数据:
MAX324ESA+ 数据手册
| 属性 | 参数值 |
| 型号 | MAX324ESA+ |
| 描述 | IC SWITCH DUAL SPST 8SOIC |
| 制造商 | Maxim Integrated |
| 品牌 | Maxim Integrated |
| 系列 | - |
| 包装 | Tube |
| 供货状态 | Active |
| Switch 电路 | SPST - NC |
| 多路复用器/解复用器 电路 | 1:1 |
| 电路数 | 2 |
| On-State 电阻容差 (最大) | 60Ohm |
| Channel-to-Channel Matching (ΔRon) | 800mOhm |
| 电压 - 供电, Single (V+) | 2.7V ~ 16V |
| 电压 - 供电, Dual (V±) | - |
| Switch Time (Ton, Toff) (最大) | 150ns, 100ns |
| -3db带宽 | - |
| Charge Injection | 1pC |
| Channel 点容 (CS(off), CD(off)) | 9pF, 9pF |
| Current - Leakage (IS(off)) (最大) | 100pA |
| Crosstalk | -85dB @ 1MHz |
| 工作温度 | -40°C ~ 85°C (TA) |
| 安装类型 | Surface Mount |
| 封装 | 8-SOIC (0.154"", 3.90mm Width) |
| 制造商封装 | 8-SOIC |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
