Qt学习笔记之数据库结构设计7
四、导出EXCEL表
最后,就是导出excel了,创建一个新的类
odbcexcel.h文件
#ifndef ODBCEXCEL_H
#define ODBCEXCEL_H
#include
#include
#include
#include
#include
#include
class OdbcExcel
public:
    OdbcExcel();
    //将数据保存为excel
    bool static save(QString filePath,QStringList headers,QList data,QString comment="");
    //将QTableView保存为excel
    bool static saveFromTable(QString filePath,QTableView *tableView,QString comment="");
    //获取错误信息
    QString static getError(){return error;}
private:
    void static printError( QSqlError error);
    bool static insert(QSqlQuery& query, QString sheetName, QStringList slist);
    static QString error;
#endif // ODBCEXCEL_H
odbcexcel.c
#include "odbcexcel.h"
#include
OdbcExcel::OdbcExcel()
QString OdbcExcel::error;
bool OdbcExcel::save(QString filePath, QStringList headers, QList data,QString comment)
    QString sheetName = "Sheet1";
    QSqlDatabase db = QSqlDatabase::addDatabase("QODBC","excelexport");
    if( !db.isValid())
        error="数据库驱动异常";
        return false;   //! type error
    QString dsn = "DRIVER={Microsoft Excel Driver (*.xls)};"
            "DSN='';FIRSTROWHASNAMES=1;READONLY=FALSE;CREATE_DB=\\""+filePath+"\\";DBQ="+filePath;
    db.setDatabaseName( dsn);
    // open connection
    if( !db.open())
        error="无法打开数据库";
        return false;  //! db error
    QSqlQuery query(db);
    QString sql;
    // drop the table if it's already exists
    sql = QString("DROP TABLE [%1]").arg(sheetName);
    query.exec( sql);
    //create the table (sheet in Excel file)
    sql = QString("CREATE TABLE [%1] (").arg(sheetName);
    foreach (QString name, headers) {
        sql +=QString("[%1] varchar(200)").arg(name);
        if(name!=headers.last())
            sql +=",";
    sql += ")";
    query.prepare( sql);
    if( !query.exec()) {
        OdbcExcel::printError( query.lastError());
        db.close();
        return false;
    foreach (QStringList slist, data) {
        insert(query,sheetName,slist);
    if(!comment.isEmpty())
        QStringList slist;
        slist<for(int i=0,n=headers.size()-1;i<n;i++)
            slist<<"";
    db.close();
    return true;
bool OdbcExcel::saveFromTable(QString filePath,QTableView *tableView, QString comment)
    QAbstractItemModel* model=tableView->model();
    const int column=model->columnCount();
    const int row=model->rowCount();
    //header
    QStringList headers;
    for(int i=0;i//隐藏列
        if(tableView->isColumnHidden(i))
            continue;
        headers<headerData(i,Qt::Horizontal).toString();
    //data
    QStringList list;
    QList data;
    for(int i=0;iif(model->index(i,0).data().isNull())
            continue;
        list.clear();
        for(int j=0;j//隐藏列
            if(tableView->isColumnHidden(j))
                continue;
            list<index(i,j).data().toString();
        data<<list;
    return OdbcExcel::save(filePath,headers,data,comment);
void OdbcExcel::printError(QSqlError error)
    QString sqlerr = error.text();
    error=sqlerr;
    qCritical()<query, QString sheetName, QStringList slist)
    QString sSql = QString("INSERT INTO [%1] VALUES(").arg( sheetName);
    for(int i=0,n=slist.size();i<n;i++)
        sSql+=QString(":%1").arg(i);
        if(i!=n-1)
            sSql+=",";
        else
            sSql+=")";
    query.prepare( sSql);
        query.bindValue(QString(":%1").arg(i),slist.at(i));
        return false;
    return true;
然后在UI界面中创建一个导出按键,并在按键按下时调用数据库导出类来完成导出excel功能
//导出
void sqlite_sqlquerymodel_edit::on_pushButton_export_clicked()
    QFileDialog dlg;
    dlg.setAcceptMode(QFileDialog::AcceptSave);
    //  Qt 5
    dlg.setDirectory(QStandardPaths::writableLocation(QStandardPaths::DesktopLocation));
    //  Qt 4
    //  dlg.setDirectory(QDesktopServices::storageLocation(QDesktopServices::DesktopLocation));
    dlg.setNameFilter("*.xls");
    dlg.selectFile(QDate::currentDate().toString("yyyy-MM-dd.xls"));
    if(dlg.exec()!= QDialog::Accepted)
        return;
    QString filePath=dlg.selectedFiles()[0];
    if(OdbcExcel::saveFromTable(filePath,ui->tableView,"注释:无")) {
        QMessageBox::information(this,tr("提示"),tr("保存成功"));
    else{
        QString msg="保存失败!\\n\\r"+OdbcExcel::getError();
        QMessageBox::critical(this,tr("错误"),tr(msg.toUtf8()));
点击导出后,弹出保存文件框保存文件
SQlite
保存成功
SQlite
然后打开excel查看保存的数据跟Qt上的一致
SQlite
OK,Qt操作数据库就到这了。
