基于pic单片机的模拟I2C通信
控制/MCU
1933人已加入
;                      Copyright (C) 1997 by Innovatus
; This code may be distributed and used freely provided that this
; copyright notice stays intact and that any modifications are noted.
; For more information about Innovatus: http://www.innovatus.com
;    File Name: i2c_low.asm
;       Author: Alan G. Smith
;      Purpose: This code is borrowed from Microchip with all of the fancy
;               stuff taken out.
InitI2CBusMaster
TxmtStartBit
   bsf    Bus_Busy                       ; on a start condition bus is busy
   bsf    STATUS, RP0                    ; Select page 1
   bsf    _SDA                           ; set SDA high
   bsf    _SCL                           ; clock is high
   call   Delay40uSec                    ; This is necessary for setup time
   bcf    _SDA                           ; This gives a falling edge on SDA while clock is high
   call   Delay47uSec                    ; Necessary for START HOLD time
   return
TxmtStopBit
   bcf    _SCL                           ; clock is low
   bcf    _SDA                           ; set SDA low
   bsf    _SCL                           ; clock is pulled up
   call   Delay40uSec                    ; Setup time for STOP condition
   bsf    _SDA                           ; rising edge on SDA while CLOCK is high
   call   Delay47uSec                    ; makes sure a START isn‘t sent immediately after a STOP
   bcf    Bus_Busy                       ; The bus isn‘t busy anymore
   return
AbortI2C
   call   TxmtStopBit                    ; Send a stop bit
   bsf    Abort                          ; set the abort bit
   return
TxmtSlaveAddr
   movf   SlaveAddr, w                   ; Move slave address to W
   bcf    ACK_Error                      ; reset Acknowledge error bit
   movwf  I2CData                        ; move W to I2C Data
   bcf    I2CData, LSB                   ; Set for write
   btfsc  Slave_RW                       ; If skip then write operation
   bsf    I2CData, LSB                   ; Clear for read
   call   SendData                       ; send the address
   btfss  Txmt_Success                   ; skip if successful
   goto   AddrSendFail                   ; Oops, we failed
   retlw  TRUE                           ; return true
AddrSendFail
   btfss  ACK_Error                      ; was there an error acknowledging
   retlw  FALSE                          ; No, so return 0
   call   TxmtStopBit                    ; Address not acknowleged, so send STOP bit
   retlw  FALSE                          ; Unsuccessful, so return 0
SendData
; We might should make a copy of the data here, the example does but I don‘t see why!!!
   bsf    Txmt_Progress                  ; We are in the middle of transmitting
   bcf    Txmt_Success                   ; reset success bit
   movlw  0x08
   movwf  I2CBitCount                    ; Set I2C Bit Count to 8
TxmtNextBit:
   bcf    _SCL                           ; Set clock Low
   rlf    I2CData, F                     ; MSB First, Note that I2CData is Destroyed
   bcf    _SDA                           ; Set clock based on what the MSB is
   btfsc  STATUS,C                       ; Was the MSB a 1
   bsf    _SDA                           ; Nope set it high
   call   Delay47uSec                    ; guarantee min LOW TIME tLOW & Setup time
   bsf    _SCL                           ; set clock high
   call   Delay40uSec                    ; guarantee min HIGH TIME tHIGH
   decfsz I2CBitCount, F                 ; are we done yet
   goto   TxmtNextBit                    ; nope, send the next bit
; Check For Acknowledge
   bcf    _SCL                           ; reset clock
   bsf    _SDA                           ; Release SDA line for Slave to pull down
   bsf    _SCL                           ; clock for slave to ACK
   bcf    STATUS, RP0                    ; Select PAGE 0 to test SDA pin
   btfsc  SdaPin                         ; SDA should be pulled low by slave if OK
   goto   TxmtErrorAck                   ; Uh oh, slave isn‘t behaving (or isn‘t there)
   bsf    STATUS, RP0                    ; Select PAGE 1
   bcf    Txmt_Progress                  ; reset progress bit in Bus Status
   bsf    Txmt_Success                   ; Transmission successful
   bcf    ACK_Error                      ; ACK OK
   return
TxmtErrorAck
   bsf    STATUS,RP0                     ; select page 1
   bsf    _SDA                           ; tristate SDA
   bsf    _SCL                           ; tristate SCL
   bcf    Txmt_Success                   ; Transmission NOT successful
   bsf    ACK_Error                      ; No ACK From Slave
   return
GetData
   bsf    Rcv_Progress                   ; set Bus status for txmt progress
   bcf    Rcv_Success                    ; reset status bit
   movlw  0x08
   movwf  I2CBitCount
RcvNextBit
   bsf    STATUS, RP0                    ; page 1 for TRIS manipulation
   bcf    _SCL                           ; lower clock
   bcf    _SDA                           ; lower data line
   call   Delay47uSec                    ; guarantee min LOW TIME tLOW & setup time
   bsf    _SCL                           ; clock high, data sent by slave
   bcf    STATUS, RP0                    ; select page 0 to read Ports
   bcf    STATUS, C                      ; 0 out Status
   btfsc  SdaPin                         ; Check state of pin
   bsf    STATUS, C                      ; Pin was high, set status
   rlf    I2CData, F                     ; left Shift data (MSB first)
   decfsz I2CBitCount, F                 ; Are we done yet
   goto   RcvNextBit                     ; Nope, go get the next one
; Generate ACK bit if not last byte to be read,
; if last byte Gennerate NACK ; do not send ACK on last byte, main routine will send a STOP bit
   bsf    STATUS, RP0                    ; Page 1 for TRIS manipulation
   bcf    _SCL                           ; pull SCL low
   bcf    _SDA                           ; ACK by pulling SDA low
   btfsc  Last_Byte_Rcv                  ; Is it the last byte to receive
   bsf    _SDA                           ; If so, send NACK by setting SDA high
   bsf    _SCL                           ; Raise Clock back up
RcvEnd:
   bcf    Rcv_Progress                   ; reset bit in Bus Status
   bsf    Rcv_Success                    ; transmission successful
   return
Delay47uSec:
   movlw ((_47uS_Delay-5)/3 + 1)         ; move delay into W
DlyK
   movwf DelayCount                      ; move what is in W to DelayCount
   decfsz   DelayCount, F                ; Decrement DelayCount
   goto  $-1                             ; Loop until 0
   return                                ; return
Delay40uSec:
   movlw ((_40uS_Delay-8)/3 + 1)         ; move delay into W
   goto  DlyK                            ; goto DlyK loop
以下为测试程序(pic16f84)
;                        All Rights Reserved.
