) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`client_id_issued_at` timestamp(0) NOT NULL DEFAULT CURRENT_TIMESTAMP(0),
`client_secret` varchar(200) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`client_secret_expires_at` timestamp(0) NULL DEFAULT NULL,
`client_name` varchar(200) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`client_authentication_methods` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`authorization_grant_types` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`redirect_uris` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NULL DEFAULT NULL,
`scopes` varchar(1000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`client_settings` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
`token_settings` varchar(2000) CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci NOT NULL,
pom.xml引入依赖
注意!!!spring boot版本需2.6.x以上,是为后面升级成cloud做准备
<dependency>
<groupId>org.projectlombokgroupId>
<artifactId>lombokartifactId>
<version>1.18.22version>
dependency>
<dependency>
<groupId>com.xxxx.iovgroupId>
<artifactId>iov-cloud-framework-webartifactId>
<version>2.0.0-SNAPSHOTversion>
<exclusions>
<exclusion>
<groupId>org.springframework.bootgroupId>
<artifactId>spring-boot-starter-webartifactId>
exclusion>
exclusions>
dependency>
<dependency>
<version>2.6.6version>
dependency>
<dependency>
<groupId>cn.hutoolgroupId>
<artifactId>hutool-allartifactId>
<version>5.8.0version>
dependency>
<dependency>
<groupId>com.alibabagroupId>
<artifactId>fastjsonartifactId>
<version>1.2.39version>
dependency>
<dependency>
<artifactId>spring-boot-starter-securityartifactId>
dependency>
<dependency>
<groupId>org.springframework.securitygroupId>
<artifactId>spring-security-oauth2-authorization-serverartifactId>
<version>0.2.3version>
dependency>
<dependency>
<artifactId>spring-security-casartifactId>
dependency>
<dependency>
<artifactId>spring-boot-starter-thymeleafartifactId>
dependency>
<dependency>
<artifactId>druid-spring-boot-starterartifactId>
<version>1.2.9version>
dependency>
<dependency>
<groupId>mysqlgroupId>
<artifactId>mysql-connector-javaartifactId>
<version>8.0.28version>
dependency>
<dependency>
<groupId>com.baomidougroupId>
<artifactId>mybatis-plus-boot-starterartifactId>
<version>3.5.1version>
dependency>
<dependency>
<groupId>com.google.guavagroupId>
<artifactId>guavaartifactId>
<version>31.1-jreversion>
dependency>
创建自定义登录页面 login.html (可不要,使用自带的登录界面)
html>
<html lang="en"
xmlns:th="https://www.thymeleaf.org"
xmlns:sec="http://www.thymeleaf.org/thymeleaf-extras-springsecurity5">
<head>
<meta charset="utf-8">
<meta name="author" content="test">
<meta name="viewport" content="width=device-width,initial-scale=1">
<meta name="description" content="This is a login page template based on Bootstrap 5">
<title>Login Pagetitle>
<style>
.is-invalid {
color: red;
.invalid-feedback {
color: red;
.mb-3 {
margin-bottom: 3px;
style>
<script th:inline="javascript">
if (window !== top) {
top.location.href = location.href;
script>
head>
<body class="hold-transition login-page">
<div class="login-box">
<div class="card">
<div class="card-body login-card-body">
<p class="login-box-msg">Sign in to start your sessionp>
<div th:if="${param.error}" class="alert alert-error">
Invalid username and password.
div>
<div th:if="${param.logout}" class="alert alert-success">
You have been logged out.
