VASS标准-涂胶不合格重涂的编写
   ;FOLD Label 1 ;%{PSE}%MKUKATPVW,%CCONTROL,%VLABEL,%P 1:Label, 2:Label 1
      ;FOLD  ;%{H}
         Label1:
      ;ENDFOLD
   ;ENDFOLD
   ;FOLD PTP VB=100% VE=0% ACC=100% RobWzg=1 Base=0 SPSTrig=5[1/100s] PU ;%{P}%MKUKATPVW,%CMOVE8,%VPTP,%P 1:1, 2: VB=, 3:100, 4:%, 5: VE=, 6:0, 7:%, 8: ACC=, 9:100, 10:%, 11: RobWzg=, 12:1, 13: Base=, 14:0, 15: SPSTrig=, 16:5, 17:[1/100s], 18: PU, 19:2, 20:-1, 21:3
      ;FOLD 1: FB PSPS = EIN ;%{SE}%MKUKATPVW %CVW_SPS %VFBPSPS %P 2:FB PSPS = EIN,3:FBPSPS
      ;ENDFOLD
      ;FOLD 2: A23 = AUS ;%{SE}%MKUKATPVW %CVW_SPS %VBOASG %P 2:A23 = AUS,3:BOASG
      ;ENDFOLD
      ;FOLD 3: SPSLabel 1 重复清胶;%{SE}%MKUKATPVW %CCONTROL %VLABEL %P 2:SPSLabel 1,3:LABEL
      ;ENDFOLD
      ;FOLD 4: SPSMAKRO183 = E1534 + E163 E1534请求清胶 + E163选择清胶;%{SE}%MKUKATPVW %CVW_SPS %VMAKRO %P 2:SPSMAKRO183 = E1534 + E163,3:MAKRO
      ;ENDFOLD
      ;FOLD 5: GOTO SPSLabel 2 = E15 ;%{SE}%MKUKATPVW %CCONTROL %VJUMP %P 2:GOTO SPSLabel 2 = E15,3:JUMP
      ;ENDFOLD
      ;FOLD 6: GOTO SPSLabel 1 = E1534 请求清胶;%{SE}%MKUKATPVW %CCONTROL %VJUMP %P 2:GOTO SPSLabel 1 = E1534,3:JUMP
      ;ENDFOLD
      ;FOLD 7: SPSLabel 2 ;%{SE}%MKUKATPVW %CCONTROL %VLABEL %P 2:SPSLabel 2,3:LABEL
      ;ENDFOLD
      ;FOLD 8: WARTE BIS E23 ;%{SE}%MKUKATPVW %CVW_SPS %VWBOASG %P 2:WARTE BIS E23,3:WBOASG
      ;ENDFOLD
      ;FOLD 9: A23 = EIN ;%{SE}%MKUKATPVW %CVW_SPS %VBOASG %P 2:A23 = EIN,3:BOASG
      ;ENDFOLD
      ;FOLD 10: FB PSPS = M30 ;%{SE}%MKUKATPVW %CVW_SPS %VFBPSPS %P 2:FB PSPS = M30,3:FBPSPS
      ;ENDFOLD
      ;FOLD UP70 = EIN   开始涂胶;%{SE}%MKUKATPVW %CVW_SPS %VUP %P 2:UP70 = EIN,3:UP
      ;ENDFOLD
      ;FOLD UP71 = F343 + E162
UP71 涂胶展示 / F343 = !E1526(涂胶不合格)+ E162选择展示 ;%{SE}%MKUKATPVW %CVW_SPS %VUP %P 2:UP71 = F343 + E162,3:UP
      ;ENDFOLD
      ;FOLD UP120 = (E1534 + E163) & !E15  UP120清胶;%{SE}%MKUKATPVW %CVW_SPS %VUP %P 2:UP120 = (E1534 + E163) & !E15,3:UP
      ;ENDFOLD
      ;FOLD {H}
         VW_MPARA_ACT=P2_D
         Act_P1 = P2
         Act_P2 = P2
         VW(#MPARA,TRUE)
         SPS_FERTIG=FALSE
         TRIGGER WHEN DISTANCE=1 DELAY=-50 DO SPS_TRIG(3) PRIO=-1
