rk3588调试之imx415摄像头
一、环境
  • [专栏总目录]
  • soc:rk3588
  • sensor:imx415
  • board: bpi-w3
  • linux:5.10
二、imx415简介
  • 品牌:SONY
  • 型号:IMX415
  • 接口:MIPI CSI
    RK3588
三、驱动移植
瑞芯微支持的摄像头,有个support list,
此次从该list中选择了IMX415
3.1 驱动源文件及对应脚本
RK提供的默认sdk里面已经将支持的所有摄像头驱动都添加到了内核,所以不需要移植该驱动了。
需确认下移植驱动对应的一些信息
  • 源程序
3588_linux/3588_linux5.10_v1.0.5/kernel/drivers/media/i2c/imx415.c 3588_linux/3588_linux5.10_v1.0.5/kernel/drivers/media/i2c/Makefile 3588_linux/3588_linux5.10_v1.0.5/kernel/drivers/media/i2c/Kconfig 3588_linux/3588_linux5.10_v1.0.5/kernel/arch/arm64/configs/rockchip_linxu_defconfig
  • Makefile脚本
obj-$(CONFIG_VIDEO_IMX415) += imx415.o
  • Kconfig脚本
config VIDEO_IMX415
	tristate "Sony IMX415 sensor support"
	depends on I2C && VIDEO_V4L2 && VIDEO_V4L2_SUBDEV_API
	depends on MEDIA_CAMERA_SUPPORT
	help
	  This is a Video4Linux2 sensor driver for the Sony
	  IMX415 camera.
	  To compile this driver as a module, choose M here: the
	  module will be called imx415.
  • 驱动对应的宏开关
CONFIG_VIDEO_IMX415=y
3.2 dts设备树
RK3588
1)摄像头链接示意图
IMX415摄像头与SOC连接的主要的引脚有:i2c、rst、pwdn、mclk、MIPI Clk、MIPI DATA
2)电路图
RK3588
由电路图可知,几个关键引脚关系:
reset信号:gpio4 A0
power0 down信号:gpio1 B0
I2C通道:3
clock:CLK_MIPI_CAMARAOUT_M3
3)设备树节点
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
 * Copyright (c) 2022 Rockchip Electronics Co., Ltd.
	compatible = "radxa,rock-5b", "rockchip,rk3588";
	camera_pwdn_gpio: camera-pwdn-gpio {
		status = "okay";
		compatible = "regulator-fixed";
		regulator-name = "camera_pwdn_gpio";
		regulator-always-on;
		regulator-boot-on;
		enable-active-high;
		gpio = < &gpio1 RK_PB0 GPIO_ACTIVE_HIGH >;
		pinctrl-names = "default";
		pinctrl-0 = < &cam_pwdn_gpio >;
	clk_cam_24m: external-camera-clock-24m {
		status = "okay";
		compatible = "fixed-clock";
		clock-frequency = < 24000000 >;
		clock-output-names = "clk_cam_24m";
		#clock-cells = < 0 >;
&i2c3 {
	status = "okay";
	imx415: imx415@1a {
		status = "okay";
		compatible = "sony,imx415";
		reg = < 0x1a >;
		clocks = < &cru CLK_MIPI_CAMARAOUT_M3 >;
		clock-names = "xvclk";
		pinctrl-0 = < &mipim0_camera3_clk >;
		power-domains = < &power RK3588_PD_VI >;
		pwdn-gpios = < &gpio1 RK_PB0 GPIO_ACTIVE_HIGH >;
		reset-gpios = < &gpio4 RK_PA0 GPIO_ACTIVE_LOW >;
		rockchip,camera-module-index = < 0 >;
		rockchip,camera-module-facing = "back";
		rockchip,camera-module-name = "CMK-OT2022-PX1";
		rockchip,camera-module-lens-name = "IR0147-50IRC-8M-F20";
		port {
			imx415_out0: endpoint {
				remote-endpoint = < &mipidphy0_in_ucam0 >;
				data-lanes = < 1 2 3 4 >;
	camera_imx219: camera-imx219@10 {
		status = "disabled";
		compatible = "sony,imx219";
		reg = < 0x10 >;
		clocks = < &clk_cam_24m >;
		rockchip,camera-module-name = "rpi-camera-v2";
		rockchip,camera-module-lens-name = "default";
		port {
			imx219_out0: endpoint {
				remote-endpoint = < &mipidphy0_in_ucam1 >;
				data-lanes = < 1 2 >;
&csi2_dphy0_hw {
	status = "okay";
&csi2_dphy0 {
	status = "okay";
	ports {
		#address-cells = < 1 >;
		#size-cells = < 0 >;
		port@0 {
			reg = < 0 >;
			mipidphy0_in_ucam0: endpoint@1 {
				reg = < 1 >;
				remote-endpoint = < &imx415_out0 >;
			mipidphy0_in_ucam1: endpoint@2 {