div>
<form th:action="@{/login}" method="post" id="loginForm">
<div class="input-group mb-3">
<input type="text" class="form-control" value="zxg" name="username" placeholder="Email"
autocomplete="off">
div>
<input type="password" id="password" name="password" value="123" class="form-control"
maxlength="25" placeholder="Password"
autocomplete="off">
div>
<div class="row">
<div class="col-4">
<button type="submit" id="submitBtn">Sign Inbutton>
div>
div>
form>
<p class="mb-1">
<a href="javascript:void(0)">I forgot my passworda>
p>
<p class="mb-0">
<a href="javascript:void(0)" class="text-center">Register a new membershipa>
p>
div>
div>
div>
<script src="https://cdn.bootcdn.net/ajax/libs/jquery/3.6.0/jquery.js">script>
<script src="https://cdn.bootcdn.net/ajax/libs/jsencrypt/3.1.0/jsencrypt.min.js">script>
<script src="https://cdn.bootcdn.net/ajax/libs/jquery-validate/1.9.0/jquery.validate.min.js">script>
<script src="https://cdn.bootcdn.net/ajax/libs/jquery-validate/1.9.0/additional-methods.min.js">script>
$(function () {
var encrypt = new JSEncrypt();
$.validator.setDefaults({
submitHandler: function (form) {
console.log("Form successful submitted!");
form.submit();
script>
body>
html>
创建自定义授权页面 consent.html(可不要,可使用自带的授权页面)
html>
<html lang="en">
<head>
<meta name="viewport" content="width=device-width, initial-scale=1, shrink-to-fit=no">
<link rel="stylesheet" href="https://stackpath.bootstrapcdn.com/bootstrap/4.5.2/css/bootstrap.min.css"
integrity="sha384-JcKb8q3iqJ61gNV9KGb8thSsNjpSL0n8PARn9HuZOnIxN0hoP+VmmDGMN5t9UJ0Z" crossorigin="anonymous">
<title>授权页面title>
<style>
body {
background-color: aliceblue;
style>
<script>
function cancelConsent() {
document.consent_form.reset();
document.consent_form.submit();
script>
head>
<body>
<div class="container">
<div class="py-5">
<h1 class="text-center text-primary">用户授权确认h1>
div>
<div class="row">
<div class="col text-center">
<p>
应用
<a href="https://felord.cn"><span class="font-weight-bold text-primary" th:text="${clientName}">span>a>
想要访问您的账号
<span class="font-weight-bold" th:text="${principalName}">span>
p>
div>
div>
<div class="row pb-3">
<div class="col text-center"><p>上述应用程序请求以下权限<br/>请审阅以下选项并勾选您同意的权限p>div>
div>
<div class="row">
<form name="consent_form" method="post" action="/oauth2/authorize">
<input type="hidden" name="client_id" th:value="${clientId}">
<input type="hidden" name="state" th:value="${state}">
<div th:each="scope: ${scopes}" class="form-group form-check py-1">
<input class="form-check-input"
type="checkbox"
name="scope"
th:value="${scope.scope}"
th:id="${scope.scope}">
<label class="form-check-label font-weight-bold" th:for="${scope.scope}" th:text="${scope.scope}">label>
<p class="text-primary" th:text="${scope.description}">p>
div>
<p th:if="${not #lists.isEmpty(previouslyApprovedScopes)}">您已对上述应用授予以下权限:p>
<div th:each="scope: ${previouslyApprovedScopes}" class="form-group form-check py-1">
type="checkbox"
disabled
checked>
div>
<div class="form-group pt-3">
<button class="btn btn-primary btn-lg" type="submit" id="submit-consent">
同意授权
button>
div>
<div class="form-group">
<button class="btn btn-link regular" type="button" id="cancel-consent" onclick="cancelConsent();">
取消授权
button>
div>
form>
div>
div>
<div class="row pt-4">
<p>
<small>
需要您同意并提供访问权限。
<br/>如果您不同意,请单击<span class="font-weight-bold text-primary">取消授权span>,将不会为上述应用程序提供任何您的信息。
small>
p>
div>
div>
div>
body>
html>
修改配置文件 application.yml(配置内容可自行简略)
server:
