如何使用华为ensp模拟器设计实现企业网络?
本次实验在华为ensp模拟器具体实现。
拓扑图
模拟器
网段划分
区域 VLAN 网段
技术部 VLAN 10 192.168.10.0/24
人事部 VLAN 20 192.168.20.0/24
财务部 VLAN 30 192.168.30.0/24
领导部门 VLAN 40 192.168.40.0/24
来访客户 VLAN 100 192.168.100.0/24
服务器DMZ VLAN 90 192.138.90.0/24
办公区
VLAN+端口配置(二层)
LSW1
vlan batch 10
int e0/0/1
 port link-type trunk
 port trunk allow-pass vlan 10
int e0/0/2
int e0/0/10
 port link-type access
 port default vlan 10
LSW2
vlan batch 20
int e0/0/1
 port trunk allow-pass vlan 20
int e0/0/2
int e0/0/10
 port default vlan 20
LSW3
vlan batch 30
int e0/0/1
 port trunk allow-pass vlan 30
int e0/0/2
int e0/0/10
 port default vlan 30
LSW4
vlan batch 40
int e0/0/1
 port trunk allow-pass vlan 40
int e0/0/2
int e0/0/10
 port default vlan 40
H_SW1
vlan batch 10 20 30 40
int g0/0/1
int g0/0/2
int g0/0/3
int g0/0/4
H_SW2
int g0/0/1
int g0/0/2
int g0/0/3
int g0/0/4
无线网络配置
H_SW1
vlan batch 100 1000
int g0/0/5
 port trunk allow-pass vlan all
int g0/0/6
 port trunk allow-pass vlan 100 1000
dhcp enable
int vlanif 100
 ip add 192.168.100.1 24
 dhcp select interface
 dhcp server dns-list 8.8.8.8
H_SW2
vlan batch 100 1000
int g0/0/5
int g0/0/6
dhcp enable
LSW5
vlan batch 100 1000
int e0/0/1
int e0/0/2
int e0/0/10
dhcp enable
LSW6
vlan batch 100 1000
int e0/0/1
int e0/0/2
int e0/0/10
 port trunk pvid vlan 1000
dhcp enable
AC
u t m
sys
sysname AC
vlan batch 100 1000
int g0/0/1
dhcp enable
int vlanif 1000
 ip add 192.168.101.1 24
capwap source interface Vlanif 1000
wlan
 ap-group name ap-group1
 regulatory-domain-profile default
  y
 quit
 ap auth-mode mac-auth
 ap-id 0 ap-mac 00e0-fc25-3910
  ap-name area_1
  ap-group ap-group1
   y
  quit
 security-profile name WLAN
  security wpa-wpa2 psk pass-phrase a1234567 aes
  quit
 ssid-profile name WLAN
  ssid WLAN
  quit
 vap-profile name WLAN
  forward-mode direct-forward
  service-vlan vlan-id 100
  security-profile WLAN
  ssid-profile WLAN
  quit
  vap-profile WLAN wlan 1 radio 0
  vap-profile WLAN wlan 1 radio 1
DHCP配置
H_SW1
dhcp enable
ip pool vlan10
 gateway-list 192.168.10.254
 network 192.168.10.0 mask 24
 excluded-ip-address 192.168.10.1 192.168.10.10
 excluded-ip-address 192.168.10.150 192.168.10.253
 dns-list 8.8.8.8
 domain-name blue.com
ip pool vlan20
 gateway-list 192.168.20.254
 network 192.168.20.0 mask 255.255.255.0
 excluded-ip-address 192.168.20.1 192.168.20.10
 excluded-ip-address 192.168.20.150 192.168.20.253
 dns-list 8.8.8.8
ip pool vlan30
 gateway-list 192.168.30.254
 network 192.168.30.0 mask 255.255.255.0
 excluded-ip-address 192.168.30.1 192.168.30.10
 excluded-ip-address 192.168.30.150 192.168.30.253
 dns-list 8.8.8.8
ip pool vlan40
 gateway-list 192.168.40.254
 network 192.168.40.0 mask 255.255.255.0
 excluded-ip-address 192.168.40.1 192.168.40.10
 excluded-ip-address 192.168.40.150 192.168.40.253
 dns-list 8.8.8.8
int vlanif10
 ip add 192.168.10.1 255.255.255.0
 dhcp select global
int vlanif20
 ip add 192.168.20.1 255.255.255.0
 dhcp select global
int vlanif30
 ip add 192.168.30.1 255.255.255.0
 dhcp select global
int vlanif40
 ip add 192.168.40.1 255.255.255.0
 dhcp select global
H_SW2
dhcp enable
ip pool vlan10
 network 192.168.10.0 mask 255.255.255.0
 excluded-ip-address 192.168.10.1 192.168.10.149
 excluded-ip-address 192.168.10.250 192.168.10.253
 dns-list 8.8.8.8
ip pool vlan20
