华为路由器实现单臂路由的编程分享
通信网络
672人已加入
实验拓扑
华为
SWH1配置
The device is running!
sys
Enter system view, return user view with Ctrl+Z.
[Huawei]sys swh
[swh]vlan batch 10 20
[swh]int g0/0/1
[swh-GigabitEthernet0/0/1]port link-type acc
[swh-GigabitEthernet0/0/1]port default vlan 10
[swh-GigabitEthernet0/0/1]int g0/0/2
[swh-GigabitEthernet0/0/2]port link-type acc
[swh-GigabitEthernet0/0/2]port default vlan 20
[swh-GigabitEthernet0/0/2]q
[swh]dis vlan
The total number of vlans is : 3
U: Up;         D: Down;         TG: Tagged;         UT: Untagged;
MP: Vlan-mapping;               ST: Vlan-stacking;
#: ProtocolTransparent-vlan;    *: Management-vlan; 网络技术干货圈
VID  Type    Ports
1    common  UT:GE0/0/3(D)      GE0/0/4(D)      GE0/0/5(D)      GE0/0/6(D)
                GE0/0/7(D)      GE0/0/8(D)      GE0/0/9(D)      GE0/0/10(D)
                GE0/0/11(D)     GE0/0/12(D)     GE0/0/13(D)     GE0/0/14(D)
                GE0/0/15(D)     GE0/0/16(D)     GE0/0/17(D)     GE0/0/18(D)
                GE0/0/19(D)     GE0/0/20(D)     GE0/0/21(D)     GE0/0/22(D)
                GE0/0/23(D)     GE0/0/24(U)
10   common  UT:GE0/0/1(U)
20   common  UT:GE0/0/2(U)
VID  Status  Property      MAC-LRN Statistics Description
1    enable  default       enable  disable    VLAN 0001
10   enable  default       enable  disable    VLAN 0010
20   enable  default       enable  disable    VLAN 0020
[swh]int g0/0/24
[swh-GigabitEthernet0/0/24]port link-type trunk
[swh-GigabitEthernet0/0/24]port trunk allow-pass vlan 10 20
[swh-GigabitEthernet0/0/24]q
[swh]
R1配置
注意:如果在实验过程中某个端口配置错了,可以使用undo shutdown初始化端口配置。
sys
[Huawei]
[Huawei]sys R1
[R1]
[R1]int g0/0/0.10     #子接口10用来和接受vlan10
[R1-GigabitEthernet0/0/0.10]dot1q termination vid 10   #意思是这个接口接在vlan10上面
[R1-GigabitEthernet0/0/0.10]ip add 192.168.10.254 24
Oct 22 2020 2338-08:00 R1 %%01IFNET/4/LINK_STATE(l)[0]:The line protocol IP
on the interface GigabitEthernet0/0/0.10 has entered the UP state.
[R1-GigabitEthernet0/0/0.10]arp broadcast enable    #启用子接口的ARP广播功能,公众号:wljsghq
[R1-GigabitEthernet0/0/0.10]q
[R1]int g0/0/0.20
[R1-GigabitEthernet0/0/0.20]dot1q termination vid 20
[R1-GigabitEthernet0/0/0.20]ip add 192.168.20.254 24
Oct 22 2020 2319-08:00 R1 %%01IFNET/4/LINK_STATE(l)[1]:The line protocol IP
on the interface GigabitEthernet0/0/0.20 has entered the UP state.
[R1-GigabitEthernet0/0/0.20]arp broadcast enable
[R1-GigabitEthernet0/0/0.20]dis this
[V200R003C00]
 ip address 192.168.20.254 255.255.255.0
return
查看路由器的配置
[R1]display ip interface brief
*down: administratively down
^down: standby
(l): loopback
(s): spoofing
The number of interface that is UP in Physical is 4
The number of interface that is DOWN in Physical is 1
The number of interface that is UP in Protocol is 3
The number of interface that is DOWN in Protocol is 2
Interface                         IP Address/Mask      Physical   Protocol
GigabitEthernet0/0/0              unassigned           up         down
GigabitEthernet0/0/0.10           192.168.10.254/24    up         up
GigabitEthernet0/0/0.20           192.168.20.254/24    up         up
GigabitEthernet0/0/1              unassigned           down       down
NULL0                             unassigned           up         up(s)
[R1]
编辑:黄飞
