计算机系统对数值类型的编码、运算、转换原理介绍4
数值类型转换
数值类型间的转换,可以分成 2 类: 宽转换 (Widening Conversion)和 窄转换 (Narrowing Conversion)。
宽转换指往表示范围更广的类型转换,比如从 int 到 long、从 long 到 float;窄转换则相反。
整型间转换
(1)宽转换
整型间的宽转换不会产生溢出,无符号整数场景,高位补零;有符号整数场景,高位补符号位。
// C++
int main() {
    int8_t i1 = 100;
    cout << "int8_t  i1: " << bitset<8>(i1) << endl;
    cout << "int16_t i1: " << bitset<16>((int16_t) i1) << endl;
    int8_t i2 = -100;
    cout << "int8_t  i2: " << bitset<8>(i2) << endl;
    cout << "int16_t i2: " << bitset<16>((int16_t) i2) << endl;
    uint8_t i3 = 200;
    cout << "uint8_t  i3: " << bitset<8>(i3) << endl;
    cout << "uint16_t i3: " << bitset<16>((uint16_t) i3) << endl;
    return 0;
// 输出结果
int8_t  i1: 01100100
int16_t i1: 0000000001100100
int8_t  i2: 10011100
int16_t i2: 1111111110011100
uint8_t  i3: 11001000
uint16_t i3: 0000000011001000
(2)窄转换
整型间的窄转换直接进行高位截断,只保留低 n 位。比如 16 位的 int16 转换为 8 位的 int8,直接保留 int16 类型值的低 8 位作为转换结果。
// C++
int main() {
    int16_t i1 = 200;
    cout << "int16_t i1: " << bitset<16>(i1) << endl;
    cout << "int8_t  i1: " << bitset<8>((int8_t) i1) << endl;
    int16_t i2 = -200;
    cout << "int16_t i2: " << bitset<16>(i2) << endl;
    cout << "int8_t  i2: " << bitset<8>((int8_t) i2) << endl;
    uint16_t i3 = 300;
    cout << "uint16_t i3: " << bitset<16>(i3) << endl;
    cout << "uint8_t  i3: " << bitset<8>((uint8_t) i3) << endl;
    return 0;
// 输出结果
int16_t i1: 0000000011001000
int8_t  i1: 11001000
int16_t i2: 1111111100111000
int8_t  i2: 00111000
uint16_t i3: 0000000100101100
uint8_t  i3: 00101100
(3)无符号整数与有符号整数间的转换
无符号整数与有符号整数间的转换规则是:
  • 如果两者二进制位数一致,比如 int8uint8 的转换,则二进制数值不变,只是改变编码方式;
  • 如果位数不一致,比如 int16uint8 的转换,则二进制数值,先按照宽转换或窄转换规则转换,再改变编码方式。
// C++
int main() {
    uint8_t i1 = 200;
    cout << "uint8_t i1, decimal: " << +i1 << ", binary: " << bitset<8>(i1) << endl;
    cout << "int8_t  i1, decimal: " << +(int8_t) i1 << ", binary: " << bitset<8>((int8_t) i1) << endl;
    int16_t i2 = -300;
    cout << "int16_t i2, decimal: " << +i2 << ", binary: " << bitset<16>(i2) << endl;
    cout << "uint8_t i2, decimal: " << +(uint8_t) i2 << ",  binary: " << bitset<8>((uint8_t) i2) << endl;
    return 0;
// 输出结果
uint8_t i1, decimal: 200, binary: 11001000
int8_t  i1, decimal: -56, binary: 11001000
int16_t i2, decimal: -300, binary: 1111111011010100
uint8_t i2, decimal: 212,  binary: 11010100
整数与浮点数间转型
(1)宽转换
整型到浮点数类型的转换这一方向,为宽转换:
  • 如果浮点数的精度,能够表示整数,则正常转换。
  • 如果浮点数精度,无法表示整数,则需要近似,会导致精度丢失。
// Java
public static void main(String[] args) {
    int i1 = 1234567;
    System.out.printf("int i1: %d, float i1: ", i1);
    System.out.println((float) i1);
    int i2 = 123456789;
    System.out.printf("int i2: %d, float i2: ", i2);
    System.out.println((float) i2);
// 输出结果
int i1: 1234567, float i1: 1234567.0
int i2: 123456789, float i2: 1.23456792E8
上述例子中,i2=123456789 超过 float 类型能够表示的精度,所以为近似后的结果 1.23456792E8
那么,为什么 123456789 会近似为 1.23456792E8
要解释该问题,首先要把它们转换成二进制表示:
    System.out.println("int i2:   " + int2BinaryStr(i2));
    System.out.println("float i2: " + float2BinaryStr((float) i2));