 excluded-ip-address 192.168.20.1 192.168.20.149
 excluded-ip-address 192.168.20.250 192.168.20.253
 dns-list 8.8.8.8
ip pool vlan30
 excluded-ip-address 192.168.30.1 192.168.30.149
 excluded-ip-address 192.168.30.250 192.168.30.253
 dns-list 8.8.8.8
ip pool vlan40
 excluded-ip-address 192.168.40.1 192.168.40.149
 excluded-ip-address 192.168.40.250 192.168.40.253
 dns-list 8.8.8.8
interface Vlanif10
 ip address 192.168.10.2 255.255.255.0
 dhcp select global
interface Vlanif20
 ip address 192.168.20.2 255.255.255.0
 dhcp select global
interface Vlanif30
 ip address 192.168.30.2 255.255.255.0
 dhcp select global
interface Vlanif40
 ip address 192.168.40.2 255.255.255.0
 dhcp select global
在IP地址池创建的过程中,使用了excluded-ip-address命令,使得在主备交换机切换时分配的地址池相互排除,防止主备交换机切换后出现IP地址分配冲突导致网络故障。
VRRP配置
H_SW1
int vlanif10
 vrrp vrid 10 virtual-ip 192.168.10.254
 vrrp vrid 10 priority 105
int vlanif20
 vrrp vrid 20 virtual-ip 192.168.20.254
 vrrp vrid 20 priority 105
int vlanif30
 vrrp vrid 30 virtual-ip 192.168.30.254
int vlanif40
 vrrp vrid 40 virtual-ip 192.168.40.254
H_SW2
int vlanif10
int vlanif20
int vlanif30
vrrp vrid 30 priority 105
int vlanif40
vrrp vrid 40 priority 105
STP配置
LSW1
stp region-configuration
 region-name Blue_mstp
 revision-level 1
 instance 10 vlan 10
 active region-configuration
int e0/0/10
 stp edged-port enable
LSW2
 revision-level 1
 instance 10 vlan 10
int e0/0/10
LSW3
 revision-level 1
 instance 30 vlan 30
 quit
int e0/0/10
LSW4
 revision-level 1
 instance 40 vlan 40
int e0/0/10
H_SW1
stp instance 12 root primary
stp instance 34 root secondary
 revision-level 1
 instance 12 vlan 10 20
 instance 34 vlan 30 40
int g0/0/11
 stp disable
int g0/0/12
 stp disable
H_SW2
stp instance 12 root secondary
stp instance 34 root primary
 revision-level 1
int g0/0/11
 stp disable
int g0/0/12
 stp disable
ACL配置
H_SW1
acl number 3002
rule 5 deny ip source 192.168.100.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
int g0/0/5
 traffic-filter inbound acl 3002
H_SW2
acl number 3002
int g0/0/5
LACP配置
LACP链路聚合,链路聚合的原理是将一组相同属性的物理接口捆绑在一起为一个逻辑接口来增加带宽和可靠性的一种方法。有以下优势:
增加带宽、提高冗余(提高可靠性)、负载分担、节省成本、配置量小
1.增加带宽:链路聚合接口的最大带宽可以达到各个成员接口带宽之和。
2提高冗余:当某条路线出现故障的时候,流量可以切到其他可用的成员链路上。流量会切到其他可用链路上,从而提高链路聚合接口的冗余性。并不会影响数据的传输,相对来说也具有稳定性。
3负载分担:在一个链路聚合组内,可以实现在各成员活动链路上的负载分担。
4节省成本:管理员不需要升级链路速度,对已有的接口进行捆绑。
5配置量小:大部分的配置在组Eth-Trunk下完成。
主要的优势是能增加带宽、提高可靠性和负载分担。
H_SW1
lacp priority 100
int eth-trunk1
 port trunk allow-pass vlan 10 20 30 40
 mode lacp-static
 load-balance src-dst-mac
int g0/0/13
 eth-trunk 1
 lacp priority 100
int g0/0/14
 eth-trunk 1
H_SW2
int eth-trunk1
 mode lacp-static
int g0/0/13
 eth-trunk 1
int g0/0/14
 eth-trunk 1
OSPF配置
LSW1
int loopback0
 ip add 192.168.1.1 32
LSW2
interface LoopBack0
 ip address 192.168.2.2 255.255.255.255
LSW3
interface LoopBack0
 ip address 192.168.3.3 255.255.255.255
LSW4
interface LoopBack0
 ip address 192.168.4.4 255.255.255.255
H_SW1
int loopback 0
 ip add 192.168.5.5 32
ospf 10 router-id 192.168.5.5
 silent-interface Vlanif10
 silent-interface Vlanif20
 silent-interface Vlanif30
 silent-interface Vlanif40
 area 0
  network 192.168.5.5 0.0.0.0
  network 192.168.10.1 0.0.0.0
  network 192.168.20.1 0.0.0.0
  network 192.168.30.1 0.0.0.0
  network 192.168.40.1 0.0.0.0
  network 192.168.25.5 0.0.0.0
  network 192.168.35.5 0.0.0.0
