RK3588-WIF/BT调试之AP6256
一、简介
  • 专栏总目录
  • AP6256是正基科技推出的一款低成本,低功耗的双模模块。是一款SDIO接口单通道802.11ac双频支持BT5.0 蓝牙WiFi二合一模块。
  • Model:AP6256:SDIO WIFI + UART BT
  • Chip:BCM43456
  • WiFi: 2.4G&5G
  • BT:5.0
  • WIFI Throughput:up:196 Mbits/sec down: 187 Mbits/sec
二、DTS配置
2.1 配置SDIO
/* SDIO接口Wi-Fi专用配置:SDIO接口节点 */
&sdio {
	max-frequency = < 150000000 >;  /* sdio接口的最大频率,可调整 */
	supports-sdio;
	bus-width = < 4 >;    /* 4线模式,可调整1线模式 */
	disable-wp;
	cap-sd-highspeed;
	cap-sdio-irq;
	keep-power-in-suspend;
	mmc-pwrseq = < &sdio_pwrseq >;
	non-removable;
	num-slots = < 1 >;
	pinctrl-names = "default";
	pinctrl-0 = < &sdiom0_pins >;
	sd-uhs-sdr104;     /* 支持SDIO3.0 */
	status = "okay";
2.2 WIFI的配置
  • WIFI_REG_ON: Wi-Fi的电源使能PIN脚配置 ( 控制WIFI模块电源的GPIO )
  • WL_REG_ON由sdio_pwrseq节点进行管理控制,不需要在wireless-wlan节点下面重复添加WIFI,poweren_gpio配置;
/* SDIO接口Wi-Fi专用配置: WIFI_REG_ON: Wi-Fi的电源使能PIN脚 */
sdio_pwrseq: sdio-pwrseq {
		compatible = "mmc-pwrseq-simple";
		clocks = < &hym8563 >;
		clock-names = "ext_clock";
		pinctrl-0 = < &wifi_enable_h >;
		reset-gpios = < &gpio0 RK_PC4 GPIO_ACTIVE_LOW >;  /*跟电源使能状态恰好相反:高有效为LOW,低有效则为HIGH。切记:这个配置跟下面的WIFI,poweren_gpio是互斥的,不能同时配置!!!*/
		 /*特别注意:reset-gpios的GPIO_ACTIVE 配置跟poweren_gpio配置的电源使能状态恰好是相反的*/
/* SDIO接口Wi-Fi专用配置:WIFI_REG_ON脚的pinctrl的配置 */
&pinctrl {
		sdio-pwrseq {
		wifi_enable_h: wifi-enable-h {
			rockchip,pins = < 0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none >;  /* 对应上面的WIFI_REG_ON,关掉上下拉,防止不能拉高或拉低 */
  • WIFI节点配置
/* Wi-Fi节点 */
wireless_wlan: wireless-wlan {
		compatible = "wlan-platdata";
		wifi_chip_type = "ap6256";        //模块名称
		pinctrl-0 = < &wifi_host_wake_irq >;
		WIFI,host_wake_irq = < &gpio0 RK_PB2 GPIO_ACTIVE_HIGH >;     //WIFI模块唤醒CPU的
		//WIFI,poweren_gpio = < &gpio0 RK_PC4 GPIO_ACTIVE_HIGH >;    //控制WIFI模块电源的GPIO,配置了sdio_pwrseq就不需要再配置poweren_gpio
		status = "okay";
  • WIFI,host_wake_irq的配置说明:
/* WIFI_WAKE_HOST: Wi-Fi中断通知主控的PIN脚。
* 特别注意:确认下这个Wi-Fi pin脚跟主控的pin的硬件连接关系,直连的话就是GPIO_ACTIVE_HIGH;
* 如果中间加了一个反向管就要改成低电平GPIO_ACTIVE_LOW触发
  • WIFI_WAKE_HOST脚的pinctrl的配置:
&pinctrl {
		wireless-wlan {
		wifi_host_wake_irq: wifi-host-wake-irq {
			rockchip,pins = < 0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down >;
/* 注意一般Wi-Fi的wake host pin都是高电平触发,
* 所以默认这里要配置为下拉; 如果客户的硬件设计
* 是反向的则要改为上拉,总之要初始化为与触发电平
* 相反的状态
2.3 蓝牙的配置
  • 以下UART相关的都要配置为实际使用的UART口的所对应PIN,注意RTS/CTS pin一定要按照SDK设计
    接(具体接法参考7.3章节的UART描述),很多客户反馈的异常都是因为这两个PIN脚没有接导致初始化
    异常,下面假设蓝牙使用UART4:
bt_uart6: wireless_bluetooth: wireless-bluetooth {
		compatible = "bluetooth-platdata";
		clocks = < &hym8563 >;                                     //外部时钟
		uart_rts_gpios = < &gpio1 RK_PA2 GPIO_ACTIVE_LOW >;        //uart的rts脚
		pinctrl-names = "default", "rts_gpio";
		pinctrl-0 = < &uart6m1_rtsn >;
		pinctrl-1 = < &uart6_gpios >;
		BT,reset_gpio    = < &gpio3 RK_PA6 GPIO_ACTIVE_HIGH >;     //蓝牙的复位脚