port: 9000
spring:
application:
thymeleaf:
cache: false
datasource:
url: jdbc//192.168.1.69:3306/test
username: root
password: root
driver-class-name: com.mysql.cj.jdbc.Driver
security:
oauth2:
resourceserver:
jwt:
issuer-uri: http://127.0.0.1:9000 #认证中心端点,作为资源端的配置
application:
security:
excludeUrls: #excludeUrls中存放白名单地址
- "/favicon.ico"
# mybatis plus配置
mybatis-plus:
mapper-locations: classpath:/mapper/*Mapper.xml
global-config:
# 关闭MP3.0自带的banner
banner: false
db-config:
#主键类型 0:"数据库ID自增", 1:"不操作", 2:"用户输入ID",3:"数字型snowflake", 4:"全局唯一ID UUID", 5:"字符串型snowflake";
id-type: AUTO
#字段策略
insert-strategy: not_null
update-strategy: not_null
select-strategy: not_null
#驼峰下划线w转换
table-underline: true
# 逻辑删除配置
# 逻辑删除全局值(1表示已删除,这也是Mybatis Plus的默认配置)
logic-delete-value: 1
# 逻辑未删除全局值(0表示未删除,这也是Mybatis Plus的默认配置)
logic-not-delete-value: 0
configuration:
#驼峰
map-underscore-to-camel-case: true
#打开二级缓存
cache-enabled: true
# log-impl: org.apache.ibatis.logging.stdout.StdOutImpl #开启sql日志
新增认证服务器配置文件 AuthorizationServerConfig
@Configuration(proxyBeanMethods = false)
public class AuthorizationServerConfig {
* 自定义授权页面
* 使用系统自带的即不用
private static final String CUSTOM_CONSENT_PAGE_URI = "/oauth2/consent";
* 自定义UserDetailsService
@Autowired
private UserService userService;
* 使用默认配置进行form表单登录
* OAuth2AuthorizationServerConfiguration.applyDefaultSecurity(http)
@Bean
@Order(Ordered.HIGHEST_PRECEDENCE)
public SecurityFilterChain authorizationServerSecurityFilterChain(HttpSecurity http) throws Exception {
OAuth2AuthorizationServerConfigurer authorizationServerConfigurer = new OAuth2AuthorizationServerConfigurer<>();
authorizationServerConfigurer.authorizationEndpoint(authorizationEndpoint -> authorizationEndpoint.consentPage(CUSTOM_CONSENT_PAGE_URI));
RequestMatcher endpointsMatcher = authorizationServerConfigurer.getEndpointsMatcher();
http
.requestMatcher(endpointsMatcher)
.userDetailsService(userService)
.authorizeRequests(authorizeRequests -> authorizeRequests.anyRequest().authenticated())
.csrf(csrf -> csrf.ignoringRequestMatchers(endpointsMatcher))
.apply(authorizationServerConfigurer);
return http.formLogin(Customizer.withDefaults()).build();
* 注册客户端应用
@Bean
public RegisteredClientRepository registeredClientRepository(JdbcTemplate jdbcTemplate) {
// Save registered client in db as if in-jdbc
RegisteredClient registeredClient = RegisteredClient.withId(UUID.randomUUID().toString())
.clientId("zxg")
.clientSecret("123")
.clientAuthenticationMethod(ClientAuthenticationMethod.CLIENT_SECRET_BASIC)
.authorizationGrantType(AuthorizationGrantType.AUTHORIZATION_CODE)
.authorizationGrantType(AuthorizationGrantType.REFRESH_TOKEN)
.authorizationGrantType(AuthorizationGrantType.CLIENT_CREDENTIALS)
// 回调地址
.redirectUri("http://www.baidu.com")
// scope自定义的客户端范围
.scope(OidcScopes.OPENID)
.scope("message.read")
.scope("message.write")
// client请求访问时需要授权同意
.clientSettings(ClientSettings.builder().requireAuthorizationConsent(true).build())
// token配置项信息
.tokenSettings(TokenSettings.builder()
// token有效期100分钟
.accessTokenTimeToLive(Duration.ofMinutes(100L))
// 使用默认JWT相关格式
.accessTokenFormat(OAuth2TokenFormat.SELF_CONTAINED)
// 开启刷新token
.reuseRefreshTokens(true)
// refreshToken有效期120分钟
.refreshTokenTimeToLive(Duration.ofMinutes(120L))
.idTokenSignatureAlgorithm(SignatureAlgorithm.RS256).build()
.build();
// Save registered client in db as if in-memory
JdbcRegisteredClientRepository registeredClientRepository = new JdbcRegisteredClientRepository(jdbcTemplate);