  network 192.168.100.1 0.0.0.0
H_SW2
interface LoopBack0
 ip address 192.168.6.6 255.255.255.255
ospf 10 router-id 192.168.6.6
 area 0.0.0.0
  network 192.168.6.6 0.0.0.0
  network 192.168.10.2 0.0.0.0
  network 192.168.20.2 0.0.0.0
  network 192.168.30.2 0.0.0.0
  network 192.168.40.2 0.0.0.0
  network 192.168.24.6 0.0.0.0
  network 192.168.36.6 0.0.0.0
  network 192.168.100.2 0.0.0.0
核心层
VLAN划分+配置端口
核心交换机
C_SW1
vlan batch 22 to 25
int g0/0/1
 port default vlan 25
 stp disable
int g0/0/2
 port default vlan 24
 stp disable
int g0/0/11
 port default vlan 22
 stp disable
int g0/0/12
 port default vlan 23
 stp disable
interface Vlanif22
 ip address 192.168.22.7 255.255.255.0
interface Vlanif23
 ip address 192.168.23.7 255.255.255.0
interface Vlanif24
 ip address 192.168.24.7 255.255.255.0
interface Vlanif25
 ip address 192.168.25.7 255.255.255.0
C_SW2
vlan batch 33 to 36 44 55
int g0/0/1
 port default vlan 35
 stp disable
int g0/0/2
 port default vlan 36
 stp disable
int g0/0/11
 port default vlan 34
 stp disable
int g0/0/12
 port default vlan 33
 stp disable
interface Vlanif33
 ip address 192.168.33.8 255.255.255.0
interface Vlanif34
 ip address 192.168.34.8 255.255.255.0
interface Vlanif35
 ip address 192.168.35.8 255.255.255.0
interface Vlanif36
 ip address 192.168.36.8 255.255.255.0
interface Vlanif44
 ip address 192.168.44.8 255.255.255.0
interface Vlanif55
 ip address 192.168.55.8 255.255.255.0
汇聚层连接核心交换机
H_SW1
vlan batch 25 35
int g0/0/11
 stp disable
int g0/0/12
 stp disable
int vlanif25
 ip add 192.168.25.5 24
int vlanif35
 ip add 192.168.35.5 24
H_SW2
vlan batch 24 36
int g0/0/11
 stp disable
int g0/0/12
 stp disable
int vlanif24
 ip add 192.168.24.6 24
int vlanif36
 ip add 192.168.36.6 24
STP配置
C_SW1
int g0/0/1
 stp disable
int g0/0/2
 stp disable
int g0/0/11
 stp disable
int g0/0/12
 stp disable
C_SW2
int g0/0/1
 stp disable
int g0/0/2
 stp disable
int g0/0/11
 stp disable
int g0/0/12
 stp disable
LACP链路聚合
C_SW1
lacp priority 100
int eth-trunk1
 mode lacp-static
int g0/0/3
 eth-trunk 1
 lacp priority 100
int g0/0/4
 eth-trunk 1
C_SW2
int eth-trunk1
 mode lacp-static
int g0/0/3
 eth-trunk 1
int g0/0/4
 eth-trunk 1
OSPF配置
C_SW1
interface LoopBack0
 ip address 192.168.7.7 255.255.255.255
ospf 10 router-id 192.168.7.7
 area 0.0.0.0
  network 192.168.7.7 0.0.0.0
  network 192.168.22.7 0.0.0.0
  network 192.168.23.7 0.0.0.0
  network 192.168.44.7 0.0.0.0
  network 192.168.55.7 0.0.0.0
  network 192.168.24.7 0.0.0.0
  network 192.168.25.7 0.0.0.0
C_SW2
interface LoopBack0
 ip address 192.168.8.8 255.255.255.255
ospf 10 router-id 192.168.8.8
 area 0.0.0.0
  network 192.168.8.8 0.0.0.0
  network 192.168.33.8 0.0.0.0
  network 192.168.34.8 0.0.0.0
  network 192.168.35.8 0.0.0.0
  network 192.168.36.8 0.0.0.0
  network 192.168.44.8 0.0.0.0
  network 192.168.55.8 0.0.0.0
防火墙
基本配置
FW1
用户名:admin
原始密码:Admin@123
密码:P@ssw0rd
新密码:Blue@123
undo terminal monitor
language-mode Chinese
sys
sysname FW1
#配置连接防火墙web的接口,IP为虚拟网络对应网段的地址
int g0/0/0
 undo ip add 192.168.0.1 24
 ip add 192.168.94.2 24
 service-manage all permit
FW2
用户名:admin
原始密码:Admin@123
密码:P@ssw0rd
新密码:Blue@123
sys
sysname FW2
int g0/0/0
 ip add 192.168.94.3 24
规划网段
FW1
int g1/0/0
 undo shutdown
 ip add 192.168.90.1 255.255.255.0
int g1/0/1
 undo shutdown
 ip add 192.168.22.1 255.255.255.0