				reg = < 2 >;
				remote-endpoint = < &imx219_out0 >;
		port@1 {
			reg = < 1 >;
			csidphy0_out: endpoint@0 {
				reg = < 0 >;
				remote-endpoint = < &mipi2_csi2_input >;
&mipi2_csi2 {
	status = "okay";
	ports {
		port@0 {
			reg = < 0 >;
			mipi2_csi2_input: endpoint@1 {
				reg = < 1 >;
				remote-endpoint = < &csidphy0_out >;
		port@1 {
			reg = < 1 >;
			mipi2_csi2_output: endpoint@0 {
				reg = < 0 >;
				remote-endpoint = < &cif_mipi2_in0 >;
&rkcif {
	status = "okay";
&rkcif_mipi_lvds2 {
	status = "okay";
	port {
		cif_mipi2_in0: endpoint {
			remote-endpoint = < &mipi2_csi2_output >;
&rkcif_mipi_lvds2_sditf {
	status = "okay";
	port {
		mipi_lvds2_sditf: endpoint {
			remote-endpoint = < &isp0_vir0 >;
&rkcif_mmu {
	status = "okay";
&rkisp0 {
	status = "okay";
&isp0_mmu {
	status = "okay";
&rkisp0_vir0 {
	status = "okay";
	port {
		isp0_vir0: endpoint@0 {
			reg = < 0 >;
			remote-endpoint = < &mipi_lvds2_sditf >;
&pinctrl {
	camera {
		cam_pwdn_gpio: cam-pwdn-gpio {
			rockchip,pins = < 1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up >;
设备树的信息最终转换成i2c_client,并传递给IMX415驱动 imx415_probe(){ compatible = "imx415";与驱动的 of_match_table 保持一致
匹配的是external\\camera_engine_rkaiq\\iqfiles\\isp3x下面的iq文件
四、调试技能
4.1 开机log
root@linaro-alip:/# dmesg | grep imx415
[    2.547754] imx415 3-001a: driver version: 00.01.08
[    2.547767] imx415 3-001a:  Get hdr mode failed! no hdr default
[    2.547819] imx415 3-001a: Failed to get power-gpios
[    2.547826] imx415 3-001a: could not get default pinstate
[    2.547831] imx415 3-001a: could not get sleep pinstate
[    2.547850] imx415 3-001a: supply dvdd not found, using dummy regulator
[    2.547918] imx415 3-001a: supply dovdd not found, using dummy regulator
[    2.547945] imx415 3-001a: supply avdd not found, using dummy regulator
[    2.613843] imx415 3-001a: Detected imx415 id 0000e0
[    2.613890] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_imx415 3-001a:bus type 5
[   18.386174] imx415 3-001a: set fmt: cur_mode: 3864x2192, hdr: 0
[   18.389067] imx415 3-001a: set exposure(shr0) 2047 = cur_vts(2250) - val(203)
4.2 查看IMX415设备
驱动加载成功后,会有以下信息
  • 查看摄像头设备节点:
root@linaro-alip:/rockchip-test# ls /dev/video* -l
crw-rw----+ 1 root video 81,  0  87 15:26 /dev/video0
crw-rw----+ 1 root video 81,  1  87 15:26 /dev/video1
crw-rw----+ 1 root video 81, 10  87 15:26 /dev/video10
crw-rw----+ 1 root video 81, 11  87 15:26 /dev/video11
crw-rw----+ 1 root video 81, 12  87 15:26 /dev/video12
crw-rw----+ 1 root video 81, 13  87 15:26 /dev/video13
crw-rw----+ 1 root video 81, 14  87 15:26 /dev/video14
crw-rw----+ 1 root video 81, 15  87 15:26 /dev/video15
crw-rw----+ 1 root video 81, 16  87 15:26 /dev/video16
crw-rw----+ 1 root video 81, 17  87 15:26 /dev/video17
crw-rw----+ 1 root video 81, 18  87 15:26 /dev/video18
crw-rw----+ 1 root video 81, 19  87 15:26 /dev/video19
crw-rw----+ 1 root video 81,  2  87 15:26 /dev/video2
crw-rw----+ 1 root video 81, 20  87 15:26 /dev/video20
crw-rw----+ 1 root video 81,  3  87 15:26 /dev/video3
crw-rw----+ 1 root video 81,  4  87 15:26 /dev/video4
crw-rw----+ 1 root video 81,  5  87 15:26 /dev/video5
