MediaPipe + OpenCV五分钟搞定手势识别
MediaPipe介绍
这个是真的,首先需要从Google在2020年发布的mediapipe开发包说起,这个开发包集成了人脸、眼睛、虹膜、手势、姿态等各种landmark检测与跟踪算法。
https://google.github.io/mediapipe/
请看下图比较详细
跟踪算法
是个不折不扣的现实增强的宝藏工具包,特别实用!支持的平台跟语言也非常的丰富,图示如下:
跟踪算法
只说一遍,感觉要逆天了,依赖库只有一个就是opencv,python版本的安装特别简单,直接运行下面的命令行:
pip install mediapipe
手势landmark检测
直接运行官方提供的Python演示程序,需要稍微修改一下,因为版本更新了,演示程序有点问题,改完之后执行运行视频测试,完美get到手势landmark关键点:
跟踪算法
手势landmark的关键点编号与解释如下:
跟踪算法
修改后的代码如下:
import cv2
import mediapipe as mp
mp_drawing = mp.solutions.drawing_utils
mp_hands = mp.solutions.hands
# For webcam input:
cap = cv2.VideoCapture(0)
with mp_hands.Hands(
    min_detection_confidence=0.5,
    min_tracking_confidence=0.5as hands:
  while cap.isOpened():
    success, image = cap.read()
    if not success:
      print("Ignoring empty camera frame.")
      # If loading a video, use 'break' instead of 'continue'.
      continue
    # To improve performance, optionally mark the image as not writeable to
    # pass by reference.
    image.flags.writeable = False
    image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
    results = hands.process(image)
    # Draw the hand annotations on the image.
    image.flags.writeable = True
    image = cv2.cvtColor(image, cv2.COLOR_RGB2BGR)
    if results.multi_hand_landmarks:
      for hand_landmarks in results.multi_hand_landmarks:
        mp_drawing.draw_landmarks(
            image,
            hand_landmarks,
            mp_hands.HAND_CONNECTIONS)
        cv2.imwrite('D:/result.png', cv2.flip(image, 1))
    # Flip the image horizontally for a selfie-view display.
    cv2.imshow('MediaPipe Hands', cv2.flip(image, 1))
    if cv2.waitKey(5) & 0xFF == 27:
      break
cap.release()
手势识别
基于最简单的图象分类,收集了几百张图象,做了一个简单的迁移学习,实现了三种手势分类,运行请看视频:
