report_timing报告格式如何个性化配置?
1、单次配置
innovus > report_timing
Innovus
innovus > report_timing -format {instance arc transition capacitance delay} -from xx -to yy
灵活性强,但是每次都要带上-format选项
Innovus
2、全局配置
innovus > set_global report_timing_format {instance arc transition capacitance delay}
innovus > report_timing -from xx -to xx
只要设置一次即可,后边report_timing都会用上面设置的格式报告timing。
补充:使用report_timing-format {*} 可以知道一共有多少format可以配置
[DEV]innovus 9> report_timing -early -format {*}
**ERROR: (TCLCMD-1114): Invalid field '*' in format list. Valid fields are :
abs_delay_err abs_slew_err abs_transition_err adjustment
annotation aocv_adj_stages aocv_derate aocv_weight
arc arrival arrival_mean arrival_sigma
cell delay delay_mean delay_sigma
direction edge fanin fanout
flags hpin incr_delay incr_slew
instance instance_location latch_window load
module net pct_delay_err pct_slew_err
pct_transition_err phase phys_info pin
pin_load pin_location power_domain required
retime_delay retime_delay_mean retime_delay_sigma retime_slew
retime_slew_mean retime_slew_sigma retime_transition
retime_transition_mean retime_transition_sigma
slew slew_mean slew_sensitivity
slew_sigma socv_derate spice_arrival spice_delay spice_slew
spice_transition stage_count stolen timing_point total_derate
transition transition_mean transition_sigma
user_derate when_cond wire_load wlmodel
设置report_timing报告的格式
set_global report_timing_format {instance arc cell fanout load slew delay incr_delay arrival}
Innovus
上面的报告默认是有框线的,如果想取消框线,可以用下面的方式:
set_table_style -name report_timing -no_frame -indent 0
report_timing
Innovus
做了上面的设置之后,同一列的内容也不会自动换行,设置前后的对比如下:
Innovus   Innovus
-no_frame的意思就是取消框线。
-indent的意思如下:-indent               # Specifies the number of spaces to leave on the left for that particular table (int, optional)
指定特定表左侧要保留的空格数(int,可选)
默认report_timing中会出现换行的情况,如下图所示,如何避免换行呢?
命令:
set_table_style -name report_timing -no_frame_fix_width -nosplit
Innovus
效果如下图所示:
Innovus
两个option的详细解释如下:
-no_frame_fix_width             # Specifies that the table columns have a fixed minimum width, but no maximum width (bool, required)
-nosplit                        # Specifies that each column follows the preceding column without splitting to a new line, if the data in one column overruns the next column (bool, optional)
审核编辑:刘清
