linux系统中内存分配基本原理分析
嵌入式技术
1418人已加入
Linux
第一:linux系统中内存分配关注问题
     在编写Linux驱动过程中,不可避免涉及外设操作,而外设地址空间与DDR地址空间一般不连续,在linux上电时,并不会为外设地址空间建立页表,又因为linux访问内存使用的都是虚拟地址,因此如果想访问外设的寄存器(一般包括数据寄存器、控制寄存器与状态寄存器),需要在驱动初始化中将外设所处的物理地址映射为虚拟地址,linux为应对该问题提供了较多接口,包括:ioremap/ioremap_wc/devm_ioremap/devm_ioremap_resource等,以应对不同的场景需求,本文即阐述这些接口的使用,以及需要注意的区别。
第二:场景的应用背景
   在系统运行时,外设IO资源的物理地址是已知的,由硬件的设计决定(参考SOC的datesheet,一般会有memorymap)。驱动程序不能通过物理地址访问IO资源,必须将其映射到内核态的虚拟地址空间(通过页表)[1],然后根据映射所得到的内核虚拟地址范围,通过线性偏移(virt_addr = virt_base + phy_addr - phy_base)访问这些IO内存资源。
代码路径:arch/arm/include/asm/io.h
349  * ioremap() and friends.
350  *
351  * ioremap() takes a resource address, and size.  Due to the ARM memory
352  * types, it is important to use the correct ioremap() function as each
353  * mapping has specific properties.
354  *
355  * Function             Memory type     Cacheability    Cache hint
356  * ioremap()            Device          n/a             n/a
357  * ioremap_nocache()    Device          n/a             n/a
358  * ioremap_cache()      Normal          Writeback       Read allocate
359  * ioremap_wc()         Normal          Non-cacheable   n/a
360  * ioremap_wt()         Normal          Non-cacheable   n/a
361  *
362  * All device mappings have the following properties:
363  * - no access speculation
364  * - no repetition (eg, on return from an exception)
365  * - number, order and size of accesses are maintained
366  * - unaligned accesses are "unpredictable"
367  * - writes may be delayed before they hit the endpoint device
368  *
369  * ioremap_nocache() is the same as ioremap() as there are too many device
370  * drivers using this for device registers, and documentation which tells
371  * people to use it for such for this to be any different.  This is not a
372  * safe fallback for memory-like mappings, or memory regions where the
373  * compiler may generate unaligned accesses - eg, via inlining its own
374  * memcpy.
375  *
376  * All normal memory mappings have the following properties:
377  * - reads can be repeated with no side effects
378  * - repeated reads return the last value written
379  * - reads can fetch additional locations without side effects
380  * - writes can be repeated (in certain cases) with no side effects
381  * - writes can be merged before accessing the target
382  * - unaligned accesses can be supported
383  * - ordering is not guaranteed without explicit dependencies or barrier
384  *   instructions
385  * - writes may be delayed before they hit the endpoint memory
386  *
387  * The cache hint is only a performance hint: CPUs may alias these hints.
388  * Eg, a CPU not implementing read allocate but implementing write allocate
389  * will provide a write allocate mapping instead.
390  */
ioremap函数组共有五个接口,根据函数实现可以分为三类:
ioremap & ioremap_nocache实现相同,使用场景为映射device memory类型内存;
ioremap_cached,使用场景为映射normal memory类型内存,且映射后的虚拟内存支持cache;
ioremap_wc & ioremap_wt实现相同,使用场景为映射normal memory类型内训,且映射后的虚拟内存不支持cache。
第三:何为memory type?
     内存类型(memory type)分为设备(device)类型与一般(normal)类型。
第四:ioremap & ioremap_nocache
void __iomem *ioremap(resource_size_t res_cookie, size_t size);
#define ioremap ioremap        #define ioremap_nocache ioremap
    ioremap用来映射memory type为device memory的设备,同时不使用cache(device memory本身就没有cacheable这个属性),即CPU的读写操作直接操作设备内存。ioremap_nocache的实现与ioremap完全相同,保留该符号是因为向后兼容使用ioremap_nocache接口的驱动程序。
    API接口中的res_cookie参数是需要映射的物理地址,size参数是需要映射的内存大小,单位是Byte。不需要考虑物理地址的页对齐问题,底层通过PAGE_ALIGN接口完成了页对齐。
第五:ioremap_cached
* Do not use ioremap_cached in new code. Provided for the benefit of
* the pxa2xx-flash MTD driver only.
void __iomem *ioremap_cached(resource_size_t res_cookie, size_t size);
ioremap_cached用来映射memory type为normal memory的设备,同时使用cache,这会提高内存的访问速度,提高系统的性能。
第六:ioremap_wc & ioremap_wt
void __iomem *ioremap_wc(resource_size_t res_cookie, size_t size);
#define ioremap_wc ioremap_wc
#define ioremap_wt ioremap_wc
ioremap_wc用来映射memory type为normal memory的设备,同时不使用cache。
第七:解映射API
void iounmap(volatile void __iomem *iomem_cookie);
不论采用以上哪种映射方式,解映射为统一接口,其中iomem_cookie参数为映射后的虚拟地址。
第八:IO资源读写过程
我们已经知道如何映射和解映射虚拟内存,内存映射是为了访问,理论上这时候可以像读写RAM那样直接通过虚拟地址指针读写IO内存资源,但是为了保证驱动程序跨平台的可移植性【这一点还不太理解,直接指针操作怎么影响的移植性,望大家指教】,我们应该采用linux中特定的接口函数来访问IO内存[1]。常用接口如下:
299 #define readb(c)                ({ u8  __v = readb_relaxed(c); __iormb(); __v; })
300 #define readw(c)                ({ u16 __v = readw_relaxed(c); __iormb(); __v; })
301 #define readl(c)                ({ u32 __v = readl_relaxed(c); __iormb(); __v; })
303 #define writeb(v,c)             ({ __iowmb(); writeb_relaxed(v,c); })
304 #define writew(v,c)             ({ __iowmb(); writew_relaxed(v,c); })
305 #define writel(v,c)             ({ __iowmb(); writel_relaxed(v,c); })
316 static inline void memset_io(volatile void __iomem *dst, unsigned c,                                size_t count);
324 static inline void memcpy_fromio(void *to, const volatile void __iomem *from,                         size_t count);
332 static inline void memcpy_toio(volatile void __iomem *to, const void *from,                           size_t count);
  审核编辑:汤梓红