int g1/0/2
 undo shutdown
 ip add 192.168.34.1 255.255.255.0
int g1/0/3
 undo shutdown
int g1/0/4
 undo shutdown
int g1/0/5
 undo shutdown
 ip address 100.100.100.1 255.255.255.0
 service-manage ping permit
int g1/0/6
 undo shutdown
 ip add 200.200.200.1 255.255.255.0
FW2
int g1/0/0
 undo shutdown
 ip add 192.168.90.2 255.255.255.0
int g1/0/1
 undo shutdown
 ip add 192.168.23.1 255.255.255.0
int g1/0/2
 undo shutdown
 ip add 192.168.33.1 255.255.255.0
int g1/0/3
 undo shutdown
int g1/0/4
 undo shutdown
int g1/0/5
 undo shutdown
 ip address 100.100.100.2 255.255.255.0
int g1/0/6
 undo shutdown
 ip add 200.200.200.2 255.255.255.0
LACP链路聚合
FW1
int eth-trunk2
 ip add 192.168.2.1 255.255.255.0
 mode lacp-static
int g1/0/3
 eth-trunk 2
int g1/0/4
 eth-trunk 2
FW2
int eth-trunk2
 ip add 192.168.2.2 255.255.255.0
 mode lacp-static
int g1/0/3
 eth-trunk 2
int g1/0/4
 eth-trunk 2
规划安全区域
根据拓扑,将接口划入对应的安全区域
注意:两个防火墙之间的心跳接口要必须放进信任区域
FW1
firewall zone trust
 add int g1/0/1
 add int g1/0/2
firewall zone dmz
 add int g1/0/0
firewall zone name heart id 4
 set priority 75
 add int eth-trunk2
firewall zone name ISP1 id 5
 set priority 20
 add int g1/0/5
firewall zone name ISP2 id 6
 set priority 15
 add int g1/0/6
FW2
firewall zone trust
 add int g1/0/1
 add int g1/0/2
firewall zone dmz
 add int g1/0/0
 set priority 75
 add int eth-trunk2
 set priority 15
 add int g1/0/5
 set priority 20
 add int g1/0/6
指定链路接口组名称
FW1
 isp name "china mobile" linkif-group 63
 isp name "china unicom" linkif-group 62
 isp name "china telecom" linkif-group 61
 isp name "china educationnet" linkif-group 60
FW2
安全策略精要
BGP、BFD、DHCP、DHCPv6、LDP和OSPF是否受安全策略控制,由基础协议控制开关(firewall packet-filter basic-protocol enable)决定。
FW1
firewall defend port-scan enable
firewall defend ip-sweep enable
firewall defend teardrop enable
firewall defend time-stamp enable
firewall defend route-record enable
firewall defend source-route enable
firewall defend ip-fragment enable
firewall defend tcp-flag enable
firewall defend winnuke enable
firewall defend fraggle enable
firewall defend tracert enable
firewall defend icmp-unreachable enable
firewall defend icmp-redirect enable
firewall defend large-icmp enable
firewall defend ping-of-death enable
firewall defend smurf enable
firewall defend land enable
firewall defend ip-spoofing enable
FW2
安全策略配置
FW1
security-policy
 #管理区
 rule name Trust_Local
  description Management
  source-zone trust
  destination-zone local
  action permit
FW2
security-policy
 #管理区
  source-zone trust
  action permit
配置IP-link
FW1
ip-link check enable
ip-link name isp1
 destination 100.100.100.100 interface GigabitEthernet1/0/5 mode icmp
ip-link name isp2
 destination 200.200.200.200 interface GigabitEthernet1/0/6 mode icmp
#安全策略配置
security-policy
 rule name Local_ISP
  description ip-link
  source-zone local
  destination-zone ISP1
  destination-zone ISP2
  action permit
FW2
ip-link name isp1
ip-link name isp2
#安全策略配置
security-policy
 rule name Local_ISP
  description ip-link
  source-zone local
  action permit
配置静态路由
FW1
ip route-static 0.0.0.0 0.0.0.0 100.100.100.100 preference 50 track ip-link isp1
ip route-static 0.0.0.0 0.0.0.0 200.200.200.200 preference 50
ip route-static 10.20.100.0 255.255.255.0 GigabitEthernet1/0/5 100.100.100.100