registeredClientRepository.save(registeredClient);
return registeredClientRepository;
* 授权服务:管理OAuth2授权信息服务
@Bean
public OAuth2AuthorizationService authorizationService(JdbcTemplate jdbcTemplate, RegisteredClientRepository registeredClientRepository) {
return new JdbcOAuth2AuthorizationService(jdbcTemplate, registeredClientRepository);
* 授权确认信息处理服务
@Bean
public OAuth2AuthorizationConsentService authorizationConsentService(JdbcTemplate jdbcTemplate, RegisteredClientRepository registeredClientRepository) {
return new JdbcOAuth2AuthorizationConsentService(jdbcTemplate, registeredClientRepository);
* 加载JWK资源
* JWT:指的是 JSON Web Token,不存在签名的JWT是不安全的,存在签名的JWT是不可窜改的
* JWS:指的是签过名的JWT,即拥有签名的JWT
* JWK:既然涉及到签名,就涉及到签名算法,对称加密还是非对称加密,那么就需要加密的 密钥或者公私钥对。此处我们将 JWT的密钥或者公私钥对统一称为 JSON WEB KEY,即 JWK。
@Bean
public JWKSource jwkSource() {
RSAKey rsaKey = JwksUtils.generateRsa();
JWKSet jwkSet = new JWKSet(rsaKey);
return (jwkSelector, securityContext) -> jwkSelector.select(jwkSet);
* 配置 OAuth2.0 提供者元信息
@Bean
public ProviderSettings providerSettings() {
return ProviderSettings.builder().issuer("http://127.0.0.1:9000").build();
新增Security的配置文件WebSecurityConfig
@Configuration
@EnableWebSecurity(debug = true) //开启Security
public class WebSecurityConfig {
@Autowired
private ApplicationProperties properties;
* 设置加密方式
@Bean
public PasswordEncoder passwordEncoder() {
// // 将密码加密方式采用委托方式,默认以BCryptPasswordEncoder方式进行加密,兼容ldap,MD4,MD5等方式
// return PasswordEncoderFactories.createDelegatingPasswordEncoder();
// 此处我们使用明文方式 不建议这样
return NoOpPasswordEncoder.getInstance();
* 使用WebSecurity.ignoring()忽略某些URL请求,这些请求将被Spring Security忽略
@Bean
WebSecurityCustomizer webSecurityCustomizer() {
return new WebSecurityCustomizer() {
@Override
public void customize(WebSecurity web) {
// 读取配置文件application.security.excludeUrls下的链接进行忽略
web.ignoring().antMatchers(properties.getSecurity().getExcludeUrls().toArray(new String[]{}));
* 针对http请求,进行拦截过滤
* CookieCsrfTokenRepository进行CSRF保护的工作方式:
* 1.客户端向服务器发出GET请求,例如请求主页
* 2.Spring发送 GET 请求的响应以及 Set-cookie 标头,其中包含安全生成的XSRF令牌
@Bean
public SecurityFilterChain httpSecurityFilterChain(HttpSecurity httpSecurity) throws Exception {
httpSecurity
authorizeRequests.antMatchers("/login").permitAll()
//使用默认登录页面
//.formLogin(withDefaults())
//设置form登录,设置且放开登录页login
.formLogin(fromlogin -> fromlogin.loginPage("/login").permitAll())
// Spring Security CSRF保护
.csrf(csrfToken -> csrfToken.csrfTokenRepository(new CookieCsrfTokenRepository()))
// //开启认证服务器的资源服务器相关功能,即需校验token
// .oauth2ResourceServer()
// .accessDeniedHandler(new SimpleAccessDeniedHandler())
// .authenticationEntryPoint(new SimpleAuthenticationEntryPoint())
// .jwt()
return httpSecurity.build();
新增读取application配置的类 ApplicationProperties
* 此步主要是获取配置文件中配置的白名单,可自行舍去或自定义实现其他方式
@Data
@Component
@ConfigurationProperties("application")
public class ApplicationProperties {
private final Security security = new Security();
@Data
public static class Security {
private Oauth2 oauth2;
private List excludeUrls = new ArrayList<>();
@Data
public static class Oauth2 {
private String issuerUrl;
新增 JwksUtils 类和 KeyGeneratorUtils
,这两个类作为JWT对称加密
public final class JwksUtils {
private JwksUtils() {
* 生成RSA加密key (即JWK)
public static RSAKey generateRsa() {
// 生成RSA加密的key
KeyPair keyPair = KeyGeneratorUtils.generateRsaKey();
// 公钥
RSAPublicKey publicKey = (RSAPublicKey) keyPair.getPublic();
// 私钥
RSAPrivateKey privateKey = (RSAPrivateKey) keyPair.getPrivate();