         PTP P2
         $ADVANCE=1
         WAIT FOR SPS_FERTIG
         SEL_RES=SELECT(#UP,70,TRUE)
         SEL_RES=SELECT(#UP,71,$FLAG[343] OR $IN[162])
         SEL_RES=SELECT(#UP,120,($IN[1534] OR $IN[163]) AND NOT $IN[15])
      ;ENDFOLD
   ;ENDFOLD
   ;FOLD GOTO Label 1 = F343 (涂胶不合格)返回上一步
VASS图解:
;%{PSE}%MKUKATPVW,%CCONTROL,%VJUMP,%P 1:GOTO Label, 2:1, 3:=, 4:6, 5:343
      ;FOLD  ;%{H}
         CONTINUE
         IF $FLAG[343] THEN
            CONTINUE
            GOTO Label1
         ENDIF
      ;ENDFOLD
   ;ENDFOLD
搅拌器
搅拌器
'Option' (STRING)
必须根据过程设备所位于的机器人地址区,在这里组态正确的选件。
'Option'的设置:
粘贴 1  KL1  'C'
粘贴 2  KL2  'D'
粘贴 3  KL3  'E'
'Layer' (INT)
该可视化对象在某个特定层中。可视化功能将其层号发送给 PLC。为了正确地执行全局选择,该块必须知道可视化对象所处的层。
选件 C (KL1):'E161  过程处于活跃状态' = True
'Ex_LM' (WORD)
操作粘贴控制的外部键中的指示灯采用 'Ex_LM' 进行组态。
'Vorw' (BOOL) 预警。
搅拌器
选件 C (KL1):'A165  预警未决' = True-
选件 C (KL1):'E166  容器预警' = True
'Stoexx' (BOOL) 故障。
搅拌器
选件 C (KL1):'A167  过程温度未到'
选件 C (KL1):'A168  加热/泵/配料装置故障'
选件 C (KL1):'A169  胶粘不良'
选件 C (KL1):'A175  未就绪'
选件 C (KL1):"A176  组故障"
'ST_ROB' (ST_Rob)
机器人结构。包含完整的机器人接口。通过该结构,可从过程设备读出数据,和将数据写入到过程设备中。
'ST_PG' (ST_PG)
过程设备结构。机器人块( FB_Rob ) 和过程设备块之间的通信。
'ST_BA' (ST_Betriebsarten)
运行模式结构。内含确认信号。
'ST_Meld' (ST_Meldungen)
消息结构。进入报警系统中的各种消息需要使用该结构。
报警系统
该块可生成以下错误消息:
过程温度未到             STE  过程信号:过程温度未到
加热/泵/配料装置出现故障 STE  过程信号:加热/泵/配料装置出现故障
胶粘不良                 STE  过程信号:胶粘不良
未准备好                 STE  过程信号:未准备好
组故障                   STE  过程信号:组故障
预警未决                 MS1  过程信号:预警未决
容器预警                 MS1  过程信号:容器预警
已去选                   MT0  过程已被去选
用于显示                 MT1  过程信号:用于显示
用于漂洗                 MT1  过程信号:用于漂洗
机器人和过程设备的接口
E/A 161 无胶粘选择    -过程处于活跃状态
E/A 162 显示选择      -用于显示
搅拌器
E/A 163 漂洗/  漂洗选择  -漂洗
搅拌器
E/A 164打开节能模式  -节能模式已打开
搅拌器
E/A 165选择枪 3  -预警未决
E/A 166选择枪 1  -容器预警
搅拌器E166
搅拌器A166
E/A 167选择枪 2  -过程温度未到
E/A 168启动加热/ 仓式泵   -加热/泵/配料装置出现故障
搅拌器
E/A 169零件正常   -胶粘不良
搅拌器A169胶粘不良
搅拌器E169 涂胶合格
E/A 170零件后续加工   --(-搅拌器中)
搅拌器 E170  零件后续加工,重新涂一次胶
E/A 171拒收零件  --漂洗
搅拌器
E/A 172漂洗选择     --(搅拌器中)
E/A 173搅拌器更换请求  --控制测量已完成
E/A 174重量选择  --空秤
审核编辑:刘清
