时钟芯片SH5195B
消耗积分:0 | 格式:exe | 大小: | 2011-07-26
朱工
分享资料个
3. GENERAL DATA
(1) Product Name
(2) Module Dimensions
(3) Active Area Dimensions
(4) Pixel Pitch
(5) Resolution
(6) Color Pixel Arrangement
(7) Display Mode
(8) Number of Colors
(9) View ing Direction
(10) Backlight
(11) Weight
(12) Pow er Supply Voltage
(13) Interface I/O pow er supply
Note (1)
(14) LCD Driver IC
(15) Interface
3-1/1
TX05D125VM0AAA
46.0 (W) mmx 63.05 (H) mmx 1.9 (t) mm
40.8 (W) mmx 30.6 (H) mm
0.1275 (W) mmx 0.1275 (H) mm
320 x 3 (R,G,B)(W) x 240(H) dots
RGB Vertical Stripe
Transmissive Type, Normally Black Mode, In-Plane Sw itching Mode
65,536 Colors / 262,144 Colors
Light Emitting Diode (LED), FourLEDs are parallel connection
Backlight current : 20 mA/LED (typ)
6.5 g (typ)
VDD= 2.8 V (typ)
IOVCC = 1.8 V to VDD(1.8 V
评论(0)
发评论
下载排行榜
