python迭代调用内置函数计时比较(下)
1.3 python迭代工具最小计时
timertool.py:
timer_compatible():根据win版、Unix版、python版本选择对应计时函数计算总时间。
mintime():计算每个迭代工具执行的最小时间。
timeiterevn.py:
timeiter_compatible():计算每个迭代工具执行的总时间、平均时间、最小时间。
示例
#timertool.py
import time,sys
reps = 1000
repslist = range(reps)
if sys.version[:3]<'3.3':
   if sys.platform[:3] == 'win':
       timefunc = time.clock
   else:
       timefunc = time.time
else:
   timefunc = time.perf_counter
def trace(*args):
   #print('args={}'.format(args))
   pass
def timer(func,*pargs,**kargs):
   begin = time.perf_counter()
   for i in repslist:
       ret = func(*pargs,**kargs)
   usetime = time.perf_counter() - begin
   return (usetime,ret)
def timer_compatible(func,*pargs,**kargs):
   _reps = kargs.pop('_reps',1000)
   trace(func,pargs,kargs,_reps)
   repslist = range(_reps)
   begin = timefunc()
   for i in repslist:
   usetime = timefunc() - begin
def mintime(func,*pargs,**kargs):
   _reps = kargs.pop('_reps',50)
   mintime = 2 ** 32
   for i in range(_reps):
      (usetime,ret) = timer_compatible(func,*pargs,_reps=1,**kargs)
       if usetime < mintime:
           mintime = usetime
   return (mintime,ret)
# timeiterevn.py
import sys,timertool
s = '梯阅线条tyxt'*1000
def forloop():
   res = []
   for x in s:
       res.append(ord(x)+1)
   return res
def listComp():
   return [ord(x) for x in s]
def mapCall():
   return list(map(lambda x:ord(x)+1,s))
def genExpr():
   return list(ord(x)+1 for x in s)
def genFunc():
   def gen():
       for x in s:
           yield ord(x)+1
   return list(gen())
def commstr(s):
   commstr = '# '+s
   print(commstr)
functp = (forloop,listComp,mapCall,genExpr,genFunc)
timetp = (timertool.timer_compatible,timertool.mintime)
commstr('-'*33)
commstr(str(sys.version))
def timeiter():
   reslist=[]
   for test in funcList:
       usetime,result = timertool.timer(test)
       reslist.append((test.__name__,usetime,result[0],result[-1],len(result)))
   commstr('-'*33)
   reslistsort=sorted(reslist,key = lambda x:x[1])
   for L in reslistsort:
       #print(commstr+'%-9s:%.5f=>[%s....%s....%s]'%(L[0],L[1],L[2],L[3],L[4]))
       commstr('%-9s:%.5f=>[%s....%s....%s]'%(L[0],L[1],L[2],L[3],L[4]))
   commstr('-'*33)
def timeiter_compatible():
   _reps = 1000
   commstr('-'*33)
   for ttp in timetp:
       reslist=[]
       commstr('<{}>'.format(ttp.__name__))
       for ftp in functp:
           usetime,result = ttp(ftp,_reps=_reps)
           reslist.append((ftp.__name__,usetime,result[0],result[-1],len(result)))
       commstr('-'*33)
       if ttp.__name__ == 'timer_compatible':
           commstr('总时间排序')
       else:
           commstr('最小时间排序')
       commstr('-'*33)
       commstr('-'*33)
           commstr('平均时间排序')
           commstr('-'*33)
               commstr('%-9s:%.5f=>[%s....%s....%s]'%(L[0],(L[1]/_reps),L[2],L[3],L[4]))
           commstr('-'*33)
# 3.7.8 (tags/v3.7.8:4b47a5b6ba, Jun 28 2020, 07:55:33) [MSC v.1916 32 bit (Intel)]
# 总时间排序
# listComp :0.52310=>[26799....116....8000]
# genFunc :0.92414=>[26800....117....8000]
# genExpr :0.94791=>[26800....117....8000]
# forloop :1.01522=>[26800....117....8000]
# mapCall :1.12953=>[26800....117....8000]
# 平均时间排序
# listComp :0.00052=>[26799....116....8000]
# genFunc :0.00092=>[26800....117....8000]
# genExpr :0.00095=>[26800....117....8000]
# forloop :0.00102=>[26800....117....8000]
# mapCall :0.00113=>[26800....117....8000]
# 最小时间排序
# listComp :0.00039=>[26799....116....8000]
# genFunc :0.00065=>[26800....117....8000]
# genExpr :0.00066=>[26800....117....8000]
# forloop :0.00072=>[26800....117....8000]
# mapCall :0.00073=>[26800....117....8000]
1.4 time计时
python的time模块对Windows、Unix、python版本提供不同计时方法。
NO 系统版本 对应方法
1 Windows time.clock()
2 Unix time.time()
3 =python3.8 time.perf_counter(),python3.3开始支持
两次调用之间的时间差用于计时。
示例
>>> import time
>>> begin = time.clock()
>>> end = time.clock()
>>> use=end - begin
>>> begin,end,use
(782.9449924, 793.3414938, 10.39650139999992)
>>> begin = time.time()
>>> end = time.time()
>>> use = end - begin
>>> begin,end,use
(1674368678.73148, 1674368685.6409733, 6.909493446350098)
>>> end = time.perf_counter()
>>> use = end - begin
>>> begin,end,use
(899.3102242, 908.7626699, 9.452445699999998)
1.5 sys平台版本
python通过sys模块获取平台版本信息。
NO 属性 描述
1 sys.version python版本
2 sys.platform 系统平台
示例
>>> import sys
>>> v=sys.version
>>> pf=sys.platform
>>> v
'3.7.8 (tags/v3.7.8:4b47a5b6ba, Jun 28 2020, 07:55:33) [MSC v.1916 32 bit (Intel)]'
>>> pf
'win32'
>>> v[:3],pf[:3]
('3.7', 'win')
1.6 sorted按键排序
用法
sorted(iterable, /, *, key=None, reverse=False)
python内置函数sorted(可迭代对象,key)属于迭代工具,按指定key对可迭代对象进行排序。
key:自定义排序函数。
reverse:默认False为升序。
示例
>>> zs={'name':'张三','yuwen':90,'shuxue':100,'english':60}
>>> ls={'name':'李四','yuwen':91,'shuxue':95,'english':85}
>>> ww={'name':'王五','yuwen':80,'shuxue':99,'english':82}
>>> classOne=[zs,ls,ww]
>>> for i,stu in zip(range(1,len(classOneSort)+1),classOneSort):
   zf = stu['yuwen']+stu['shuxue']+stu['english']
   print("总分第{i:0>3}名:{d[name]:>4},语文={d[yuwen]:>3},数学={d[shuxue]:>3},英语={d[english]:>3},总分={zf:>3}".format(d=stu,zf=zf,i=i))
总分第001名:  李四,语文= 91,数学= 95,英语= 85,总分=271
总分第002名:  王五,语文= 80,数学= 99,英语= 82,总分=261
总分第003名:  张三,语文= 90,数学=100,英语= 60,总分=250