		BT,wake_host_irq = < &gpio0 RK_PC5 GPIO_ACTIVE_HIGH >;     //蓝牙模块唤醒CPU的GPIO
		status = "okay";
&pinctrl {
		uart6_gpios: uart6-gpios {
			rockchip,pins = < 1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none >;
  • 蓝牙对应的uart6配置
/* 打开对应的UART配置 */
&uart6 {
	/* 这里配置对应主控UART的TX/RX/CTS PIN ,不要配置RTS PIN*/
	pinctrl-0 = < &uart6m1_xfer &uart6m1_ctsn >;
	status = "okay";
三 、内核配置
3.1 WIFI配置:kernel配置defconfig
  • MK文件中定义的Kernel defconfig:
  • kernel的defconfig对应到这个文件: "kernel\\arch\\arm64\\configs\\rockchip_linux_defconfig"
# Kernel defconfig
export RK_KERNEL_DEFCONFIG=rockchip_linux_defconfig
cd kernel
make ARCH=arm64 menuconfig
make savedefconfig
选择:Device Drivers ---> Network device support ---> Wireless LAN ---> Rockchip Wireless LAN support
开发板
Wi-Fi驱动可编译到内核或者ko方式, 切记下面两个配置必须二选一,否则Wi-Fi无法加载!
  • KO 配置:[* ] build wifi ko modules
    CONFIG_WIFI_BUILD_MODULE=y
    # CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP is not set
  • buildin 配置:[* ] Wifi load driver when kernel bootup
    CONFIG_WIFI_LOAD_DRIVER_WHEN_KERNEL_BOOTUP=y
    # CONFIG_WIFI_BUILD_MODULE is not set
  • buildin 只能选择一个型号,realtek 模组和 ap6xxx 模组不能同时选择为y,且realtek的也只能选择其
    中一个;
  • ap6xxx 和 cypress 也是互斥的,只能选择一个且如果选择ap6xxx,cypress的配置自动消失,去掉ap
    配置,cypress自动出现;
  • ko方式则可以选择多个Wi-Fi
3.2 蓝牙配置:kernel配置defconfig
  • 正基和海华的模块使用内核的默认CONFIG_BT_HCIUART 驱动:
    cd kernel
    make savedefconfig
选择: Networking support ---> Bluetooth subsystem support ---> Bluetooth device drivers
开发板
注意:配置完成后要保存到对应的defconfig
四、Wi-Fi/BT的文件及更新及编译说明
4.1 查看板上生成的ko文件和firmware / nvram文件
  • 正基/海华模组以AP6256为例:对应的Wi-Fi/BT的firmware在SDK中的位置:
    external/rkwifibt/firmware/broadcom/AP6256/
    ├── bt
    │ └── BCM4345C5.hcd
    └── wifi
    ├── fw_bcm43456c5_ag.bin
    ├── fw_bcm43456c5_ag_mfg.bin
    └── nvram_ap6256.txt
  • 经过编译规则编译后,对应的文件被拷贝到工程的output目录:(kernel4.19内核由system变更为vendor目录)
    buildroot/output/rockchip_rk3xxxx/target/
    /system(vendor)/lib/modules/bcmdhd.ko #驱动ko(如果是ko编译的话)
    /system(vendor)/etc/firmware/fw_bcm43456c5_ag.bin #驱动firmware文件存放位置
    /system(vendor)/etc/firmware/fw_bcm43456c5_ag_mfg.bin #驱动firmware文件存放位置
    /system(vendor)/etc/firmware/nvram_ap6256.txt #驱动nvram文件存放位置
    /system(vendor)/etc/firmware/BCM4345C5.hcd #蓝牙firmware文件(如果有蓝牙功能)
  • 最终烧录到机器中后,Wi-Fi运行时所需的文件及存放位置:
4.2 编译配置说明
  • mk文件配置路径:3588_linux5.10_v1.0.5/device/rockchip/rk3588/BoardConfig-rk3588-pi5.mk
  • 兼容正基和Realtek
  • RK_WIFIBT_TTY这个参数根据蓝牙对应的串口来配置,此处蓝牙对应的是uart6
    # Define WiFi BT chip
    # Compatible with Realtek and AP6XXX WiFi : RK_WIFIBT_CHIP=ALL_AP
    # Compatible with Realtek and CYWXXX WiFi : RK_WIFIBT_CHIP=ALL_CY
    # Single WiFi configuration: AP6256 or CYW43455: RK_WIFIBT_CHIP=AP6256
    export RK_WIFIBT_CHIP=ALL_AP
    # Define BT ttySX
    export RK_WIFIBT_TTY=ttyS6
  审核编辑:汤梓红
