Halcon基于形状匹配的人脸追踪
Halcon基于形状匹配的人脸追踪
*打开摄像头句柄AcqHandle
open_framegrabber ('DirectShow', 1, 1, 0, 0, 0, 0, 'default', 8, 'rgb', -1, 'false', 'default', '[0] USB2.0 HD UVC WebCam', 0, -1, AcqHandle)
*从摄像头抓取一张图片
grab_image (Image, AcqHandle)
*抓完关闭摄像头
close_framegrabber (AcqHandle)
dev_close_window ()
get_image_size (Image, Width, Height)
dev_open_window (0, 0, Width, Height, 'black', WindowHandle)
*打开一个窗口,尺寸400*400,黑色背景,句柄赋予WindowHandle
dev_set_draw ('margin')
*'margin'只显示轮廓,'fille'显示填充
dev_display (Image)
*定义数组显示提示信息
Message[0] := ' 提 示:'
Message[1] := '右键画面开始创建识别区域,按左键结束'
*显示数组中的提示信息
disp_message (WindowHandle, Message[0], 'window', 12, 12, 'red', 'true')
disp_message (WindowHandle, Message[1], 'window', 48, 12, 'black', 'true')
*继续提示语显示
disp_continue_message (WindowHandle, 'black', 'true')
draw_rectangle1 (WindowHandle, Row1, Column1, Row2, Column2)
*鼠标在打开的窗口绘制一个矩形,输出左上右下点的坐标
gen_rectangle1 (Rectangle, Row1, Column1, Row2, Column2)
*得到一个矩形
reduce_domain (Image, Rectangle, ImageReduced)
*缩小图像的域,取image与rectangle的交集,句柄ImageReduced,诣在从原图上扣取画出的区域
*执行断点处
stop()
*准备一个可变形模型,用于平面标定匹配轮廓。
*create_planar_uncalib_deformable_model (ImageReduced, 'auto', [], [], 'auto', 1, [], 'auto', 1, [], 'auto', 'none', 'use_polarity', 'auto', 'auto', [], [], ModelID)
create_planar_uncalib_deformable_model (ImageReduced, 5, rad(0), rad(360), rad(1), 1, 1, 0.02, 1, 1, 0.02, 'none', 'use_polarity', [42,57], 10, [], [], ModelID)
*create_planar_calib_deformable_model_xld(Template::NumLevel,AngleStart,AngleExtent,AngleStep,ScaleRMin,ScaleRMax,ScaleRStep,ScaleCMin,ScaleCMax,ScaleCStep,Optimization,Metric,Contrast,MinContrast,GenParamName,GenParamValue:ModelID
*template输入模板
*NumLevels 输入金字塔最大层数(‘auto’(默认), 1, 2, 3, 4, 5, 6, 7, 8, 9, 10)
*AngleStart 在最小的旋转模式(-3.14, -1.57, -0.79, -0.39(默认), -0.20, 0.0),
*AngleExtent 在旋转的角(6.29, 3.14, 1.57, 0.79(默认), 0.39(输入条件:大于等于0))
*AngleStep 输入角度的步长(分辨率)(‘auto’(默认), 0.0175, 0.0349, 0.0524, 0.0698, 0.0873,(输入条件:(AngleStep > 0) && (AngleStep <= (pi / 16))))
*ScaleRMin行方向上的图案的最小尺度( 0.5, 0.6, 0.7, 0.8, 0.9, 1.0(默认)(输入条件:ScaleRMin > 0))
*ScaleRMax 在行方向上的图案的最大尺度(1.0(默认), 1.1, 1.2, 1.3, 1.4, 1.5(输入条件:ScaleRMax >= ScaleRMin))
*ScaleRStep 在行方向上的刻度步长(分辨率)(‘auto’(默认), 0.01, 0.02, 0.05, 0.1, 0.15, 0.2,(输入条件:ScaleCStep > 0))
*ScaleCMin 行方向上的图案的最小尺度( 0.5, 0.6, 0.7, 0.8, 0.9, 1.0(默认)(输入条件:ScaleRMin > 0))
*ScaleCStep 在列方向上的刻度步长(分辨率)(‘auto’(默认), 0.01, 0.02, 0.05, 0.1, 0.15, 0.2,(输入条件:ScaleCStep > 0))
*Optimization 一种用于生成模型的优化方法( ‘auto’(默认), ‘none’, ‘point_reduction_low’, ‘point_reduction_medium’, ‘point_reduction_high’)
*Metric ( ‘use_polarity’, ‘ignore_global_polarity’, ‘ignore_part_polarity’, ‘ignore_local_polarity’,‘ignore_color_polarity’(默认))
*Contrast 搜索图像中物体的对比度
*MinContrast 搜索图像中物体的最小对比度(1, 2, 3, 5(默认), 7, 10, 20, 30, 40)
*GenParamName 泛型参数名([],‘part_size’)
*GenParamValue 泛型参数的值( [], ‘small’, ‘medium’, ‘big’)
*ModelID 模型的句柄
get_deformable_model_contours (ModelContours, ModelID, 1)
*返回可变形模型的轮廓表示,输出:输入模板轮廓,级别1、2、3、4、5、6、7、8、9、10(Level >= 1)
*测量输入轮廓的面积与中心值
area_center (Rectangle, ModelRegionArea, RefRow, RefColumn)
*仿射变换
vector_angle_to_rigid (0, 0, 0, RefRow, RefColumn, 0, HomMat2D)
*对XLD轮廓进行任意仿射2D变换
affine_trans_contour_xld (ModelContours, TransContours, HomMat2D)
dev_set_color ('green')
dev_display (Image)
dev_display (Rectangle)
dev_display (TransContours)
stop ()
while (true)
    find_planar_uncalib_deformable_model (Image, ModelID, rad(0), rad(360), 1, 1, 1, 1, 0.5, 0, 0.5, 5, 0.75, ['subpixel'], ['least_squares_very_high'], ResultHomMat2D, Score)
    dev_display (Image)
    for I := 0 to |Score| - 1 by 1
        TempHomMat2D := ResultHomMat2D[I*9:I*9+8]
        projective_trans_contour_xld (ModelContours, TransContours, TempHomMat2D)
*       将射影变换应用于 XLD 轮廓
       * dev_display (TransContours)
        *xld转换成region
        gen_region_contour_xld (TransContours, Region, 'filled')
        union1 (Region, RegionUnion)
        *对区域,生成最小外接矩形
        smallest_rectangle1 (RegionUnion, Row1, Column1, Row2, Column2)
        *使用绿色矩形框,框选匹配结果
      * dev_set_color ('green')
       disp_rectangle1 (WindowHandle, Row1, Column1, Row2, Column2)
      *使用红色勾画匹配结果轮廓
*        stop ()
    endfor
endwhile
审核编辑 :李倩