// 输出结果
int i2:   00000111010110111100110100010101
float i2: 01001100111010110111100110100011
接下来,我们根据 IEEE 浮点数的编码规则,尝试将 int i2 转换成 float i2
  1. int i2 的二进制 ,可以写成 ,对应到 的形式,可以确认 s = 0,E = 26,M = 1.11010110111100110100010101。
  2. float 类型中 k = 8,有,,得出 e = 153,按 k 位无符号编码表示为 。
  3. 同理,由 ,但由于 float 类型的 n = 23,而 m 一共有 26 位,因此需要按照 round-to-even 规则,对 0.11010110111100110100010101进行近似,保留 23 位小数,得到 0.11010110111100110100011,所以 m 为
  4. 最后,将 s、e、m 按照 float 单精度的编码格式组合起来,就是 ,转换成十进制,就是 1.23456792E8
(2)窄转换
浮点数类型到整型的转换这一方向,为窄转换:
  • 如果浮点数的整数部分,能够用整型表示,则直接舍去小数,保留整数部分。
  • 如果超出了整型范围,则结果为该整型的最大/最小值。
// Java
    float f1 = 12345.123F;
    System.out.print("float f1: ");
    System.out.print(f1);
    System.out.printf(",  int f1: %d\\n", (int) f1);
    float f2 = 1.2345E20F;
    System.out.print("float f2: ");
    System.out.print(f2);
    System.out.printf(",  int f2: %d\\n", (int) f2);
    float f3 = -1.2345E20F;
    System.out.print("float f3: ");
    System.out.print(f3);
    System.out.printf(", int f3: %d\\n", (int) f3);
// 输出结果
float f1: 12345.123,  int f1: 12345
float f2: 1.2345E20,  int f2: 2147483647
float f3: -1.2345E20, int f3: -2147483648
浮点数间转型
(1)宽转换
单精度 float 到 双精度 double 为宽转换,不会出现精度丢失的问题。
对于 ,规则如下:
  • s 保持不变。
  • 在 E 保持不变的前提下,因为 float 的 k = 8,而 double 的 k = 11,所以两者的 e 会有所不同。
  • 在 M 保持不变的前提下,float 的 n = 23,而 double 的 n =52,所以 m 需要低位补 52 - 23 = 29 个 0。
// Java
    float f1 = 1.2345E20F;
    System.out.print(", double f1: ");
    System.out.println((double) f1);
    System.out.println("float  f1: " + float2BinaryStr(f1));
    System.out.println("double f1: " + double2BinaryStr((double) f1));
// 输出结果
float  f1: 1.2345E20, double f1: 1.2344999897320129E20
float  f1: 01100000110101100010011011010000
double f1: 0100010000011010110001001101101000000000000000000000000000000000
计算机
(2)窄转换
doublefloat 为窄转换,会存在精度丢失问题。
如果 double 值超出了 float 的表示范围,则转换结果为 Infinity
// Java
    double d1 = 1E200;
    System.out.print("double d1: ");
    System.out.println(d1);
    System.out.print("float d1: ");
    System.out.println((float) d1);
    double d2 = -1E200;
    System.out.print("double d2: ");
    System.out.println(d2);
    System.out.print("float d2: ");
    System.out.println((float) d2);
// 输出结果
double d1: 1.0E200
float d1: Infinity
double d2: -1.0E200
float d2: -Infinity
如果 double 值还在 float 的表示范围内,则按照如下转换规则:
  • s 保持不变。
  • 对于 M,因为 float 的 n = 23,而 double 的 n = 52,所以转换到 float 之后,需要进行截断,只保留高 23 位。
// Java
    double d1 = 3.267393471324506;
    System.out.println("double d1: " + double2BinaryStr(d1));
    System.out.println("float  d1: " + float2BinaryStr((float) d1));
// 输出结果
double d1: 3.267393471324506
float  d1: 3.2673936
double d1: 0100000000001010001000111001111100110000001101000000010101110110
float  d1: 01000000010100010001110011111010
计算机
最后
本文花了很长的篇幅,深入介绍了计算机系统对数值类型的编码、运算、转换的底层原理。
数值类型间的转换是最容易出现隐藏 bug 的地方 ,特别是无符号整数与有符号整数之间的转换。所以,很多现代的编程语言,如 Java、Go 等都不再支持无符号整数,根除了该隐患。
另外,浮点数的编码方式,注定它只能精确表示一小部分的数值范围,大部分都是近似,所以才有了不能用等号来比较两个浮点数的说法。
数值类型虽然很基础,但使用时一定要多加小心。希望本文能够加深你对数值类型的理解,让你写出更健壮的程序。
