英飞凌PSC62低功耗温湿度数据采集
目的
驱动hs3003温湿度传感器,采集完数据后进入深度睡眠模式,以达到节能的目的。
实现步聚
1、打开rtthreadsettings, 添加hs300x模块:
英飞凌
2、添加初始化代码:
#define HS300X_I2C_BUS  "i2c1"
int rt_hw_hs300x_port(void)
    struct rt_sensor_config cfg;
    cfg.intf.dev_name  = HS300X_I2C_BUS;
    cfg.intf.user_data = (void *)HS300X_I2C_ADDR;
    rt_hw_hs300x_init("hs300x", &cfg);
    return RT_EOK;
INIT_ENV_EXPORT(rt_hw_hs300x_port);
3、修改主程序代码如下:
#include
#include
#include "sensor_renesas_hs300x.h"
#include "drv_gpio.h"
#define LED_PIN     GET_PIN(0, 0)
#define USE_SECONDS_FOR_ALARM 30
#define LONG_GLITCH_DELAY_MS        100u    /* in ms */
#define RTC_INTERRUPT_PRIORITY      3u
void set_rtc_alarm_date_time(void);
cyhal_rtc_t rtc_obj;
extern struct hs300x_device temp_humi_dev;
int main(void)
    cy_rslt_t result;
    float temp_f, humi_f;
    __enable_irq();
    rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT);
    rt_thread_mdelay(500);
    /* Initialize RTC */
    cyhal_rtc_enable_event(&rtc_obj, CYHAL_RTC_ALARM, RTC_INTERRUPT_PRIORITY, true);
    for (;;)
        rt_kprintf("Go to DeepSleep mode
        set_rtc_alarm_date_time();
        cyhal_system_delay_ms(LONG_GLITCH_DELAY_MS);
//        /* Go to deep sleep */
        cyhal_syspm_deepsleep();
        rt_kprintf("Wakeup from DeepSleep mode
        hs300x_read_data(&temp_humi_dev, &humi_f, &temp_f);
//        /* Set the RTC generate alarm after 10 seconds */
        rt_kprintf("Temp:%2d.%df, Humi:%2d%%
",(int)temp_f,(int)(temp_f*10)%10, (int)humi_f);
实验效果
[I/I2C] I2C bus [i2c1] registered
- RT -     Thread Operating System
 / |      4.1.1 build May 28 2023 12:08:51
 2006 - 2022 Copyright by RT-Thread team
[D/drv.rtc] rtc init success
[D/drv.rtc] RTC: get rtc_time 946684800
[I/sensor] rt_sensor[temp_hs300x] init success
[I/sensor] rt_sensor[humi_hs300x] init success
msh >Go to DeepSleep mode
Temp:29.6f, Humi:77%
用电流表测试深度睡眠相比休眠模式少15MA左右,因为板载的DAP等其他元件在用电,所以还不能测试出来工作电路的电流情况。
审核编辑:汤梓红