; For more information about Innovatus: http://www.innovatu.com
s
;    File Name: testI2C.asm
;      Purpose: This is testing out the I2C code.
    LIST P=16f84, F=INHX8M, C=100, N=59
#include "p16f84.inc"
XTAL_FREQ       equ     10000000        ; the crystal frequency we are using
ClkOut          equ     XTAL_FREQ / 4   ; the number of cycles per second
_40uS_Delay set   (ClkOut/250000)
_47uS_Delay set   (ClkOut/212766)
_50uS_Delay set   (ClkOut/200000)
#define SclPin  PORTA, 0                ; Pin for SCL (I2C)
#define SdaPin  PORTA, 1                ; Pin for SDA (I2C)
#define _SCL    TRISA, 0                ; How do we toggle SCL
#define _SDA    TRISA, 1                ; How do we toggle SDA
#define MSB   7
#define LSB   0
#define TRUE  1
#define FALSE 0
InitTrisA       equ     0x07            ; The Initial state to TRIS port A.
#define  Bus_Busy      BusStatus,0
#define  Abort         BusStatus,1
#define  Txmt_Progress BusStatus,2
#define  Rcv_Progress  BusStatus,3
#define  Txmt_Success  BusStatus,4
#define  Rcv_Success   BusStatus,5
#define  Fatal_Error   BusStatus,6
#define  ACK_Error     BusStatus,7
#define  Slave_RW      BusControl,0
#define  Last_Byte_Rcv BusControl,1
#define  SlaveActive   BusControl,2
CBLOCK     0x0C                        ; I2C Ram needed
   BusStatus                            ; The I2C Status register
   BusControl                           ; The I2C Control register
   I2CBitCount                          ; Number of bits left to send (or receive)
   I2CData                              ; Data (note: This is DESTROYED when sending)
   SlaveAddr                            ; Slave Address
ENDC
CBLOCK
   DelayCount                           ; used to figure out precise time delays
ENDC
   org 0                                 ; Reset Vector
   goto   start                          ; Goto Start
start
   bcf    INTCON, GIE                    ; Turn off interrupts in this critical part of code!
   bcf    STATUS, RP0                    ; Select Page 0 of registers
   movlw  0x0C                           ; Make sure there are 0‘s on SCL and SDA
   movwf  PORTA                          ; We write 1‘s to TX since 0 is a start bit
   bsf    STATUS, RP0                    ; Select Page 1 of registers
   movlw  InitTrisA                      ; Load W with the value for TRIS A
   movwf  TRISA                          ; movw the value from W into TRIS A
;*************** DEBUG CODE (let us use LEDs) *******************
   clrf   TRISB
   clrf   BusStatus                      ; Let‘s clear out busStatus before we start
   clrf   BusControl                     ; Let‘s clear out busControl before we start
;*************** TEST CODE *******************
   clrf   PORTB
main
   movlw  0xB0                           ; address of EEPROM
   movwf  SlaveAddr                      ; move into SlaveAddress register
   call   IsSlaveActive                  ; Check and see if the slave is active
   movlw  0xFF                           ; move FF into w (turn all LED‘s on)
   btfss  SlaveActive                    ; If the slave is active, leave it
   movlw  0xAA                           ; We didn‘t find it, turn off half.
   bcf    STATUS, RP0                    ; Select page 0 of registers
   movwf  PORTB                          ; move W to PortB
done                                     ; Game over man!
   goto   done                           ; endless loop
IsSlaveActive
   bcf    Slave_RW                       ; set for write operation
   call   TxmtStartBit                   ; Transmit Start Bit
   call   TxmtSlaveAddr                  ; Transmit Slave Address
   bcf    SlaveActive                    ; Assume not present
   btfss  ACK_Error                      ; skip if NACK, device is not present or not responding
   bsf    SlaveActive                    ; ACK received, device present & listening
   call   TxmtStopBit
   return
#include "i2c_low.asm"