// 构建RSA加密key
return new RSAKey.Builder(publicKey)
.privateKey(privateKey)
.keyID(UUID.randomUUID().toString())
.build();
* 生成EC加密key (即JWK)
public static ECKey generateEc() {
// 生成EC加密的key
KeyPair keyPair = KeyGeneratorUtils.generateEcKey();
// 公钥
ECPublicKey publicKey = (ECPublicKey) keyPair.getPublic();
// 私钥
ECPrivateKey privateKey = (ECPrivateKey) keyPair.getPrivate();
// 根据公钥参数生成曲线
Curve curve = Curve.forECParameterSpec(publicKey.getParams());
// 构建EC加密key
return new ECKey.Builder(curve, publicKey)
.build();
* 生成HmacSha256密钥
public static OctetSequenceKey generateSecret() {
SecretKey secretKey = KeyGeneratorUtils.generateSecretKey();
return new OctetSequenceKey.Builder(secretKey)
.build();
class KeyGeneratorUtils {
private KeyGeneratorUtils() {
* 生成RSA密钥
static KeyPair generateRsaKey() {
KeyPair keyPair;
try {
KeyPairGenerator keyPairGenerator = KeyPairGenerator.getInstance("RSA");
keyPairGenerator.initialize(2048);
keyPair = keyPairGenerator.generateKeyPair();
} catch (Exception ex) {
throw new IllegalStateException(ex);
return keyPair;
* 生成EC密钥
static KeyPair generateEcKey() {
EllipticCurve ellipticCurve = new EllipticCurve(
new ECFieldFp(
new BigInteger("115792089210356248762697446949407573530086143415290314195533631308867097853951")),
new BigInteger("115792089210356248762697446949407573530086143415290314195533631308867097853948"),
new BigInteger("41058363725152142129326129780047268409114441015993725554835256314039467401291"));
ECPoint ecPoint = new ECPoint(
new BigInteger("48439561293906451759052585252797914202762949526041747995844080717082404635286"),
new BigInteger("36134250956749795798585127919587881956611106672985015071877198253568414405109"));
ECParameterSpec ecParameterSpec = new ECParameterSpec(
ellipticCurve,
ecPoint,
new BigInteger("115792089210356248762697446949407573529996955224135760342422259061068512044369"),
1);
KeyPair keyPair;
try {
KeyPairGenerator keyPairGenerator = KeyPairGenerator.getInstance("EC");
keyPairGenerator.initialize(ecParameterSpec);
return keyPair;
* 生成HmacSha256密钥
static SecretKey generateSecretKey() {
SecretKey hmacKey;
try {
hmacKey = KeyGenerator.getInstance("HmacSha256").generateKey();
return hmacKey;
新建 ConsentController
,编写登录和认证页面的跳转
如果在上面没有使用自定义的登录和授权页面,下面的跳转方法按需舍去
@Slf4j
@Controller
public class ConsentController {
private final RegisteredClientRepository registeredClientRepository;
private final OAuth2AuthorizationConsentService authorizationConsentService;
public ConsentController(RegisteredClientRepository registeredClientRepository,
OAuth2AuthorizationConsentService authorizationConsentService) {
this.registeredClientRepository = registeredClientRepository;
this.authorizationConsentService = authorizationConsentService;
@ResponseBody
@GetMapping("/favicon.ico")
public String faviconico(){
return "favicon.ico";
@GetMapping("/login")
public String loginPage(){
return "login";
@GetMapping(value = "/oauth2/consent")
public String consent(Principal principal, Model model,
@RequestParam(OAuth2ParameterNames.CLIENT_ID) String clientId,
@RequestParam(OAuth2ParameterNames.SCOPE) String scope,
@RequestParam(OAuth2ParameterNames.STATE) String state) {
// Remove scopes that were already approved
Set scopesToApprove = new HashSet<>();
Set previouslyApprovedScopes = new HashSet<>();
RegisteredClient registeredClient = this.registeredClientRepository.findByClientId(clientId);
OAuth2AuthorizationConsent currentAuthorizationConsent =
