RT-Thread内核对象操作API详解
嵌入式技术
1420人已加入
背景
  • 目的还是学习并熟悉RT-Thread 操作系统。
  • 从最简单的对象管理切入
  • 了解操作系统最基本的组成单位:Object
内核对象API
内核对象的主要操作方法:内核文件:object.c中实现
内核
知识点
查看内核文件:object.c,发现的主要的几个知识点
内核
验证与测试
  • 光看内核代码,不如敲一敲(抄一下)。
  • 可以使用模拟器,写几个测试函数,看看对象操作的流程。
测试用例如下:
/* RT-Thread 内核对象学习 */
#include < rtthread.h >
struct _obj_type
    enum rt_object_class_type type;
    const char* name;
/* 静态的对象定义 */
static struct rt_object _obj[] = { 0 };
/* 测试用,线程对象 */
static const struct _obj_type _obj_tbl[] =
    { RT_Object_Class_Thread, "th_01" },
    { RT_Object_Class_Thread, "th_02" },
    { RT_Object_Class_Thread, "th_03" },
    { RT_Object_Class_Thread, "th_04" },
    { RT_Object_Class_Thread, "th_05" },
#define OBJ_TEST_TBL_SIZE       (sizeof(_obj_tbl) / sizeof(_obj_tbl[0]))
/* 静态初始化对象 */
void obj_test_init(void)
    rt_uint8_t index = 0;
    rt_uint8_t obj_size = 0;
    for (index = 0; index < OBJ_TEST_TBL_SIZE; index++)
        rt_object_init(&_obj[index], _obj_tbl[index].type, _obj_tbl[index].name);
/* 动态创建对象 obj_test_create thread1 */
void obj_test_create(uint8_t argc, char** argv)
    struct rt_object* obj = RT_NULL;
    if (argc >= 2)
        rt_kprintf(" obj_name=%s\\n", argv[1]);
    obj = rt_object_find(argv[1], RT_Object_Class_Thread);
    if (obj != RT_NULL)
        rt_kprintf("obj_name=%s, exist!!\\n", obj- >name);
        return;
    else
        rt_object_allocate(RT_Object_Class_Thread, argv[1]);
        rt_kprintf("create obj_name=%s\\n", argv[1]);
/* 对象的打印 */
void obj_test_dump(void)
    struct rt_object* obj_pointers[OBJ_TEST_TBL_SIZE + 10] = { 0 };
    obj_size = rt_object_get_pointers(RT_Object_Class_Thread, obj_pointers, sizeof(obj_pointers));
    rt_kprintf("object init : object size=%d\\n", obj_size);
    rt_kprintf("| index |     name     |  flag  |  type  |\\n");
    rt_kprintf("+-------+--------------+--------+--------+\\n");
    for (index = 0; index < obj_size; index++)
        if (obj_pointers[index] == RT_NULL)
            break;
        rt_kprintf("|  %03d  |  %10s  |   %02d   |  0x%02x  |\\n", index,
            obj_pointers[index]- >name, obj_pointers[index]- >flag,
            obj_pointers[index]- >type);
/* 查找线程对象 */
void obj_test_find(uint8_t argc, char** argv)
    if (argc >= 2)
    if (obj != RT_NULL)
        rt_kprintf("find obj_name=%s\\n", obj- >name);
    else
        rt_kprintf("not find obj_name=%s\\n", argv[1]);
/* 静态对象 detach */
void obj_test_detach(uint8_t argc, char** argv)
    if (argc >= 2)
    if (obj != RT_NULL)
        rt_object_detach(obj);
        rt_kprintf("detach obj_name=%s\\n", obj- >name);
    else
/* 动态对象 delete */
void obj_test_delete(uint8_t argc, char** argv)
    if (argc >= 2)
    if (obj != RT_NULL)
        rt_object_delete(obj);
        rt_kprintf("delete obj_name=%s\\n", obj- >name);
    else
/* 导出命令 */
MSH_CMD_EXPORT(obj_test_init, object init test);
MSH_CMD_EXPORT(obj_test_create, obj create test);
MSH_CMD_EXPORT(obj_test_dump, object test dump);
MSH_CMD_EXPORT(obj_test_find, object test find);
MSH_CMD_EXPORT(obj_test_detach, object test detach);
MSH_CMD_EXPORT(obj_test_delete, object test del);
学习总结
总结一
  • 发现:tshell 是动态创建的线程
  • 发现:tidle 是静态的线程
msh / >obj_test_dump
object init : object size=2
|  000  |      tshell  |   00   |  0x01  |
|  001  |      tidle0  |   00   |  0x81  |
msh / >
总结二
  • 动态对象,创建后,内存占用增加。
  • 动态对象,删除后,内存占用恢复
msh / >free
total memory: 8388580
used memory : 5164  /* 【5164】 内存原有大小 */
maximum allocated memory: 7336
msh / >
msh / >obj
obj_test_init
obj_test_create
obj_test_dump
obj_test_find
obj_test_detach
obj_test_delete
msh / >obj_test_cre
obj_test_create
msh / >obj_test_create hello
 obj_name=hello
create obj_name=hello
msh / >
msh / >fre
free
msh / >free
used memory : 5304   /* 【5304】 内存占用 */
msh / >
msh / >obj_test_delete hello
 obj_name=hello
find obj_name=hello
delete obj_name=hello
msh / >free
used memory : 5164  /* 【5304】,内存占用恢复 */
msh / >
总结三
  • 静态初始化的对象,detach(剔除对象管理)后,内存占用不变。
msh / >obj_test_init
msh / >ob
obj_test_init
obj_test_create
obj_test_dump
obj_test_find
obj_test_detach
obj_test_delete
msh / >obj_test_du
obj_test_dump
object init : object size=7
|  000  |       th_05  |   00   |  0x81  |
|  001  |       th_04  |   00   |  0x81  |
|  002  |       th_03  |   00   |  0x81  |
|  003  |       th_02  |   00   |  0x81  |
|  004  |       th_01  |   00   |  0x81  |
|  005  |      tshell  |   00   |  0x01  |
|  006  |      tidle0  |   00   |  0x81  |
msh / >free
used memory : 5164
msh / >
msh / >obj
obj_test_init
obj_test_create
obj_test_dump
obj_test_find
obj_test_detach
obj_test_delete
msh / >obj_test_deta
obj_test_detach
msh / >obj_test_detach th_04
 obj_name=th_04
find obj_name=th_04
detach obj_name=th_04
msh / >obj_test_du
obj_test_dump
object init : object size=6
|  001  |       th_03  |   00   |  0x81  |
|  002  |       th_02  |   00   |  0x81  |
|  003  |       th_01  |   00   |  0x81  |
|  004  |      tshell  |   00   |  0x01  |
|  005  |      tidle0  |   00   |  0x81  |
msh / >
msh / >free
used memory : 5164
总结
  • RT-Thread 内核对象的管理并不复杂
  • 相关的知识点,如链表的初始化、插入、遍历、通过链表指针获取对象指针等比较的重要。
  • 掌握好内核对象的基本操作,为后面学习派生对象如:线程对象、设备对象等,打下基础。