ip route-static 10.20.100.0 255.255.255.0 GigabitEthernet1/0/6 200.200.200.200
ip route-static 10.20.100.0 255.255.255.0 NULL0
FW2
配置OSPF动态路由
步骤一:配置动态路由
FW1
interface LoopBack0
 ip address 192.168.11.11 255.255.255.255
ospf 10 router-id 192.168.11.11
 default-route-advertise
 area 0.0.0.0
  network 192.168.11.11 0.0.0.0
  network 192.168.22.1 0.0.0.0
  network 192.168.34.1 0.0.0.0
  network 192.168.90.1 0.0.0.0
FW2
interface LoopBack0
 ip address 192.168.22.22 255.255.255.255
ospf 10 router-id 192.168.22.22
 area 0.0.0.0
  network 192.168.22.22 0.0.0.0
  network 192.168.23.1 0.0.0.0
  network 192.168.33.1 0.0.0.0
  network 192.168.90.2 0.0.0.0
步骤二:配置安全策略
FW1
security-policy
 rule name Local_Trust
  description OSPF
  source-zone local
  destination-zone trust
  action permit
FW2
security-policy
  description OSPF
  source-zone local
  action permit
双机热备
步骤1:配置VRRP备份组
主设备:FW1
int g1/0/5
 vrrp vrid 1 virtual-ip 100.100.100.5 active
 vrrp virtual-mac enable
int g1/0/6
 vrrp vrid 2 virtual-ip 200.200.200.5 standby
备份设备:FW2
int g1/0/5
 vrrp vrid 1 virtual-ip 100.100.100.5 standby
int g1/0/6
 vrrp vrid 2 virtual-ip 200.200.200.5 active
步骤2:开启HRP协议,并配置心跳接口和会话备份功能
FW1
hrp enable
hrp int eth-trunk2 remote 192.168.2.2
hrp mirror session enable
hrp standby config enable
FW2
hrp enable
hrp int eth-trunk2 remote 192.168.2.1
步骤3:配置安全策列
是内网用户可以访问服务器和外网用户;外网用户只能访问服务器。
注意:只需要配置Master即可,Backup设备不用配置,配置命令会自动从主设备备份到备份设备。
FW1
security-policy
 rule name heart
  source-zone heart
  source-zone local
  destination-zone heart
  action permit
FW2
security-policy
 default action permit
 rule name heart
  source-zone heart
  source-zone local
  action permit
NAT配置
定义转换的IP地址范围
FW1
ip address-set Web_IP type object
 address 0 100.100.100.5 mask 32
 address 1 200.200.200.5 mask 32
ip address-set PC type object
 address 0 192.168.10.0 mask 24
 address 1 192.168.20.0 mask 24
 address 2 192.168.30.0 mask 24
 address 3 192.168.40.0 mask 24 来源:网络技术干货圈
FW2
配置安全策略
FW1
security-policy
 rule name Trust_ISP
  description NAT
  source-zone trust
  source-address address-set PC
  action permit
FW2
security-policy
 rule name Trust_ISP
  description NAT
  source-zone trust
  action permit
配置NAT策略
FW1
nat address-group isp1 0
 mode pat
 section 0 100.100.100.1 100.100.100.2
nat address-group isp2 1
 mode pat
 section 0 200.200.200.1 200.200.200.2
nat-policy
 rule name NO_NAT_ISP1
  source-zone trust
  source-address 192.168.10.0 mask 255.255.255.0
  source-address 192.168.20.0 mask 255.255.255.0
  source-address 192.168.30.0 mask 255.255.255.0
  source-address 192.168.40.0 mask 255.255.255.0
  destination-address 10.20.0.0 mask 255.255.0.0
  action no-nat
 rule name NO_NAT_ISP2
  source-zone trust
  action no-nat
 rule name NAT_ISP1
  source-zone trust
  action source-nat address-group isp1
 rule name NAT_ISP2
  source-zone trust
  action source-nat address-group isp2
FW2
 mode pat
 mode pat
nat-policy
  source-zone trust
  action no-nat
  source-zone trust
  action no-nat
 rule name NAT_ISP1
  source-zone trust
 rule name NAT_ISP2
  source-zone trust
SNMP配置
FW1
snmp-agent session-rate trap threshold 100
FW2
IPsec配置
步骤一:配置ACL
FW1
acl number 3000
 rule 5 permit ip source 192.168.0.0 0.0.255.255 destination 10.20.100.0 0.0.0.255
acl number 3001
FW2
acl number 3000
acl number 3001
步骤二:配置IPsec proposal
这是IKE阶段二的策略,在阶段二的策略中安全协议采用ESP,加密算法使用aes-256,验证算法使用sha2-256
FW1
ipsec proposal prop23101638529
 encapsulation-mode auto
 esp authentication-algorithm sha2-256
 esp encryption-algorithm aes-256
ipsec proposal prop23101639469
FW2
步骤三:配置IKE proposal
配置IKE Proposal,这是IKE阶段一的策略,在FW1/FW2上部署的相关策略均需与FW3相匹配。IKE阶段一的策略中,身份验证使用的是预共享的认证方式,验证算法使用的是sha2-256,加密算法使用aes-256
FW1
ike proposal 1
 dh group14
 authentication-method pre-share
 integrity-algorithm hmac-sha2-256
 prf hmac-sha2-256
ike proposal 2
 dh group14
 prf hmac-sha2-256
FW2
ike proposal 1
 dh group14
 prf hmac-sha2-256
ike proposal 2
 dh group14
 prf hmac-sha2-256
步骤四:配置IKE peer
定义预共享秘钥、关联IKE proposal并指定隧道对端节点IP
FW1
ike peer ike231016385293
 exchange-mode auto
 pre-shared-key 123.abc
 ike-proposal 1
 local-id-type fqdn
 remote-id-type none
 local-id C1
 dpd type periodic
 ike negotiate compatible
ike peer ike231016394699
 exchange-mode auto
 ike-proposal 2
 local-id-type fqdn
 remote-id-type none
 local-id c2
 dpd type periodic
FW2
 exchange-mode auto
 ike-proposal 1
 local-id-type fqdn
 remote-id-type none
 local-id C1
 dpd type periodic
 exchange-mode auto
 ike-proposal 2
 local-id-type fqdn
 remote-id-type none
 local-id C2
 dpd type periodic
步骤五:配置IPsec Policy
创建ipsec policy,绑定ipsec proposal、Ike peer、ACL感兴趣流、配置本地站点地址。
FW1
ipsec policy-template tpl231016385293 1
 security acl 3000
 ike-peer ike231016385293
 tunnel local 100.100.100.5
 alias IPsec-1
 sa duration traffic-based 10485760
 sa duration time-based 3600
 route inject dynamic
ipsec policy-template tpl231016394699 1
 security acl 3001
 ike-peer ike231016394699
 tunnel local 200.200.200.5
 alias IPsec-2
ipsec policy ipsec2310163852 10000 isakmp template tpl231016385293
ipsec policy ipsec2310163946 10000 isakmp template tpl231016394699
FW2
 security acl 3000
 alias IPsec-1
 security acl 3001
 alias IPsec-2
步骤六:应用IPsec Policy到接口
FW1
int g1/0/5
ipsec policy ipsec2310163852 master
int g1/0/6
ipsec policy ipsec2310163946 slave
FW2
int g1/0/5
ipsec policy ipsec2310163852 slave
int g1/0/6
ipsec policy ipsec2310163946 master
步骤七:配置策略
FW1
#基于策略路由
policy-based-route
 rule name Trust_DMZ 1
  source-zone trust
  destination-address address-set Web_IP
  action pbr next-hop 192.168.90.3
 rule name ISP1 2
  source-zone trust
  action pbr egress-interface GigabitEthernet1/0/5 next-hop 100.100.100.100
 rule name ISP2 3
  source-zone trust
  action pbr egress-interface GigabitEthernet1/0/6 next-hop 200.200.200.200
#安全策略配置
security-policy
 rule name ISP_Local
  description IPSec
  source-zone ISP1
  source-zone ISP2
  destination-address 100.100.100.5 mask 255.255.255.255
  destination-address 200.200.200.5 mask 255.255.255.255
  action permit
 rule name ISP_Trust
  description VPN
  source-zone ISP1
  source-zone ISP2
  destination-address 192.168.0.0 mask 255.255.0.0
  action permit
FW2
#基于策略路由
policy-based-route
  source-zone trust
 rule name ISP1 2
  source-zone trust
 rule name ISP2 3
  source-zone trust
#安全策略配置
security-policy
 rule name ISP_Local
  description IPSec
  source-zone ISP1
  source-zone ISP2
  action permit
 rule name ISP_Trust
  description VPN
  source-zone ISP1
  source-zone ISP2
  action permit
L2TP配置
打开防火墙的web界面,依次选择 对象->用户->default,然后新建一个用于登录L2TP VPN的用户,再点击应用。
FW1
l2tp enable
aaa
 service-scheme webServerScheme1649076535499
  quit
