STM32单片机的启动文件及FLASH分配
控制/MCU
1938人已加入
STM32的启动文件
STM32作为一款单片机,它的启动方式很简单,即当Boot配置了从内部Flash启动模式之后,一上电程序就会从0x8000000地址处开始执行文件,因此我们在使用Keil设置程序起始地址的时候,需要将这个Flash地址设置成0x8000000,只有将这个地址设置成0x8000000,生成的hex文件才可以被正常烧录到此地址,单片机上电之后才可以正常启动。而如果使用J-Flash工具烧写Hex文件时,这个地址会自动根据Hex文件解析出来。然而如果当你烧写二进制Bin文件时,还需要手动将单片机的起始地址制定出来,关于Hex文件和Bin文件的异同点,这个又是可以长篇大论一番了,我们下次特别写文章来讲。
bootloader
图1 Keil设置起始地址和空间
STM32启动文件
;********************* (C) COPYRIGHT 2017 STMicroelectronics ********************
;* File Name          : startup_stm32l151xb.s
;* Author             : MCD Application Team
;* Description        : STM32L151XB Devices vector for MDK-ARM toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR
;*                        address.
;*                      - Configure the system clock
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the Cortex-M3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* Copyright (c) 2017 STMicroelectronics. All rights reserved.
;* This software component is licensed by ST under BSD 3-Clause license,
;* the "License"; You may not use this file except in compliance with the
;* License. You may obtain a copy of the License at:
;*                        opensource.org/licenses/BSD-3-Clause
;* <<< Use Configuration Wizard in Context Menu >>>
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; <h> Stack Configuration
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; h>
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; h>
Heap_Size       EQU     0x00000200
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp              ; Top of Stack
                DCD     Reset_Handler             ; Reset Handler
                DCD     NMI_Handler               ; NMI Handler
                DCD     HardFault_Handler         ; Hard Fault Handler
                DCD     MemManage_Handler         ; MPU Fault Handler
                DCD     BusFault_Handler          ; Bus Fault Handler
                DCD     UsageFault_Handler        ; Usage Fault Handler
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     SVC_Handler               ; SVCall Handler
                DCD     DebugMon_Handler          ; Debug Monitor Handler
                DCD     0                         ; Reserved
                DCD     PendSV_Handler            ; PendSV Handler
                DCD     SysTick_Handler           ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler           ; Window Watchdog
                DCD     PVD_IRQHandler            ; PVD through EXTI Line detect
                DCD     TAMPER_STAMP_IRQHandler   ; Tamper and Time Stamp
                DCD     RTC_WKUP_IRQHandler       ; RTC Wakeup
                DCD     FLASH_IRQHandler          ; FLASH
                DCD     RCC_IRQHandler            ; RCC
                DCD     EXTI0_IRQHandler          ; EXTI Line 0
                DCD     EXTI1_IRQHandler          ; EXTI Line 1
                DCD     EXTI2_IRQHandler          ; EXTI Line 2
                DCD     EXTI3_IRQHandler          ; EXTI Line 3
                DCD     EXTI4_IRQHandler          ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler  ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler  ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler  ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler  ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler  ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler  ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler  ; DMA1 Channel 7
                DCD     ADC1_IRQHandler           ; ADC1
                DCD     USB_HP_IRQHandler         ; USB High Priority
                DCD     USB_LP_IRQHandler         ; USB Low  Priority
                DCD     DAC_IRQHandler            ; DAC
                DCD     COMP_IRQHandler           ; COMP through EXTI Line
                DCD     EXTI9_5_IRQHandler        ; EXTI Line 9..5
                DCD     0                         ; Reserved
                DCD     TIM9_IRQHandler           ; TIM9
                DCD     TIM10_IRQHandler          ; TIM10
                DCD     TIM11_IRQHandler          ; TIM11
                DCD     TIM2_IRQHandler           ; TIM2
                DCD     TIM3_IRQHandler           ; TIM3
                DCD     TIM4_IRQHandler           ; TIM4
                DCD     I2C1_EV_IRQHandler        ; I2C1 Event
                DCD     I2C1_ER_IRQHandler        ; I2C1 Error
                DCD     I2C2_EV_IRQHandler        ; I2C2 Event
                DCD     I2C2_ER_IRQHandler        ; I2C2 Error
                DCD     SPI1_IRQHandler           ; SPI1
                DCD     SPI2_IRQHandler           ; SPI2
                DCD     USART1_IRQHandler         ; USART1
                DCD     USART2_IRQHandler         ; USART2
                DCD     USART3_IRQHandler         ; USART3
                DCD     EXTI15_10_IRQHandler      ; EXTI Line 15..10
                DCD     RTC_Alarm_IRQHandler      ; RTC Alarm through EXTI Line
                DCD     USB_FS_WKUP_IRQHandler    ; USB FS Wakeup from suspend
                DCD     TIM6_IRQHandler           ; TIM6
                DCD     TIM7_IRQHandler           ; TIM7
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset handler routine
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
        IMPORT  __main
        IMPORT  SystemInit
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                [WEAK]
                B       .
                ENDP
HardFault_Handler                PROC
                EXPORT  HardFault_Handler          [WEAK]
                B       .
                ENDP
MemManage_Handler                PROC
                EXPORT  MemManage_Handler          [WEAK]
                B       .
                ENDP
BusFault_Handler                PROC
                EXPORT  BusFault_Handler           [WEAK]
                B       .
                ENDP
UsageFault_Handler                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                [WEAK]
                B       .
