3自由度串联机械臂实现电磁铁搬运功能
1、功能描述
     R308样机是一款拥有3自由度的串联机械臂。本文提供的示例所实现的功能为:在3自由度串联机械臂样机上安装电磁铁,实现电磁铁搬运物品的功能。
ArduinoArduino
2、电子硬件
在这个示例中,我们采用了以下硬件,请大家参考:
主控板 Basra(兼容Arduino Uno)
扩展板 Bigfish2.1
舵机 270°伺服电机
电池 7.4V锂电池
其它 电磁铁、USB线
电路连接说明:
Arduino
注:
① 270°伺服电机连接在Bigfish扩展板D4 . GND . VCC接口上
② 270°伺服电机连接在Bigfish扩展板D7 . GND . VCC接口上
③ 270°伺服电机连接在Bigfish扩展板D11 . GND . VCC接口上
电磁铁连接在Bigfish扩展板D9,D10接口上
3、运动控制
上位机:Controller 1.0
下位机编程环境:Arduino 1.8.19
3.1初始位置的设定
① 将Controller下位机程序servo_bigfish.ino直接下载到主控板。这段代码供Controller上位机与主控板通信,并允许调试舵机。代码如下:
  版权说明:Copyright 2023 Robottime(Beijing) Technology Co., Ltd. All Rights Reserved.
           Distributed under MIT license.See file LICENSE for detail or copy at
           https://opensource.org/licenses/MIT
           by 机器谱 2023-01-31 https://www.robotway.com/
* Bigfish扩展板舵机口; 4, 7, 11, 3, 8, 12, 14, 15, 16, 17, 18, 19
* 使用软件调节舵机时请拖拽对应序号的控制块
#include
#define ANGLE_VALUE_MIN 0
#define ANGLE_VALUE_MAX 180
#define PWM_VALUE_MIN 500
#define PWM_VALUE_MAX 2500
#define SERVO_NUM 12
Servo myServo[SERVO_NUM];
int data_array[2] = {0,0};   //servo_pin: data_array[0], servo_value: data_array[1];
int servo_port[SERVO_NUM] = {4, 7, 11, 3, 8, 12, 14, 15, 16, 17, 18, 19};
int servo_value[SERVO_NUM] = {};
String data = "";
boolean dataComplete = false;
void setup() {
  Serial.begin(9600);
void loop() {
  while(Serial.available())
    int B_flag, P_flag, T_flag;
    data = Serial.readStringUntil('n');
    data.trim();
    for(int i=0;i= ANGLE_VALUE_MIN && where <= ANGLE_VALUE_MAX)
    myServo[which].write(where);
  else if(where >= PWM_VALUE_MIN && where <= PWM_VALUE_MAX)
    myServo[which].writeMicroseconds(where);
int pin2index(int _pin){
  int index;
  switch(_pin)
    case 4: index = 0; break;
    case 7: index = 1; break;
    case 11: index = 2; break;
    case 3: index = 3; break;
    case 8: index = 4; break;
    case 12: index = 5; break;
    case 14: index = 6; break;
    case 15: index = 7; break;
    case 16: index = 8; break;
    case 17: index = 9; break;
    case 18: index = 10; break;
    case 19: index = 11; break;
  return index;
下载完成后,保持主控板和电脑的USB连接,以便利用上位机进行调试。
② 双击打开Controller 1.0b.exe:
ArduinoArduino
③ 界面左上角选择:设置-面板设置,弹出需要显示的调试块,可通过勾选隐藏不需要调试的舵机块:联机-选择主控板对应端口号以及波特率。
ArduinoArduinoArduinoArduino
④ 拖动进度条,可以观察相应的舵机角度转动。写好对应的舵机调试角度,勾选左下角添加-转化,获得舵机调试的数组:
Arduino
⑤ 将该数组直接复制到相应的Arduino程序中的get_coordinate()部分进行使用。
3.2调试好角度后将电磁铁搬运例程(calculate_angle_test.ino)下载到主控板【程序源码详见 https://www.robotway.com/h-col-191.html】
#include
#include
#define SERVO_SPEED 3460                                        //定义舵机转动快慢的时间
#define ACTION_DELAY 200                                        //定义所有舵机每个状态时间间隔
#define L1 172
#define L2 160
#define L3 135
Servo myServo[6];
int f = 200;                                                    //定义舵机每个状态间转动的次数,以此来确定每个舵机每次转动的角度
int servo_port[6] = {4,7,11,3,8,12};                            //定义舵机引脚
int servo_num = sizeof(servo_port) / sizeof(servo_port[0]);     //定义舵机数量
float value_init[6] = {1500, 1500, 1500, 0, 0, 0};              //定义舵机初始角度
double theta[3] = {};
float value_pwm[6] = {};
float coordinate[3] = {};
int data_num;
void setup() {
  Serial.begin(9600);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  for(int i=0;i= 0){
    theta[0] = theta0 * 180 / PI;
  else
    theta[0] = 180 + theta0 * 180 / PI;
  theta[1] = 90 - theta1 * 180 / PI;
  theta[2] = theta2 * 180 / PI;
//   Serial.print("theta0 = ");
//   Serial.println(theta[0]);
//   Serial.print("theta1 = ");
//   Serial.println(theta[1]);
//   Serial.print("theta2 = ");
//   Serial.println(theta[2]);
//   Serial.println("-------------------------------------");
void ServoStart(int which)
  if(!myServo[which].attached())myServo[which].attach(servo_port[which]);
  pinMode(servo_port[which], OUTPUT);
void ServoStop(int which)
  myServo[which].detach();
  digitalWrite(servo_port[which],LOW);
void ServoGo(int which , int where)
  if(where!=200)
    if(where==201) ServoStop(which);
    else
      ServoStart(which);
void servo_move(float value0, float value1, float value2, float value3, float value4, float value5)
  float value_arguments[] = {value0, value1, value2, value3, value4, value5};
  float value_delta[servo_num];
  for(int i=0;i
审核编辑 黄宇
