光模块因为有数字诊断监控功能(DDM, Digital Diagnostic monitoring)这位医生进行实时的性能监测,能够精确的找到故障位置,以及通过兼容性验证直观的反映不兼容的情况,所以其稳定性和可靠性得以提高。那么数字诊断监控功能又是如何修炼出这么强大的功能呢?通过内校准和外校准!
内校准:采用内部校准,A / D的值被校准为标准值,A / D转换值经过物理量变换和相应缩放,最后输出的数字标定值符合协议中规定的数值范围。
A2h Bit Name Description 96 All Temperature MSB Internally measured module temperature 97 All Temperature LSB 98 All Vcc MSB Internally measured supply voltage in transceiver 99 All Vcc LSB 100 All TX Bias MSB Internally measured TX Bias Currnet 101 All TX Bias LSB 102 All TX Power MSB Measured TX output power 103 All TX Power LSB
A2h Bit Name Description 104 All RX Power MSB Measured RX input power 105 All RX Power LSB 106 All Optional Laser Tem/Wavelength MSB Measured laser temperature or wavelength 107 All Optional Laser Tem/Wavelength LSB 108 All Optional TEC current MSB Measured TEC current(positive is cooling) 109 All Optional TEC current LSB
外校准:采用外部校准时,存储的是未经处理的A / D转换值,监测软件通过读取存储单元A2H中38H~5FH地址内的校准常数,再通过外部校准公式把A / D值换算成实际值