crw-rw----+ 1 root video 81,  6  87 15:26 /dev/video6
crw-rw----+ 1 root video 81,  7  87 15:26 /dev/video7
crw-rw----+ 1 root video 81,  8  87 15:26 /dev/video8
crw-rw----+ 1 root video 81,  9  87 15:26 /dev/video9
lrwxrwxrwx  1 root root       7  87 15:26 /dev/video-camera0 - > video11
-rw-rw----  1 root video      4  87 15:26 /dev/video-dec0
-rw-rw----  1 root video      4  87 15:26 /dev/video-enc0
4.3 查看sys文件系统中文件信息
内核会为摄像头在目录/sys/class/video4linux下分配设备信息描述文件
root@linaro-alip:grep imx415 /sys/class/video4linux/v*/name
root@linaro-alip:/rockchip-test# grep imx415 /sys/class/video4linux/v*/name
/sys/class/video4linux/v4l-subdev2/name:m00_b_imx415 3-001a
root@linaro-alip:/rockchip-test# grep "" /sys/class/video4linux/v*/name | grep mainpath
/sys/class/video4linux/video11/name:rkisp_mainpath
4.4 查看拓扑 media-ctl -d /dev/media0 -p
root@linaro-alip:/rockchip-test# media-ctl -d /dev/media0 -p
Media controller API version 5.10.110
Media device information
driver          rkcif
model           rkcif-mipi-lvds2
serial
bus info
hw revision     0x0
driver version  5.10.110
Device topology
- entity 1: stream_cif_mipi_id0 (1 pad, 11 links)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                < - "rockchip-mipi-csi2":1 [ENABLED]
                < - "rockchip-mipi-csi2":2 []
                < - "rockchip-mipi-csi2":3 []
                < - "rockchip-mipi-csi2":4 []
                < - "rockchip-mipi-csi2":5 []
                < - "rockchip-mipi-csi2":6 []
                < - "rockchip-mipi-csi2":7 []
                < - "rockchip-mipi-csi2":8 []
                < - "rockchip-mipi-csi2":9 []
                < - "rockchip-mipi-csi2":10 []
                < - "rockchip-mipi-csi2":11 []
- entity 5: stream_cif_mipi_id1 (1 pad, 11 links)
            device node name /dev/video1
        pad0: Sink
                < - "rockchip-mipi-csi2":1 []
                < - "rockchip-mipi-csi2":2 [ENABLED]
- entity 9: stream_cif_mipi_id2 (1 pad, 11 links)
            device node name /dev/video2
        pad0: Sink
                < - "rockchip-mipi-csi2":3 [ENABLED]
- entity 13: stream_cif_mipi_id3 (1 pad, 11 links)
             device node name /dev/video3
        pad0: Sink
                < - "rockchip-mipi-csi2":4 [ENABLED]
- entity 17: rkcif_scale_ch0 (1 pad, 11 links)
             device node name /dev/video4
        pad0: Sink
                < - "rockchip-mipi-csi2":5 [ENABLED]
- entity 21: rkcif_scale_ch1 (1 pad, 11 links)
             device node name /dev/video5
        pad0: Sink
                < - "rockchip-mipi-csi2":6 [ENABLED]
- entity 25: rkcif_scale_ch2 (1 pad, 11 links)
             device node name /dev/video6
        pad0: Sink
                < - "rockchip-mipi-csi2":7 [ENABLED]
- entity 29: rkcif_scale_ch3 (1 pad, 11 links)
             device node name /dev/video7
        pad0: Sink
                < - "rockchip-mipi-csi2":8 [ENABLED]
- entity 33: rkcif_tools_id0 (1 pad, 11 links)
             device node name /dev/video8
        pad0: Sink
                < - "rockchip-mipi-csi2":9 [ENABLED]
- entity 37: rkcif_tools_id1 (1 pad, 11 links)
             device node name /dev/video9
