怎么制作网页查询Excel
Excel
一.项目背景
   本项目利用Django Web框架制作一个简易版的网页查询数据,数据源为Excel表格
   数据,通过该项目让大家了解到Django与办公自动化的结合,也给大家拓展一种数据展
示思路。
二.实现过程
1.创建项目
  1)创建项目(django-admin startproject 项目名称)和app(python manage.py startapp myapp)
  2)在settings.py中添加配置信息
  3)启动项目(python manage.py runserver)
Django settings for data_test project.
Generated by 'django-admin startproject' using Django 1.11.4.
For more information on this file, see
https://docs.djangoproject.com/en/1.11/topics/settings/
For the full list of settings and their values, see
https://docs.djangoproject.com/en/1.11/ref/settings/
import os
# Build paths inside the project like this: os.path.join(BASE_DIR, ...)
BASE_DIR = os.path.dirname(os.path.dirname(os.path.abspath(__file__)))
# Quick-start development settings - unsuitable for production
# See https://docs.djangoproject.com/en/1.11/howto/deployment/checklist/
# SECURITY WARNING: keep the secret key used in production secret!
SECRET_KEY = 'w_!tgu=!e^z0i)beg=1(s-7p*t)1-494@w#^j-jb6(^vz$)n!3'
# SECURITY WARNING: don't run with debug turned on in production!
DEBUG = True
ALLOWED_HOSTS = []
# Application definition
INSTALLED_APPS = [
    'django.contrib.admin',
    'django.contrib.auth',
    'django.contrib.contenttypes',
    'django.contrib.sessions',
    'django.contrib.messages',
    'django.contrib.staticfiles',
    #注册app
    'myapp'
MIDDLEWARE = [
    'django.middleware.security.SecurityMiddleware',
    'django.contrib.sessions.middleware.SessionMiddleware',
    'django.middleware.common.CommonMiddleware',
    'django.middleware.csrf.CsrfViewMiddleware',
    'django.contrib.auth.middleware.AuthenticationMiddleware',
    'django.contrib.messages.middleware.MessageMiddleware',
    'django.middleware.clickjacking.XFrameOptionsMiddleware',
ROOT_URLCONF = 'data_test.urls'
TEMPLATES = [
        'BACKEND': 'django.template.backends.django.DjangoTemplates',
         #添加templates模板路径
        'DIRS': [os.path.join(BASE_DIR,'templates')],
        'APP_DIRS': True,
        'OPTIONS': {
            'context_processors': [
                'django.template.context_processors.debug',
                'django.template.context_processors.request',
                'django.contrib.auth.context_processors.auth',
                'django.contrib.messages.context_processors.messages',
WSGI_APPLICATION = 'data_test.wsgi.application'
# Database
# https://docs.djangoproject.com/en/1.11/ref/settings/#databases
DATABASES = {
    'default': {
        'ENGINE': 'django.db.backends.sqlite3',
        'NAME': os.path.join(BASE_DIR, 'db.sqlite3'),
# Password validation
# https://docs.djangoproject.com/en/1.11/ref/settings/#auth-password-validators
AUTH_PASSWORD_VALIDATORS = [
        'NAME': 'django.contrib.auth.password_validation.UserAttributeSimilarityValidator',
        'NAME': 'django.contrib.auth.password_validation.MinimumLengthValidator',
        'NAME': 'django.contrib.auth.password_validation.CommonPasswordValidator',
        'NAME': 'django.contrib.auth.password_validation.NumericPasswordValidator',
# Internationalization
# https://docs.djangoproject.com/en/1.11/topics/i18n/
LANGUAGE_CODE = 'en-us'
TIME_ZONE = 'UTC'
USE_I18N = True
USE_L10N = True
USE_TZ = True
# Static files (CSS, JavaScript, Images)
# https://docs.djangoproject.com/en/1.11/howto/static-files/
#配置静态文件
STATIC_URL = '/static/'
STATICFILES_DIRS = (
    os.path.join(BASE_DIR, "static"),
【注】以上是settings.py文件中代码,有中文注释处是本次项目所添加代码。
Excel
2.获取数据
  1)read_excel读取Excel数据(如下图所示)
  2)前端构建form表单
  3)获取页面传过来的参数
Excel
{% load static %}
{% csrf_token %}
姓名: {% if stu_name %} {%else %} {% endif %}
{{ data|safe }}
【注】以上是test.html文件中代码
from django.shortcuts import render
import  pandas as pd
#获取数据
def get_data(request):
    #读取excel文件
    data=pd.read_excel('test.xlsx')
    #如果请求方式是POST请求
    if request.method=='POST':
        #获取输入值
        value=request.POST.get('name')
        #判断是否为空
        if value=='':
            #如果为空,返回原始数据,并且将前台页面输入置为空
            return render(request, 'test.html', {'data': data.to_html(index=False),'stu_name':''})
        else:
            #查取姓名,此处为模糊查询
            data_query=data[data['姓名'].str.contains(value)]
            #获取数据,将查到的数据和输入框值返回页面
            return render(request,'test.html',{'data':data_query.to_html(index=False),'stu_name':value})
    else:
        #如果是GET请求,直接返回所有数据
        return render(request, 'test.html', {'data':data.to_html(index=False)})
【注】以上是views.py文件中代码
3.展示数据
  1)配置url(如下图)
  2)配置css文件
  2)表格可视化
Excel
.data{
    text-align:center
.data_query{
    align:center
【注】以上是test.css文件中代码
查询前结果展示
Excel
模糊查询后结果展示
Excel