 domain default
  service-type l2tp ike
  internet-access mode password
  reference user current-domain
 manager-user password-modify enable
 manager-user audit-admin
  password cipher Blue@123
  service-type web terminal
  level 15
l2tp-group 1
tunnel password cipher blue@123
tunnel name LNS
allow l2tp virtual-template 1 remote L2TP-Client domain default
interface Virtual-Template0
 ppp authentication-mode chap
 y
 remote address 172.16.1.10
 ip address 172.16.1.1 255.255.255.0
路由配置
接口配置地址
ISP
int g0/0/1
 ip add 10.10.100.3 24
int g0/0/2
 ip add 10.10.200.3 24
int g0/0/3
 ip add 150.150.150.1 24
int e0/0/0
 ip add 8.8.8.1 24
int e0/0/1
 ip add 192.168.94.50 24
ISP_1
int g0/0/1
 ip add 100.100.100.100 24
int g0/0/2
 ip add 10.10.100.1 24
ISP_2
int g0/0/1
 ip add 200.200.200.200 24
int g0/0/2
 ip add 10.10.200.2 24
配置IS-IS
ISP
int  loopback 0
 ip add 3.3.3.3 32
isis 26
 network-entity 49.0010.0030.0300.3003.00
 is-level level-2
 cost-style wide
 log-peer-change topology
int g0/0/1
 isis enable 26
int g0/0/2
 isis enable 26
int g0/0/3
 isis enable 26
int e0/0/0
 isis enable 26
int e0/0/1
 isis enable 26
int loopback 0
 isis enable 26
ISP_1
int loopback 0
 ip add 1.1.1.1 32
isis 26
 is-level level-2
 cost-style wide
 network-entity 49.0010.0010.0100.1001.00
int g0/0/1
 isis enable 26
int g0/0/2
 isis enable 26
int loopback 0
 isis enable 26
ISP_2
int loopback 0
 ip add 2.2.2.2 32
isis 26
 is-level level-2
 cost-style wide
 network-entity 49.0010.0020.0200.2002.00
int  g0/0/1
 isis enable 26
int g0/0/2
 isis enable 26
int loopback 0
 isis enable 26
子公司配置
防火墙
初始化配置
用户名:admin
原始密码:Admin@123
密码:Blue@123
sys
sysname FW3
int g0/0/0
ip add 192.168.94.4 24
规划网段
int g1/0/0
 undo shutdown
 ip add 150.150.150.150 255.255.255.0
int g1/0/1
 undo shutdown
 ip add 10.20.100.254 255.255.255.0
#创建Tunnel接口并绑定接口
int Tunnel1
 ip add unnumbered int g1/0/0
 alias Tunnel1
int Tunnel2
 alias Tunnel2
规划安全区域
firewall zone trust
 add interface GigabitEthernet1/0/1
firewall zone untrust
 add interface GigabitEthernet1/0/0
 add interface Tunnel1
 add interface Tunnel2
指定链路接口组名称
安全策略配置
#基础协议控制开关
#安全策略
security-policy
 rule name Trust_Untrust
  source-zone trust
  destination-zone untrust
  action permit
配置IP-Link
ip-link name link_100
 destination 100.100.100.5 interface GigabitEthernet1/0/1 mode icmp
ip-link name link_200
 destination 200.200.200.5 interface GigabitEthernet1/0/1 mode icmp
配置静态路由
ip route-static 0.0.0.0 0.0.0.0 150.150.150.1
ip route-static 192.168.0.0 255.255.0.0 NULL0
ip route-static 192.168.10.0 255.255.255.0 Tunnel1 preference 10 track ip-link link_100
ip route-static 192.168.10.0 255.255.255.0 Tunnel2 preference 20
ip route-static 192.168.20.0 255.255.255.0 Tunnel1 preference 10 track ip-link link_100
ip route-static 192.168.20.0 255.255.255.0 Tunnel2 preference 20
ip route-static 192.168.30.0 255.255.255.0 Tunnel2 preference 10 track ip-link link_200
ip route-static 192.168.30.0 255.255.255.0 Tunnel1 preference 20
ip route-static 192.168.40.0 255.255.255.0 Tunnel2 preference 10 track ip-link link_200
ip route-static 192.168.40.0 255.255.255.0 Tunnel1 preference 20
NAT配置
#配置NAT策略
nat-policy
 rule name NO_NAT
  source-zone trust
  source-address 10.20.100.0 mask 255.255.255.0
  action no-nat
 rule name NAT
  source-zone trust
  action source-nat easy-ip
