STM32G0开发笔记:多通道ADC与DMA的使用
使用Platformio平台的libopencm3开发框架来开发STM32G0,以下为多通道ADC与DMA的使用。
1 新建项目
  • 建立adc_dma项目
在PIO的Home页面新建项目,项目名称adc_dma,选择开发板为 MonkeyPi_STM32_G070RB,开发框架选择libopencm3;
  • 项目建立完成后在src目录下新建main.c主程序文件;
  • 修改下载和调试方式,这里开发板使用的是DAPLink仿真器,因此修改platformio.ini文件如下:
1upload_protocol = cmsis-dap
2debug_tool = cmsis-dap
2 编写程序
2.1 ADC 设置
这里设置PA0、PA1、PA2、PA3四个引脚为ADC:
1static void adc_setup(void)
 2{
 3    rcc_periph_clock_enable(RCC_ADC);
 4    rcc_periph_clock_enable(RCC_GPIOA);
 5
 6    gpio_mode_setup(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO0);
 7    gpio_mode_setup(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO1);
 8    gpio_mode_setup(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO2);
 9    gpio_mode_setup(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO3);
10
11    adc_power_off(ADC1);
12    adc_set_clk_prescale(ADC1, ADC_CCR_PRESC_DIV2);
13    adc_set_single_conversion_mode(ADC1);
14    adc_set_right_aligned(ADC1);
15    adc_set_sample_time_on_all_channels(ADC1, ADC_SMPTIME_160DOT5);
16
17    uint8_t channel_array[16] = {0};
18    channel_array[0] = 0;
19    channel_array[1] = 1;
20    channel_array[2] = 2;
21    channel_array[3] = 3;
22    adc_set_regular_sequence(ADC1, ADC_CHAN_CNT, channel_array);
23    adc_enable_dma_circular_mode(ADC1);
24    adc_set_resolution(ADC1, ADC_CFGR1_RES_12_BIT);
25    adc_power_on(ADC1);
26
27    /* Wait for ADC starting up. */
28    delay_ms(10);
29}
2.2 DMA配置
1static void dma_setup(void *data, int size)
 2{
 3    dma_channel_reset(DMA1, DMA_CHANNEL1);
 4    dma_set_peripheral_address(DMA1, DMA_CHANNEL1, (uint32_t)&ADC_DR(ADC1));
 5    dma_set_memory_address(DMA1, DMA_CHANNEL1, (uint32_t)data);
 6    dma_set_number_of_data(DMA1, DMA_CHANNEL1, size);
 7    dma_set_read_from_peripheral(DMA1, DMA_CHANNEL1);
 8    dma_enable_memory_increment_mode(DMA1, DMA_CHANNEL1);
 9    dma_set_peripheral_size(DMA1, DMA_CHANNEL1, DMA_CCR_PSIZE_16BIT);
10    dma_set_memory_size(DMA1, DMA_CHANNEL1, DMA_CCR_MSIZE_16BIT);
11    dma_enable_circular_mode(DMA1, DMA_CHANNEL1);
12    dma_enable_transfer_complete_interrupt(DMA1, DMA_CHANNEL1);
13    dma_enable_channel(DMA1, DMA_CHANNEL1);
14
15    dmamux_reset_dma_channel(DMAMUX1, DMA_CHANNEL1);
16    dmamux_set_dma_channel_request(DMAMUX1, DMA_CHANNEL1, DMAMUX_CxCR_DMAREQ_ID_ADC);
17}
主要是设置DMA的外设地址为ADC数据寄存器 ADC_DR;并设置内存地址为定义的buff,size为需要缓存的数据大小:
1#define ADC_CHAN_CNT        4
2#define ADC_FILETER_SIZE    32
3
4int16_t adc_values[ADC_FILETER_SIZE*ADC_CHAN_CNT];
2.3 ADC配置为DMA读取和Timer触发
  • 定时器设置
1void tim3_setup(void)
 2{
 3    /* Enable TIM3 clock. */
 4    rcc_periph_clock_enable(RCC_TIM3);
 5
 6    /* Enable TIM3 interrupt. */
 7    nvic_enable_irq(NVIC_TIM3_IRQ);
 8
 9    /* Reset TIM3 peripheral to defaults. */
10    rcc_periph_reset_pulse(RST_TIM3);
11
12    /* Timer global mode:
13     * - No divider
14     * - Alignment edge
15     * - Direction up
16     * (These are actually default values after reset above, so this call
17     * is strictly unnecessary, but demos the api for alternative settings)
18     */
19    timer_set_mode(TIM3, TIM_CR1_CKD_CK_INT,
20                   TIM_CR1_CMS_EDGE, TIM_CR1_DIR_UP);
21
22    /*
23     * Please take note that the clock source for STM32 timers
24     * might not be the raw APB1/APB2 clocks.  In various conditions they
25     * are doubled.  See the Reference Manual for full details!
