yum install epel-release
wget https://dl.eff.org/certbot-auto --no-check-certificate
chmod +x certbot-auto
./certbot-auto -n
./certbot-auto certonly --email my@qq.com --agree-tos --no-eff-email --webroot -w /root/html/ -d www.pydict.com
上面命令中的/root/html/路径表示nginx配置中的root目录
如果有多个域名,命令后面继续加 -d 参数就行
证书会有有效期,所以可以弄一个定时任务自动更新证书
0 3 * * * /root/certbot-auto renew –disable-hook-validation –renew-hook “/usr/sbin/nginx -s reload”
这里表示每天凌晨3点更新一遍证书,如果证书没有失效,不会起作用
/usr/sbin/nginx是nginx的实际路径,可以用 which nginx 来定位位置
server {
listen 443 ssl;
server_name pydict.com;
ssl_certificate /etc/letsencrypt/live/www.pydict.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/www.pydict.com/privkey.pem;
ssl_ciphers ECDHE-RSA-AES256-SHA384:AES256-SHA256:RC4:HIGH:!MD5:!aNULL:!eNULL:!NULL:!DH:!EDH:!AESGCM;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
access_log logs/access.log main;
gzip on;
gzip_types text/plain application/javascript application/x-javascript text/css application/xml text/javascript application/x-httpd-php image/jpeg image/gif image/png application/vnd.ms-fontobject application/x-font-ttf font/ttf font/opentype font/x-woff image/svg+xml;
error_page 404 /404.html;
error_page 500 502 503 504 /50x.html;
client_max_body_size 75M;
root /root/html/otfsenter.github.io;
location / {
index index.html;
server {
listen 80;
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
charset utf-8;
location / {
return 301 https://www.pydict.com$request_uri;
这个http的配置中,配置了一个301,这样就算方位http也会重定向到https