配置IPSec VPN
步骤一:配置ACL
acl number 3000
 rule 5 permit ip source 10.20.100.0 0.0.0.255 destination 192.168.0.0 0.0.255.255
acl number 3001
步骤二:配置IPSec proposal
ipsec proposal prop23101712198
ipsec proposal prop23101713129
步骤三:配置IKE proposal
ike proposal 1
 dh group14
 prf hmac-sha2-256
ike proposal 2
 dh group14
 prf hmac-sha2-256
步骤四:配置IKE peer
ike peer ike231017121983
 exchange-mode auto
 ike-proposal 1
 local-id-type fqdn
 remote-id-type none
 local-id Br1
 dpd type periodic
 remote-address 100.100.100.5
ike peer ike231017131292
 exchange-mode auto
 ike-proposal 2
 local-id-type fqdn
 remote-id-type none
 local-id Br2
 dpd type periodic
 remote-address 200.200.200.5
步骤五:配置IPSec Policy
ipsec policy ipsec2310171219 1 isakmp
 security acl 3000
 ike-peer ike231017121983
 tunnel local applied-interface
 alias IPSec-1
 sa trigger-mode auto
ipsec policy ipsec2310171312 1 isakmp
 security acl 3001
 ike-peer ike231017131292
 alias IPSec-2
步骤六:应用IPSec Policy到接口
int Tunnel1
 tunnel-protocol ipsec
int Tunnel2
步骤七:配置策略
security-policy
 rule name Local_Untrust
  description IPSEC UPD500
  source-zone local
  action permit
 rule name Untrust_Local
  description IPSec_esp
  source-zone untrust
  source-address 100.100.100.5 mask 255.255.255.255
  source-address 200.200.200.5 mask 255.255.255.255
  action permit
 rule name Untrust_Trust
  description VPN
  source-zone untrust
  source-address 192.168.0.0 mask 255.255.0.0
  destination-address 10.20.100.0 mask 255.255.255.0
  action permit
服务区域DMZ
VLAN+端口配置
LSW9
vlan batch 90
int vlanif90
ip address 192.168.90.3 255.255.255.0
int g0/0/11
port default vlan 90
int g0/0/12
int g0/0/13
int g0/0/1
int g0/0/2
ospf配置
LSW9
int loopback 0
 ip add 192.168.9.9 32
ospf 10 router-id 192.168.9.9
 area 0.0.0.0
  network 192.168.9.9 0.0.0.0
  network 192.168.90.3 0.0.0.0
安全策略配置
FW1
#外网访问服务、防火墙到服务器、内网访问服务
security-policy
 rule name ISP_DMZ
  description WWW
  source-zone ISP1
  source-zone ISP2
  destination-zone dmz
  service dns
  service ftp
  service http
  service icmp
  long-link enable
  long-link aging-time 10
  action permit
 rule name Local_DMZ
  description OSPF
  source-zone local
  destination-address 192.168.90.0 mask 255.255.255.0
  service icmp
  action permit
 rule name Trust_DMZ
  source-zone trust
  service http
  action permit
FW2
security-policy
 rule name ISP_DMZ
  description WWW
  source-zone ISP1
  source-zone ISP2
  service dns
  service ftp
  service http
  service icmp
  long-link enable
  action permit
 rule name Local_DMZ
  description OSPF
  source-zone local
  service icmp
  action permit
 rule name Trust_DMZ
  source-zone trust
  service http
  action permit
服务器负载均衡SLB
FW1
slb enable
slb
 group 0 server
  metric roundrobin
  health-check type icmp
  rserver 1 rip 192.168.90.10 port 80 max-connection 10 description server1
  rserver 2 rip 192.168.90.20 port 80 max-connection 20 description server2
  rserver 3 rip 192.168.90.30 port 80 max-connection 30 description server3
  action optimize
 vserver 0 WEB
  vip 0 100.100.100.5
  vip 1 200.200.200.5
  protocol http
  vport 80
  group server
FW2
slb enable
slb
  group 0 server
   metric roundrobin
   action optimize
  vserver 0 WEB
   vip 0 100.100.100.5
   vip 1 200.200.200.5
   protocol http
   vport 80
   group server
审核编辑 :李倩
