Free RTOS的任务通知-2
每个任务都有一个32位的通知值,该值在创建任务时初始化为零。
配置相关资源
//为1时开启任务通知
#define configUSE_TASK_NOTIFICATIONS 1
发送
BaseType_t xTaskNotifyGive( TaskHandle_t xTaskToNotify );
参数
xTaskToNotify:被通知并使其通知值递增的任务句柄
接收
uint32_t ulTaskNotifyTake( BaseType_t xClearCountOnExit, TickType_t xTicksToWait );
参数
xClearCountOnExit:是否需要清零
xTicksToWait:等待时间
实验程序
#include "stm32f10x.h"
#include
#include "FreeRTOS.h"
#include "task.h"
void KEY_Init(void)
  GPIO_InitTypeDef GPIO_InitStructure; //定义结构体变量
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOE,ENABLE);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;     //选择你要设置的IO口
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPD;//下拉输入
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;     //设置传输速率
  GPIO_Init(GPIOA,&GPIO_InitStructure);      /* 初始化GPIO */
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3|GPIO_Pin_2|GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;  //上拉输入
  GPIO_Init(GPIOE,&GPIO_InitStructure);
void USART_init(uint32_t bound)
  GPIO_InitTypeDef GPIO_InitStruct;   //定义GPIO结构体变量
  USART_InitTypeDef USART_InitStruct;   //定义串口结构体变量
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);   //使能GPIOC的时钟
  GPIO_InitStruct.GPIO_Pin=GPIO_Pin_9;   //配置TX引脚
  GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AF_PP;   //配置PA9为复用推挽输出
  GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;   //配置PA9速率
  GPIO_Init(GPIOA,&GPIO_InitStruct);   //GPIO初始化函数
  GPIO_InitStruct.GPIO_Pin=GPIO_Pin_10;   //配置RX引脚
  GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IN_FLOATING;   //配置PA10为浮空输入
  GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;   //配置PA10速率
  USART_InitStruct.USART_Mode=USART_Mode_Tx|USART_Mode_Rx;   //发送接收模式
  USART_InitStruct.USART_Parity=USART_Parity_No;   //无奇偶校验
  USART_InitStruct.USART_BaudRate=bound;   //波特率
  USART_InitStruct.USART_StopBits=USART_StopBits_1;   //停止位1位
  USART_InitStruct.USART_WordLength=USART_WordLength_8b;   //字长8位
  USART_InitStruct.USART_HardwareFlowControl=USART_HardwareFlowControl_None;   //无硬件数据流控制
  USART_Init(USART1,&USART_InitStruct);   //串口初始化函数
  USART_Cmd(USART1,ENABLE);   //使能USART1
int fputc(int ch,FILE *f)   //printf重定向函数
  USART_SendData(USART1,(uint8_t)ch);   //发送一字节数据
  while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);   //等待发送完成
  return ch;
#define START_TASK_PRIO 1      //任务优先级
#define START_STK_SIZE 128      //任务堆栈大小
TaskHandle_t StartTask_Handler;   //任务句柄
void Start_Task(void *pvParameters);//任务函数
#define Send_TASK_PRIO 2       //任务优先级
#define Send_STK_SIZE 50       //任务堆栈大小
TaskHandle_t SendTask_Handler;     //任务句柄
void Send_Task(void *p_arg);     //任务函数
#define Read_TASK_PRIO 3       //任务优先级
#define Read_STK_SIZE 50       //任务堆栈大小
TaskHandle_t ReadTask_Handler;   //任务句柄
void Read_Task(void *p_arg);     //任务函数
int main( void )
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//设置系统中断优先级分组 4
  KEY_Init();
  USART_init(9600);
   printf("车位默认值为0个,按下KEY1申请车位,按下KEY2释放车位!nn");
  //创建开始任务
  xTaskCreate(
    (TaskFunction_t )Start_Task,     //任务函数
    (const char* )"Start_Task",     //任务名称
    (uint16_t )START_STK_SIZE,       //任务堆栈大小
    (void* )NULL,             //传递给任务函数的参数
    (UBaseType_t )START_TASK_PRIO,     //任务优先级
    (TaskHandle_t* )&StartTask_Handler  //任务句柄
  vTaskStartScheduler();  //开启调度
//开始任务函数
  taskENTER_CRITICAL();   //进入临界区
  //创建 Send_Task 任务
  xTaskCreate(
    (TaskFunction_t )Send_Task,
    (const char* )"Send_Task",
    (uint16_t )Send_STK_SIZE,
    (void* )NULL,
    (UBaseType_t )Send_TASK_PRIO,
    (TaskHandle_t* )&SendTask_Handler
  //创建 Read_Task 任务
  xTaskCreate(
    (TaskFunction_t )Read_Task,
    (const char* )"Read_Task",
    (uint16_t )Read_STK_SIZE,
    (void* )NULL,
    (UBaseType_t )Read_TASK_PRIO,
    (TaskHandle_t* )&ReadTask_Handler
  vTaskDelete(StartTask_Handler); //删除开始任务
  taskEXIT_CRITICAL();   //退出临界区
//Send_Task 任务函数
void Send_Task(void *pvParameters)
  BaseType_t Return = pdPASS;
  while(1)
    if(GPIO_ReadInputDataBit( GPIOE, GPIO_Pin_4)==0)
      Return = xTaskNotifyGive(ReadTask_Handler);//发送任务通知
      if ( pdPASS == Return )
        printf( "KEY2被按下,释放1个停车位n" );
    vTaskDelay(50);
//Read_Task 任务函数
void Read_Task(void *pvParameters)
  uint32_t Return = 0;
  while(1)
    if(GPIO_ReadInputDataBit( GPIOE, GPIO_Pin_3)==0)
       Return = ulTaskNotifyTake(pdFALSE,0);//不清零
      if(Return > 0)
        printf( "KEY1被按下,成功申请到停车位,当前车位为 %d n", Return - 1);
      else
        printf( "KEY1被按下,车位已经没有了,请按KEY2释放车位n" );
    vTaskDelay(50);
实验现象
初始化
--END--
