Linux下的网络HOOK实现
嵌入式操作系统
58人已加入
最近疯狂的研究Linux的种种功能,也颇有心得,这里讲述一下Linux下的Net的Hook,使用net的Hook可以实现很多很多非常底层的功能,比如过滤报文,做防火墙,做代理等等。
  Now,Let's Go!
  使用的是Linux 2.6.19.1的内核代码。
  首先是 在./Source/net/netfilter/core.c文件中的函数 nf_register_hook:
  static DEFINE_SPINLOCK(nf_hook_lock);
  int nf_register_hook(struct nf_hook_ops *reg)
  struct list_head *i;
  spin_lock_bh(&nf_hook_lock);
  list_for_each(i, &nf_hooks[reg->pf][reg->hooknum]) {
  if (reg->priority < ((struct nf_hook_ops *)i)->priority)
  break;
  list_add_rcu(?->list, i->prev);
  spin_unlock_bh(&nf_hook_lock);
  synchronize_net();
  return 0;
  EXPORT_SYMBOL(nf_register_hook);
  void nf_unregister_hook(struct nf_hook_ops *reg)
  list_del_rcu(?->list);
  synchronize_net();
  EXPORT_SYMBOL(nf_unregister_hook);
  int nf_register_hooks(struct nf_hook_ops *reg, unsigned int n)
  unsigned int i;
  int err = 0;
  for (i = 0; i < n; i++) {
  err = nf_register_hook(?[i]);
  if (err)
  goto err;
  return err;
  err:
  if (i > 0)
  nf_unregister_hooks(reg, i);
  return err;
  EXPORT_SYMBOL(nf_register_hooks);
  void nf_unregister_hooks(struct nf_hook_ops *reg, unsigned int n)
  unsigned int i;
  nf_unregister_hook(?[i]);
  EXPORT_SYMBOL(nf_unregister_hooks);
  上面分别是四个函数:
  nf_register_hook,nf_unregister_hook,nf_register_hooks,nf_unregister_hooks.
  功能是注册Hooks函数
  输入的参数是struct nf_hook_ops *reg。
  下面让我们看一个验证ARP报文的Hook代码,以表示我们如何使用Hook函数实现这种功能。
  unsigned int arphook_snd(unsigned int hooknum,struct sk_buff **skb,const struct net_device *in, const struct net_device *out,int (*okfn)(struct sk_buff*))
  struct arphdr *arp;
  struct net_device *dev;
  unsigned char * arp_ptr;
  unsigned char *sha, *tha;
  u32 sip,tip;
  unsigned short arpop;
  unsigned int status=NF_DROP;
  dev=(*skb)->dev;
  arp = (*skb)->nh.arph;
  arp_ptr= (unsigned char *)(arp+1);
  sha = arp_ptr;
  arp_ptr += dev->addr_len;
  memcpy(&sip, arp_ptr, 4);
  arp_ptr += 4;
  tha = arp_ptr;
  memcpy(&tip, arp_ptr, 4);
  arpop=ntohs(arp->ar_op);
  if(!check_ip(&tip,WABLOCK)) /*check block list*/
  if(arpop==1) /*sending ARP request*/
  if(!check_ip(&tip,WAARP)) /*if not in list add it*/
  add_ip(&tip,WAARP);
  status=NF_ACCEPT;
  return(status);
  下面是初始化一些参数的函数
  static int arpstar_init(void)
  arphkrcv.hook=arphook_rcv; /*arp receive hook*/
  arphkrcv.hooknum=NF_ARP_IN;
  arphkrcv.pf=NF_ARP;
  arphkrcv.priority=NF_IP_PRI_FIRST;
  nf_register_hook(&arphkrcv);
  arphksnd.hook=arphook_snd; /*arp send hook*/
  arphksnd.hooknum=NF_ARP_OUT;
  arphksnd.pf=NF_ARP;
  arphksnd.priority=NF_IP_PRI_FIRST;
  nf_register_hook(&arphksnd);
  iphkrcv.hook=iphook_rcv; /*ip rcv hook*/
  iphkrcv.hooknum=NF_IP_LOCAL_IN;
  iphkrcv.pf=PF_INET;
  iphkrcv.priority=NF_IP_PRI_FIRST;
  nf_register_hook(&iphkrcv);
  tmac=strtomac(trustedmac);
  trustip=strtou32(trustedip);
  run_timer(0);
  return(0);
  下面是函数结束时候的清理工作
  static void arpstar_exit(void)
  nf_unregister_hook(&arphkrcv); /*clean up time*/
  nf_unregister_hook(&arphksnd);
  nf_unregister_hook(&iphkrcv);
  del_timer(&watimer);
  free_list();
  kfree(tmac);
  我们知道Windows下面也有Hook的功能,但是要Hook到Net的底层,一般是使用NDIS来实现,但是Linux就提供了如此强大的功能,让我们不得不佩服Linux的伟大。几天的研究让我越来越对Linux的推崇!而且我想Linux在嵌入式方面的应用会更加广泛!
  这几天也在看一些嵌入式的资料,想想,这个世界真的可以因为Linux的改变而改变,相对来说Windows的代码保密性会失去很多嵌入式方面的开发者的!
