STM32入门学习笔记之USB读卡器实验2
(2)usb_prop.c文件修改
原文件
PC
修改后文件
PC
(3)memory.h文件修改
PC
(4)mass_mal.h文件修改
PC
(5)memory.c文件修改
PC
(6)usb_bot.c文件修改
PC
(7)mass_mal.c文件重写
#include "platform_config.h"
#include "mass_mal.h"
#include "sdio_sdcard.h"
#include "w25q128.h"
long long Mass_Memory_Size[ MAX_LUN+1 ] ;
u32 Mass_Block_Size[ MAX_LUN+1 ] ;
u32 Mass_Block_Count[ MAX_LUN+1 ] ;
uint16_t MAL_Init( uint8_t lun )
u16 Status=MAL_OK ;
   switch( lun )
          case 0:    break;
          case 1:    break;
          default:return MAL_FAIL ;
   return Status ;
uint16_t MAL_Write(uint8_t lun, uint64_t Memory_Offset, uint32_t *Writebuff, uint16_t Transfer_Length)
u8 STA ;
   switch( lun )
          //磁盘0为 SPI FLASH盘
          case 0:
                 STA = 0 ;
                 W25QXX_Write( ( u8* )Writebuff, Memory_Offset, Transfer_Length ) ;
                 break ;
          //磁盘1为SD卡
          case 1:
                 STA = SD_WriteDisk( ( u8* )Writebuff, Memory_Offset>>9, Transfer_Length>>9 ) ;
                 break ;
          default:
                 return MAL_FAIL ;
   if( STA!=0 )
          return MAL_FAIL ;
   return MAL_OK ;
uint16_t MAL_Read( uint8_t lun, uint64_t Memory_Offset, uint32_t *Readbuff, uint16_t Transfer_Length )
u8 STA ;
   switch( lun )
          //磁盘0为 SPI FLASH盘
          case 0 :
                 STA = 0 ;
W25QXX_Read( ( u8* )Readbuff, Memory_Offset, Transfer_Length ) ;
break;
          //磁盘1为SD卡
          case 1 :
STA = SD_ReadDisk( ( u8* )Readbuff, Memory_Offset>>9, Transfer_Length>>9 ) ;
break;
   if( STA!=0 )
          return MAL_FAIL ;
   return MAL_OK ;
uint16_t MAL_GetStatus( uint8_t lun )
switch( lun )
          case 0:return MAL_OK;
          case 1:return MAL_OK;
          default:return MAL_FAIL;