        pad0: Sink
                < - "rockchip-mipi-csi2":10 [ENABLED]
- entity 41: rkcif_tools_id2 (1 pad, 11 links)
             device node name /dev/video10
        pad0: Sink
                < - "rockchip-mipi-csi2":11 [ENABLED]
- entity 45: rockchip-mipi-csi2 (12 pads, 122 links)
             type V4L2 subdev subtype Unknown flags 0
             device node name /dev/v4l-subdev0
        pad0: Sink
                [fmt:SGBRG10_1X10/3864x2192 field:none
                 crop.bounds:(12,16)/3840x2160
                 crop:(12,16)/3840x2160]
                < - "rockchip-csi2-dphy0":1 [ENABLED]
        pad1: Source
                - > "stream_cif_mipi_id0":0 [ENABLED]
                - > "stream_cif_mipi_id1":0 []
                - > "stream_cif_mipi_id2":0 []
                - > "stream_cif_mipi_id3":0 []
                - > "rkcif_scale_ch0":0 []
                - > "rkcif_scale_ch1":0 []
                - > "rkcif_scale_ch2":0 []
                - > "rkcif_scale_ch3":0 []
                - > "rkcif_tools_id0":0 []
                - > "rkcif_tools_id1":0 []
                - > "rkcif_tools_id2":0 []
        pad2: Source
                - > "stream_cif_mipi_id0":0 []
                - > "stream_cif_mipi_id1":0 [ENABLED]
        pad3: Source
                - > "stream_cif_mipi_id2":0 [ENABLED]
        pad4: Source
                - > "stream_cif_mipi_id3":0 [ENABLED]
        pad5: Source
                - > "rkcif_scale_ch0":0 [ENABLED]
        pad6: Source
                - > "rkcif_scale_ch1":0 [ENABLED]
        pad7: Source
                - > "rkcif_scale_ch2":0 [ENABLED]
        pad8: Source
                - > "rkcif_scale_ch3":0 [ENABLED]
        pad9: Source
                - > "rkcif_tools_id0":0 [ENABLED]
        pad10: Source
                - > "rkcif_tools_id1":0 [ENABLED]
        pad11: Source
                - > "rkcif_tools_id2":0 [ENABLED]
- entity 58: rockchip-csi2-dphy0 (2 pads, 2 links)
             device node name /dev/v4l-subdev1
        pad0: Sink
                [fmt:SGBRG10_1X10/3864x2192@10000/300000 field:none
                 crop.bounds:(12,16)/3840x2160]
                < - "m00_b_imx415 3-001a":0 [ENABLED]
        pad1: Source
                - > "rockchip-mipi-csi2":0 [ENABLED]
- entity 63: m00_b_imx415 3-001a (1 pad, 1 link)
             type V4L2 subdev subtype Sensor flags 0
             device node name /dev/v4l-subdev2
        pad0: Source
                - > "rockchip-csi2-dphy0":0 [ENABLED]
从entity 63信息中可以看到:
该Entity完整的名称是:m00_b_imx415 3-001a
它是一个V4L2 subdev(Sub-Device) Sensor
它对应的节点是 /dev/v4l-subdev2,应用程序(如v4l2-ctl)可以打开它,并进行配置
它仅有一个输出(Source)节点,记为pad0
它的输出格式是 [fmt:SGBRG10_1X10/3864x2192@10000/300000 field:none
crop.bounds:(12,16)/3840x2160],其中SBGGR10是一种mbus-code的简称
它的Source pad0 链接到"rockchip-csi2-dphy0"的pad0,并且当前的状态是 ENABLED。
media-ctl -d /dev/media1 -p
- entity 6: rkisp_mainpath (1 pad, 1 link)
            device node name /dev/video11
        pad0: Sink
                < - "rkisp-isp-subdev":2 [ENABLED]
五、测试
使用
gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=3840,height=2160, framerate=30/1 ! xvimagesink
RK3588
