ADUM2402 ADI推出一款四通道数字隔离器
ADUM2402是一款四通道数字隔离器,同光电耦合器等道统器件相比,它具有出色的性能特性。由于不使用LED和光电二极管,iCoupler器件不再具有与光电耦合器相关的设计难度,包括不确定电流传输比率、非线性传输功能、温度影响以及寿命影响等挑战。iCoupler器件具有简单的数字界面和稳定的性能特性。iCoupler器件不再需要外部驱动器以及其他分立器件。此外,在可比较的信号数据速率时,iCoupler器件的功耗仅为光电耦合器的1/10~1/6。
产品规格︰
Max OperaTIng Temp (°C):105Deg
Isolated Output (V)min:2.7V
Isolated Output (V)max:5.5V
Output Default State:High
InsulaTIon RaTIng (kVrms):5kV rms
# Ch:4
Pulse Width Distort (ns):3ns
Max Prop Delay (ns):32ns
产品特性︰
Low power operaTIon
5 V operation - Please see data sheet
3 V operation - Please see data sheet
Bidirectional communication
3 V/5 V level translation
High temperature operation: 105°C
High data rate: dc to 90 Mbps (NRZ)
Precise timing characteristics
2 ns maximum pulse width distortion
产品应用︰
General-purpose, high voltage, multichannel isolation
Medical equipment
Motor drives
Power supplies
ADI
审核编辑 黄宇