26     * In our case, TIM3 on APB1 is running at double frequency, so this
27     * sets the prescaler to have the timer run at 5kHz
28     */
29    timer_set_prescaler(TIM3, 64-1);
30
31    /* Disable preload. */
32    timer_disable_preload(TIM3);
33    timer_continuous_mode(TIM3);
34
35    timer_set_period(TIM3, 20000-1); //100Hz
36
37    timer_set_master_mode(TIM3, TIM_CR2_MMS_UPDATE);
38
39    timer_enable_irq(TIM3, TIM_DIER_UIE);
40}
41
42void tim3_enable_counter(bool en)
43{
44    if(en){
45        timer_enable_counter(TIM3);
46    }else{
47        timer_disable_counter(TIM3);
48    }
49}
50
51void tim3_isr(void)
52{
53    if (timer_get_flag(TIM3, TIM_SR_UIF)) {
54
55        /* Clear compare interrupt flag. */
56        timer_clear_flag(TIM3, TIM_SR_UIF);
57    }
58}
  • DMA设置和Timer触发
1    rcc_periph_clock_enable(RCC_DMA);
 2    nvic_set_priority(NVIC_DMA1_CHANNEL1_IRQ, 3);
 3    nvic_enable_irq(NVIC_DMA1_CHANNEL1_IRQ);
 4
 5    adc_setup();
 6
 7    dma_setup(adc_values, ADC_CHAN_CNT*ADC_FILETER_SIZE);
 8
 9    adc_enable_overrun_interrupt(ADC1);
10
11    adc_enable_dma(ADC1);
12
13    ADC_CFGR1(ADC1) = (ADC_CFGR1(ADC1) & ~(0x3<<10)) | (0x1<<10);    // Hardware trigger detection on the rising edge
14    ADC_CFGR1(ADC1) = (ADC_CFGR1(ADC1) & ~ADC_CFGR1_EXTSEL) | (3<1_EXTSEL_SHIFT);    // toggle by tim3
15
16    tim3_setup();
17
18    adc_start_conversion_regular(ADC1);
19
21    tim3_enable_counter(true);
22
23    delay_ms(100);
DMA中断时候即准备好读取ADC数据,因此在DMA中断中先把定时器关闭,读取数据后再次打开:
1void dma1_channel1_isr(void)
 2{
 3
 4    if ((DMA1_ISR &DMA_ISR_TCIF1) != 0) {
 5        DMA1_IFCR |= DMA_IFCR_CTCIF1;
 6    }
 7
 8    tim3_enable_counter(false);
 9
10}
2.4 ADC读取
1void adc_sample(void)
 2{
 3    uint32_t sum_val1 = 0;
 4    uint32_t sum_val2 = 0;
 5    uint32_t sum_val3 = 0;
 6    uint32_t sum_val4 = 0;
 7
 8    for(int i=0; i9        sum_val1 += adc_values[ADC_CHAN_CNT*i + 0];
10        sum_val2 += adc_values[ADC_CHAN_CNT*i + 1];
11        sum_val3 += adc_values[ADC_CHAN_CNT*i + 2];
12        sum_val4 += adc_values[ADC_CHAN_CNT*i + 3];
13    }
14
15    uint32_t filter_val1 = sum_val1/ADC_FILETER_SIZE;
16    uint32_t filter_val2 = sum_val2/ADC_FILETER_SIZE;
17    uint32_t filter_val3 = sum_val3/ADC_FILETER_SIZE;
18    uint32_t filter_val4 = sum_val4/ADC_FILETER_SIZE;
19
20    printf("adc:%d  %d  %d  %d\\r\\n", filter_val1, filter_val2, filter_val3, filter_val4);
21
22    tim3_enable_counter(true);
23}
读取时候按照通道的顺序从buff中取出,这里做了简单的过滤;
3 烧写测试
将程序烧写到开发板,然后打开串口可以看到四个ADC通道的数据,在PA0/PA1/PA3/PA4四个引脚连接不同电压可以看到变化:
adc
评论(0)
发评论
lff1802 2023-07-03
0 回复 举报
你好博主,能否麻烦你发一份这个历程的源代码,邮箱:260322233@qq.com,我参考这个历程配置的最后输出的数据一直为0,仿真发现一直进不去dma的中断,定时器中断是可以的,谢谢 收起回复
