Linux下OpenCV,出现错误:
ASSERT false in file qasciikey.cpp, line 501
可能是OpenCV的版本有问题,需要重新安装一下:
pip install -i https://pypi.tuna.tsinghua.edu.cn/simple opencv-python
pip install -i https://pypi.tuna.tsinghua.edu.cn/simple opencv-contrib-python
如果出现提示:
Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/anaconda3/lib/python3.7/site-packages/opencv_contrib_python-4.1.0.25.dist-info'
Consider using the --user option or check the permissions.
表示需要使用--user:
pip install --user -i https://pypi.tuna.tsinghua.edu.cn/simple opencv-contrib-python
学习更多编程知识,请关注我的公众号:
[代码的路]