this.authorizationConsentService.findById(registeredClient.getId(), principal.getName());
Set authorizedScopes;
if (currentAuthorizationConsent != null) {
authorizedScopes = currentAuthorizationConsent.getScopes();
} else {
authorizedScopes = Collections.emptySet();
for (String requestedScope : StringUtils.delimitedListToStringArray(scope, " ")) {
if (authorizedScopes.contains(requestedScope)) {
previouslyApprovedScopes.add(requestedScope);
} else {
scopesToApprove.add(requestedScope);
model.addAttribute("clientId", clientId);
model.addAttribute("state", state);
model.addAttribute("scopes", withDescription(scopesToApprove));
model.addAttribute("previouslyApprovedScopes", withDescription(previouslyApprovedScopes));
model.addAttribute("principalName", principal.getName());
return "consent";
private static Set withDescription(Set scopes) {
Set scopeWithDescriptions = new HashSet<>();
for (String scope : scopes) {
scopeWithDescriptions.add(new ScopeWithDescription(scope));
return scopeWithDescriptions;
public static class ScopeWithDescription {
private static final String DEFAULT_DESCRIPTION = "UNKNOWN SCOPE - We cannot provide information about this permission, use caution when granting this.";
private static final Map scopeDescriptions = new HashMap<>();
static {
scopeDescriptions.put(
"message.read",
"This application will be able to read your message."
"message.write",
"This application will be able to add new messages. It will also be able to edit and delete existing messages."
"other.scope",
"This is another scope example of a scope description."
public final String scope;
public final String description;
ScopeWithDescription(String scope) {
this.scope = scope;
this.description = scopeDescriptions.getOrDefault(scope, DEFAULT_DESCRIPTION);
新建 UserController
,User,UserService等标准的自定义用户业务,此处仅放出UserServiceImpl
@RequiredArgsConstructor
@Slf4j
@Component
class UserServiceImpl implements UserService {
private final UserMapper userMapper;
@Override
public UserDetails loadUserByUsername(String username) throws UsernameNotFoundException {
User user = userMapper.selectOne(new LambdaQueryWrapper().eq(User::getUsername,username));
return new org.springframework.security.core.userdetails.User(username, user.getPassword(), new ArrayList<>());
启动项目,如下图
认证服务器整体结构图
pom.xml引入资源服务器相关依赖
<dependency>
<artifactId>spring-boot-starter-oauth2-resource-serverartifactId>
dependency>
<dependency>
dependency>
新增配置文件 application.yaml
server:
port: 9003
spring:
application:
security:
oauth2:
resourceserver:
jwt:
feign:
client:
config:
default: #配置超时时间
connect-timeout: 10000
read-timeout: 10000
新增资源服务器配置文件 ResourceServerConfiguration
@Configuration
@EnableGlobalMethodSecurity(prePostEnabled = true) //开启鉴权服务
public class ResourceServerConfiguration {
@Bean
// 所有请求都进行拦截
httpSecurity.authorizeRequests().anyRequest().authenticated();
// 关闭session
httpSecurity.sessionManagement().disable();
// 配置资源服务器的无权限,无认证拦截器等 以及JWT验证
httpSecurity.oauth2ResourceServer()
.jwt();
新增相关无认证无权限统一拦截回复 SimpleAccessDeniedHandler
和 SimpleAuthenticationEntryPoint
* 携带了token 而且token合法 但是权限不足以访问其请求的资源 403
* @author zxg
public class SimpleAccessDeniedHandler implements AccessDeniedHandler {
@Override
public void handle(HttpServletRequest request, HttpServletResponse response, AccessDeniedException accessDeniedException) throws IOException, ServletException {
response.setStatus(HttpServletResponse.SC_FORBIDDEN);
response.setCharacterEncoding("utf-8");
