| 属性 | 参数值 |
| 型号 | MAX5069BAUE+ |
| 制造商 | Maxim Integrated |
| Mfr | Maxim Integrated |
| 系列 | - |
| 包装 | Tube |
| 零件状态 | Active |
| 输出类型 | Transistor Driver |
| 功能 | Step-Down |
| 输出 配置 | Positive, Isolation Capable |
| Topology | Buck |
| Number of 输出s | 1 |
| 输出 Phases | 1 |
| 电压 - 供电 (Vcc/Vdd) | 10.8V ~ 24V |
| 频率 - Switching | 50kHz ~ 2.5MHz |
| Duty Cycle (最大) | 100% |
| Synchronous Rectifier | No |
| 时钟 Sync | Yes |
| 串行接口 | - |
| Control 特性 | Dead Time Control, Enable, 频率 Control |
| 工作温度 | -40°C ~ 125°C (TJ) |
| 安装类型 | Surface Mount |
| 封装/外壳 | 16-TSSOP (0.173"", 4.40mm Width) Exposed Pad |
| 供应商器件封装 | 16-TSSOP-EP |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
