通过卷积神经网络实现MNIST数据集分类
问题
对比单个全连接网络,在卷积神经网络层的加持下,初始时,整个神经网络模型的性能是否会更好。
方法
模型设计
两层卷积神经网络(包含池化层),一层全连接网络。
  1. 选择 5 x 5 的卷积核,输入通道为 1,输出通道为 10:
    此时图像矩阵经过 5 x 5 的卷积核后会小两圈,也就是4个数位,变成 24 x 24,输出通道为10;
  2. 选择 2 x 2 的最大池化层:
    此时图像大小缩短一半,变成 12 x 12,通道数不变;
  3. 再次经过5 x 5的卷积核,输入通道为 10,输出通道为 20:
    此时图像再小两圈,变成 8*8,输出通道为20;
  4. 再次经过2 x 2的最大池化层:
    此时图像大小缩短一半,变成 4 x 4,通道数不变;
  5. 最后将图像整型变换成向量,输入到全连接层中:
    输入一共有 4 x 4 x 20 = 320个元素,输出为 10.
代码
准备数据集
准备数据集
batch_size = 64
transform = transforms.Compose([
transforms.ToTensor(),
transforms.Normalize((0.1307,), (0.3081,))
train_dataset = datasets.MNIST(root='data’,
train=True,
                          download=True,
                          transform=transform)
train_loader = DataLoader(train_dataset,
shuffle=True,
                     batch_size=batch_size)
test_dataset = datasets.MNIST(root='data',
train=False,
                         download=True,
test_loader = DataLoader(test_dataset,
shuffle=False,
建立模型
class Net(torch.nn.Module):
def init (self):
super(Net, self).__init__()
   self.conv1 = torch.nn.Conv2d(1, 10, kernel_size=5)
   self.conv2 = torch.nn.Conv2d(10, 20, kernel_size=5)
   self.pooling = torch.nn.MaxPool2d(2)
   self.fc = torch.nn.Linear(320, 10)
def forward(self, x):
batch_size = x.size(0)
   x = F.relu(self.pooling(self.conv1(x)))
   x = F.relu(self.pooling(self.conv2(x)))
   x = x.view(batch_size, -1)
   x = self.fc(x)
   return x
model = Net()
device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu")
model.to(device)
构造损失函数+优化器
criterion = torch.nn.CrossEntropyLoss()
optimizer = optim.SGD(model.parameters(), lr=0.01, momentum=0.5)
训练+测试
def train(epoch):
running_loss = 0.0
for batch_idx, data in enumerate(train_loader, 0):
inputs, target = data
   inputs,target=inputs.to(device),target.to(device)
   optimizer.zero_grad()
   outputs = model(inputs)
   loss = criterion(outputs, target)
   loss.backward()
   optimizer.step()
   running_loss += loss.item()
   if batch_idx % 300 == 299:
       print('[%d,%.5d] loss:%.3f' % (epoch + 1, batch_idx + 1, running_loss / 2000))
       running_loss = 0.0
def test():
correct=0
total=0
with torch.no_grad():
for data in test_loader:
       inputs,target=data
       outputs=model(inputs)
       _,predicted=torch.max(outputs.data,dim=1)
       total+=target.size(0)
       correct+=(predicted==target).sum().item()
print('Accuracy on test set:%d %% [%d%d]' %(100*correct/total,correct,total))
if name ==' main ':
for epoch in range(10):
train(epoch)
   test()
运行结果
(1)batch_size:64,训练次数:10
数据集
数据集
(2)batch_size:128,训练次数:10
数据集
(3)batch_size:128,训练次数:10
数据集
结语
对比单个全连接网络,在卷积神经网络层的加持下,初始时,整个神经网络模型的性能显著提升,准确率最低为96%。在batch_size:64,训练次数:100情况下,准确率达到99%。下一阶在平均池化,3*3卷积核,以及不同通道数的情况下,探索对模型性能的影响。