response.setContentType(MediaType.APPLICATION_JSON_VALUE);
ObjectMapper objectMapper = new ObjectMapper();
String resBody = objectMapper.writeValueAsString(SingleResultBundle.failed("无权访问"));
PrintWriter printWriter = response.getWriter();
printWriter.print(resBody);
printWriter.flush();
printWriter.close();
* 在资源服务器中 不携带token 或者token无效 401
* @author zxg
@Slf4j
public class SimpleAuthenticationEntryPoint implements AuthenticationEntryPoint {
@Override
public void commence(HttpServletRequest request, HttpServletResponse response, AuthenticationException authException) throws IOException, ServletException {
if (response.isCommitted()){
return;
Throwable throwable = authException.fillInStackTrace();
String errorMessage = "认证失败";
if (throwable instanceof BadCredentialsException){
errorMessage = "错误的客户端信息";
}else {
Throwable cause = authException.getCause();
if (cause instanceof JwtValidationException) {
log.warn("JWT Token 过期,具体内容:" + cause.getMessage());
errorMessage = "无效的token信息";
} else if (cause instanceof BadJwtException){
log.warn("JWT 签名异常,具体内容:" + cause.getMessage());
} else if (cause instanceof AccountExpiredException){
errorMessage = "账户已过期";
} else if (cause instanceof LockedException){
errorMessage = "账户已被锁定";
// } else if (cause instanceof InvalidClientException || cause instanceof BadClientCredentialsException){
// response.getWriter().write(JSON.toJSONString(SingleResultBundle.failed(401,"无效的客户端")));
// } else if (cause instanceof InvalidGrantException || cause instanceof RedirectMismatchException){
// response.getWriter().write(JSON.toJSONString(SingleResultBundle.failed("无效的类型")));
// } else if (cause instanceof UnauthorizedClientException) {
// response.getWriter().write(JSON.toJSONString(SingleResultBundle.failed("未经授权的客户端")));
} else if (throwable instanceof InsufficientAuthenticationException) {
String message = throwable.getMessage();
if (message.contains("Invalid token does not contain resource id")){
errorMessage = "未经授权的资源服务器";
}else if (message.contains("Full authentication is required to access this resource")){
errorMessage = "缺少验证信息";
}else {
errorMessage = "验证异常";
response.setStatus(HttpServletResponse.SC_UNAUTHORIZED);
String resBody = objectMapper.writeValueAsString(SingleResultBundle.failed(errorMessage));
新增 ResourceController
进行接口测试
@Slf4j
@RestController
public class ResourceController {
* 测试Spring Authorization Server,测试权限
@PreAuthorize("hasAuthority('SCOPE_message.read')")
@GetMapping("/getTest")
public String getTest(){
return "getTest";
* 默认登录成功跳转页为 / 防止404状态
* @return the map
@GetMapping("/")
public Map index() {
return Collections.singletonMap("msg", "login success!");
@GetMapping("/getResourceTest")
public SingleResultBundle getResourceTest() {
return SingleResultBundle.success("这是resource的测试方法 getResourceTest()");
启动项目,效果如下
项目总体结构如下
#调用 /oauth2/authorize ,获取code
http://127.0.0.1:9000/oauth2/authorize?client_id=zxg&response_type=code&scope=message.read&redirect_uri=http://www.baidu.com
#会判断是否登录,若没有,则跳转到登录页面,如下图1
#登录完成后,会提示是否授权,若没有,则跳转到授权界面,如下图2
#授权成功后,跳转到回调地址,并带上code,如图3
打开postman,进行获取access_token
#访问 /oauth2/token 地址
#在Authorization中选择Basic Auth模式,填入对应客户端,其会在header中生成Authorization,如下图右侧
返回结果如下
调用ResourceController
中的接口,测试token是否生效
源码下载地址
- https://gitee.com/rjj521/authorization-server-learn
至此,spring-authorization-server
的基础使用已完成,总体上和原Spring Security OAuth
大差不差,个别配置项不同。期间在网上搜寻了很多资料,然后进行整合,因此文中存在与其他网上教程相同代码,如有争议,请联系我删除改正,谢谢。
审核编辑 :李倩
