可扩充无风扇嵌入式边缘计算机BPX-9422R-R0AE支持4个扩展插槽-40°C to 75°C宽温6th/7th高性能CPU
BPX-9422R-R0AE                   可扩充无风扇嵌入式系统
嵌入式
1、配置:Intel酷睿i3-6300(2核4线程3.80GHz),可选其他6th/7th 代LGA 1151 Intel Xeon/Core i7/i5/i3 系列TDP80W以内处理器;
2、Intel C236芯片组,嵌入式无风扇EN50155, EN50121-3-2工控机;
3、配置:8GB DDR4 2400工控内存,最大尺寸32GB;
4、外置DVI-I、DVI-D、DisplayPort显示接口,支持3个独立高清显示器;
5、配置:128GB mSATA固态硬盘,可选其他容量的SSD/HDD;
6、宽温工作温度-40°C to 75°C;
7、6V to 36V宽幅工作电压,支持80V过压保护,
8、2个RJ45 Intel芯千兆网口,支持iAMT 11.0 ;
9、3个SIM卡槽,支持3G/4G/LTE/WiFi/GPRS/UMTS    ;
10、4个2.5" SSD/HDD支持软RAID 0, 1, 5, 10   ;
11、外置2个SIM卡槽,4个2.5寸热插拔盒,1个CFast卡槽,6个USB,4个DB9 RS-232/422/485通讯串口;
12、1个PCIe x16,1个PCIe x4,2个PCI扩展插槽,最大支持250W功耗的PCI/PCIe扩展卡;
13、7个USB(1个内置USB2.0),4个COM,3个Mini PCIe,32pin DIO;
14、尺寸:172mm x 250mm x 210mm (6.8" x 9.8" x 8.3"),重量:5kg。
嵌入式
System
ProcessorQuad  Core Intel Xeon/Core i7/i5/i3 Processor (Kaby  Lake-S/Skylake-S)
ChipsetIntel  C236
BIOSAMI
SIOIT8786E
Memory2  DDR4 2133MHz SO-DIMM, up to 32GB (ECC/Non-ECC)
I/O  Interface
Serial 4  COM RS-232/422/485
USB
-  7 USB 3.0 (6 External, 1 Internal)
-  2 USB 2.0 (Internal)
Isolated  DIO32 Isolated  DIO : 16 DI, 16 DO
LEDPower,  HDD
SIM  Card 3 SIM  Card Socket (2 External, 1 Internal)
Expansion
Mini  PCIe
3  Mini PCIe Socket :
- 2  Full-size Mini PCIe for PCIe/USB/External SIM Card
- 1  Full-size Mini PCIe for PCIe/USB/Internal SIM Card/mSATA
PCIe- 1  PCIe x16 Slot
 - 1 PCIe x4 Slot
PCI2  PCI Slot
Graphics
Graphics  ProcessorIntel  HD Graphics 530
Interface
-  DVI-I : Up to 1920 x 1200 @ 60Hz
-  DVI-D : Up to 1920 x 1200 @ 60Hz
-  DisplayPort : Up to 4096 x 2304 @ 60Hz
Storage
SATA4 SATA  III (6Gbps) support S/W RAID 0, 1, 5, 10
mSATA1 SATA  III (Mini PCIe Type, 6Gbps)
Storage  Device
- 1  CFast Socket (Internal)
-  4 2.5" SSD/HDD Tray
Audio
Audio  CodecRealtek  ALC892, 5.1 Channel HD Audio
Audio  Interface1  Mic-in, 1 Line-out
Ethernet
LAN  1Intel  I219LM Gigabit LAN supports iAMT 11.0
LAN  2Intel  I210 Gigabit LAN
Power
Power  Input6V  to 36V, DC-in
Power  Interface3-pin  Terminal Block : V+, V-, Frame Ground
Ignition  Control16  Mode (Internal)
Remote  Switch3-pin  Terminal Block
Surge  ProtectionUp  to 80V/1ms Transient Power
Others
TPMOptional  Infineon SLB9665 supports TPM 2.0, LPC Interface
Watchdog  TimerReset  : 1 to 255 sec./min. per step
Smart  ManagementWake  on LAN, PXE supported
HW  MonitorMonitoring  temperature, voltages. Auto throttling control when CPU overheats.
Software  Support
OSWindows  10, Windows 8.1, Windows 7, Linux
Mechanical
Dimension  (W x L x H)172mm  x 250mm x 210mm (6.8" x 9.8" x 8.3")
Weight
BPX-9400R  系列 :  5 kg (11 lb)
BPX-9400  系列 :  3.8 kg (8.4 lb)
MountingWallmount  by mounting bracket
Environment
Operating  Temperature
35W  TDP CPU :
- Core i7, i5, i3 : -40°C to 75°C (-40°F to 167°F)
- Xeon  E3-1268L v5 : -40°C to 70°C (-40°F  to 158°F)
65W  TDP CPU :
Core i7, i5, i3 : -40°C to 55°C (-40°F to 131°F)
80W  TDP CPU :
Xeon  E3-1275 v6, E3-1275 v5, E3-1225 v5 : -40°C to
45°C (-40°F to 113°F)
Storage  Temperature-40°C to 85°C (-40°F  to 185°F)
Humidity5%  to 95% Humidity, non-condensing
Relative  Humidity95%  at 70°C
Shock
-  IEC 60068-2-27
-  SSD : 50G @ wallmount, Half-sine, 11ms
Vibration
-  IEC 60068-2-64
-  SSD : 5Grms, 5Hz to 500Hz, 3 Axis
EMCCE,  FCC, EN50155, EN50121-3-2
嵌入式