                ENDP
DebugMon_Handler                PROC
                EXPORT  DebugMon_Handler           [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler             [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler            [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler            [WEAK]
                EXPORT  PVD_IRQHandler             [WEAK]
                EXPORT  TAMPER_STAMP_IRQHandler    [WEAK]
                EXPORT  RTC_WKUP_IRQHandler        [WEAK]
                EXPORT  FLASH_IRQHandler           [WEAK]
                EXPORT  RCC_IRQHandler             [WEAK]
                EXPORT  EXTI0_IRQHandler           [WEAK]
                EXPORT  EXTI1_IRQHandler           [WEAK]
                EXPORT  EXTI2_IRQHandler           [WEAK]
                EXPORT  EXTI3_IRQHandler           [WEAK]
                EXPORT  EXTI4_IRQHandler           [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
                EXPORT  ADC1_IRQHandler            [WEAK]
                EXPORT  USB_HP_IRQHandler          [WEAK]
                EXPORT  USB_LP_IRQHandler          [WEAK]
                EXPORT  DAC_IRQHandler             [WEAK]
                EXPORT  COMP_IRQHandler            [WEAK]
                EXPORT  EXTI9_5_IRQHandler         [WEAK]
                EXPORT  TIM9_IRQHandler            [WEAK]
                EXPORT  TIM10_IRQHandler           [WEAK]
                EXPORT  TIM11_IRQHandler           [WEAK]
                EXPORT  TIM2_IRQHandler            [WEAK]
                EXPORT  TIM3_IRQHandler            [WEAK]
                EXPORT  TIM4_IRQHandler            [WEAK]
                EXPORT  I2C1_EV_IRQHandler         [WEAK]
                EXPORT  I2C1_ER_IRQHandler         [WEAK]
                EXPORT  I2C2_EV_IRQHandler         [WEAK]
                EXPORT  I2C2_ER_IRQHandler         [WEAK]
                EXPORT  SPI1_IRQHandler            [WEAK]
                EXPORT  SPI2_IRQHandler            [WEAK]
                EXPORT  USART1_IRQHandler          [WEAK]
                EXPORT  USART2_IRQHandler          [WEAK]
                EXPORT  USART3_IRQHandler          [WEAK]
                EXPORT  EXTI15_10_IRQHandler       [WEAK]
                EXPORT  RTC_Alarm_IRQHandler       [WEAK]
                EXPORT  USB_FS_WKUP_IRQHandler     [WEAK]
                EXPORT  TIM6_IRQHandler            [WEAK]
                EXPORT  TIM7_IRQHandler            [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
RTC_WKUP_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_IRQHandler
USB_HP_IRQHandler
USB_LP_IRQHandler
DAC_IRQHandler
COMP_IRQHandler
EXTI9_5_IRQHandler
TIM9_IRQHandler
TIM10_IRQHandler
TIM11_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
;************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE*****
首先让我们来看下STM32启动文件,当MCU上电复位之后,整个程序会跳转到以0x8000000为基址,偏移0的地址处,即还是0x8000000。但是STM32的0x8000000地址处存放的并不是整个芯片的第一句指令,而是整个芯片的堆栈初始化程序,如图2所示。
bootloader
图2 0x8000000偏移0地址处的堆栈初始化程序指针
由于STM32的地址空间都是4字节对齐的,因此这个栈顶指针的存放空间为4字节,所以STM32复位之后跳转的地址应该是0x8000000基址偏移4个字节,即0x8000004。如同3所示。
bootloader
图3 STM32复位跳转地址
图3中的程序非常浅显易懂,第136和137行,即将程序跳转到SystemInit处,这是个C语言函数,定义在“system_stm32l1xx.c”文件里,它的目的就是对中断向量表起始地址进行指定,也就是图2中的“__Vector”处。当然CM3内核和CM0内核关于SCB(系统控制块)的定义有些许差别,CM0不在本文讨论中,但是CM3和CM4的中断向量表映射机制还是很相似的。
bootloader
图4 SystemInit函数映射中断向量表
图4中我们可以看到,SCB中关于Vector的地址是通过符号FLASH_BASE和VECT_TAB_OFFSET计算出来的,我们可以找到关于它们的定义,如图5所示。
bootloader
图5 FLASH_BASE和VECT_TAB_OFFSET的定义
通过图5中的计算,正好可以得出整个中断向量表被映射到了0x8000000地址处。
STM32的FLASH分配
前面的大段文章内容中,频繁提及了一个关键的数值,即0x8000000,那么这个0x8000000到底是怎么来的呢?这个数值并不是平白无故拍脑袋想出来的。之前我们就说过,ARM体系的存储器结构是其一大特色,而这个0x8000000正是整个STM32内置FLASH的起始地址。我们随便打开一份STM32的数据手册,在存储器章节里面就可以看到STM32全部的存储器定义。如图6所示。
bootloader
图6 STM32内部FLASH的起始地址
STM32的Bootloader思路
抛开所有的Bootloader高级功能来说,我们设计STM32 Bootloader的主要目的有两个,第一个为方便程序烧写和更新,第二个目前是从Bootloader程序中跳转(引导)用户的应用程序。这两个目的中,对于Bootloader来说程序跳转尤其重要,因为程序跳转成不成功将会严重影响整个用户程序的运行状态。因而,怎么跳,何时跳,跳到哪里,则是下篇文章的着重讨论部分。
前面一个FLASH烧写,可以根据自己的特殊要求来定制,只要严格安装HEX文件指定的地址和数据的关系,一般不会出错。
本文分析了STM32启动时比较重要的一些定义和函数跳转,下篇将会开始着手设计一个STM32 Bootloader。
