如何利用NAT技术隐藏GRE报文中的源地址信息?
制造/封装
541人已加入
组网及说明
GRE
注:如无特别说明,描述中的 FW1 或 MSR1 对应拓扑中设备名称末尾数字为 1 的设备,FW2 或 MSR2 对应拓扑中设备名称末尾数字为 2 的设备,以此类推;另外,同一网段中,IP 地址的主机位为其设备编号,如 FW1 的 g0/0 接口若在 192.168.1.0/24 网段,则其 IP 地址为 192.168.1.1/24,以此类推。
实验需求
由于GRE报文为明文封装,在网络中传输容易被监听导致信息泄漏。基于此,本案例提供一种方案,使用NAT技术隐藏客户端源地址。
配置步骤
FW1
 nat static inbound 192.168.13.3 1.1.1.1 acl 3000 reversible
interface LoopBack0
 ip address 192.168.12.1 255.255.255.255
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip address 192.168.1.1 255.255.255.0
 nat outbound
interface GigabitEthernet1/0/1
 combo enable copper
 ip address 192.168.13.1 255.255.255.0
 nat static enable
interface Tunnel0 mode gre
 ip address 10.1.1.1 255.255.255.0
 source 192.168.12.1
 destination 192.168.12.2
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/1
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/0
 import interface Tunnel0
security-zone name Management
 ip route-static 1.1.1.1 32 192.168.13.3
 ip route-static 1.1.1.2 32 Tunnel0
 ip route-static 192.168.12.2 32 192.168.1.2
 ip route-static 192.168.24.4 32 Tunnel0
acl advanced 3000
 rule 5 permit ip source 192.168.13.3 0 destination 1.1.1.2 0
 session statistics enable
 ip http enable
 ip https enable
security-policy ip
 rule 0 name any
  action pass
FW2
 nat static inbound 192.168.24.4 1.1.1.2 acl 3000 reversible
interface LoopBack0
 ip address 192.168.12.2 255.255.255.255
 combo enable copper
 ip address 192.168.1.2 255.255.255.0
 nat outbound
 combo enable copper
 ip address 192.168.24.2 255.255.255.0
 nat static enable
 ip address 10.1.1.2 255.255.255.0
 source 192.168.12.2
 destination 192.168.12.1
 ip route-static 1.1.1.1 32 Tunnel0
 ip route-static 1.1.1.2 32 192.168.24.4
 ip route-static 192.168.12.1 32 192.168.1.1
 ip route-static 192.168.13.3 32 Tunnel0
acl advanced 3000
 rule 5 permit ip source 192.168.24.4 0 destination 1.1.1.1 0
 ip http enable
 ip https enable
security-policy ip
 rule 0 name any
  action pass
配置关键点
注意事项:需要注意添加对应的静态路由
以R3访问R4为例,访问过程如下:
FW1上的业务点
NAT转换:
 192.168.13.3:10965 -         1.1.1.2: 2048(VPN:    0) ------>
         1.1.1.1:10965 -         1.1.1.2: 2048(VPN:    0)
GRE封装:
192.168.12.1  -           192.168.12.2
W2上的业务点
GRE解封装:
NAT转换:
1.1.1.1:10965 -         1.1.1.2: 2048(VPN:    0) ------>
1.1.1.1:10965 -    192.168.24.4: 2048(VPN:    0)
审核编辑:刘清
  • 相关推荐
  • 热点推荐
  • NAT
  • GRE
