Django的简单应用示例
Django是python的Web应用框架,并于2008年发布了第一个版本,下面我们先来学习Django的简单应用示例。
一、 安装Django
  1. 在Home目录下,新建pdemo目录,并在该目录下安装Django框架
root@ubuntu:/home# mkdir pdemo
root@ubuntu:/home/pdemo# apt-get install python-django -y
Django
2.验证Django框架安装是否成功
root@ubuntu:/home/pdemo# python
Python 2.7.12 (default, Nov 20 2017, 18:23:56)
[GCC 5.4.0 20160609] on linux2
Type "help", "copyright", "credits" or "license" for more information.
import django
django.get_version()
'1.8.7'
** exit()**
3.安装可能遇到的问题:
E: Unable to locate package sqllite3 stack
解决方法:
apt-get update && apt-get upgrade
apt-get install sqlite3
二、创建项目
1.新建Django项目pdemo1,并查看所建的文件清单
root@ubuntu:/home/pdemo# django-admin startproject pdemo1
root@ubuntu:/home/pdemo# tree
└── pdemo1 --项目
├── manage.py *--命令行工具*
└── pdemo1
    ├── __init__.py
  • --该文件为空,代表pdemo1是一个python包*
      ├── settings.py
  • --配置文件*
      ├── urls.py
         *--前台请求到后台处理逻辑的映射*
      └── wsgi.py
         -*-Web服务器入口*
2 directories, 5 files
三、启动服务器
1.启动服务器
root@ubuntu:/home/pdemo/pdemo1#python manage.py runserver 0.0.0.0:8000
Performing system checks...
System check identified no issues (0 silenced).
You have unapplied migrations; your app may not work properly until they are applied.
Run 'python manage.py migrate' to apply them.
October 01, 2018 - 00:32:32
Django version 1.8.7, using settings 'pdemo1.settings'
Starting development server at http://0.0.0.0:8000/
Quit the server with CONTROL-C.
2.打开浏览器,输入127.0.0.1:8000,如呈现如下信息,则启动成功:
3.查看文件清单信息:
root@ubuntu:/home/pdemo/pdemo1# tree .
├── db.sqlite3
├── manage.py
└── pdemo1
├── __init__.py
├── __init__.pyc
├── settings.py
├── settings.pyc
├── urls.py
├── urls.pyc
├── wsgi.py
└── wsgi.pyc
1 directory, 10 files
四、创建应用
1.新建templates目录,并在该目录下创建hello.html
root@ubuntu:/home/pdemo/pdemo1/pdemo1#** mkdir templates**
root@ubuntu:/home/pdemo/pdemo1/pdemo1# vi hello.html
<form action="/hello-post" method="post">
    {% csrf_token %}
    <input type="text" name="who">
    <input type="submit" value="Submit">
form>
<p>{{ wname }}p>
注:
l {% csrf_token %}:csrf(Cross Site Request Forgery),为Django提供的防伪装提交请求的功能。
l {{ wname }}为页面显示的变量,该变量值对应后台传过来的数据。
2.打开setting.py,修改DIRS的值。
root@ubuntu:/home/pdemo/pdemo1/pdemo1# **vi ** setting .py
TEMPLATES = [
{'DIRS': [BASE_DIR+"/pdemo1"+"/templates",], --修改该值
3.增加后台处理逻辑,新建Hello.py文件
root@ubuntu:/home/pdemo/pdemo1/pdemo1# **vi ** hello .py
from django.shortcuts import render
from django.views.decorators import csrf
def hello_post(request):
ctx ={}
if request.POST:
    ctx['wname'] = request.POST['who']
return render(request, "hello.html", ctx)
4.增加前台请求和后台处理逻辑映射,修改url.py文件
root@ubuntu:/home/pdemo/pdemo1/pdemo1# vi urls.py
增加:
from pdemo1 import hello
url(r'^hello-post$', hello.hello_post),
5.打开浏览器,输入127.0.0.1:8000/hello-post
Django
