可扩充无风扇嵌入式边缘计算机BPX-1000-R0AE支持5个扩展插槽-40°C to 75°C宽温9th/8th高性能CPU
BPX-1000-R0AE                              边缘工业无风扇计算机
1、配置:Intel酷睿i3-8300(4核4线程3.7GHz),可选其他8th/9th系列8核Intel Xeon/Core i7/i5/i3 TDP80W以内高性能处理器(如:E-2278GE/E-2176G/E-2226GE/i7-9700/i7-8700/等);
2、配置:8GB DDR4 2400工控内存,最大支持64GB;
3、配置:128GB mSATA固态硬盘,可选其他容量SSD/机械硬盘;
4、Intel C246芯片组;
5、单电9V to 55V宽压电源输入;
6、4个扩展插槽:2个PCIe x8,1个PCIe x4,1个PCIe x1,
最大支持2个全高显卡;
7、最大1500W功耗扩展卡,单个最大功耗支持 NVIDIA Tesla/
Quadro/GeForce or AMD Radeon等750W以内的显卡;
8、4个Intel芯千兆网口,支持iAMT 12.0;
9、4个外置USB 3.1接口,最大10Gbps数据传输;
10、支持WiFi/4G/3G/LTE/GPRS/UMTS无线传输;
11、2个SATA III接口,4个COM(RS-232/422/485),16pin DIO;
12、可选5G无线网络,10G PoE+网口。
系统信息
处理器支持8th/9th系列8核Intel  Xeon/Core i7/i5/i3高性能处理器
芯片组Intel C246
BIOSAMI
SIOIT8786E
内存2根DDR4 2666MHz SO-DIMM插槽,最大支持64GB内存
外置I/O
串口4  COM RS-232/422/485 (ESD 8KV)
USB4 USB  3.1
数字IO16pin  DIO : 8 DI, 8 DO
指示灯电源指示灯,硬盘工作灯
SIM卡槽1个外置SIM卡槽
扩展插槽
迷你PCIe插槽
-1个全长插槽,支持PCIe/USB/External SIM Card
-1个全长插槽,支持PCIe/USB/mSATA
PCIe
4  PCIe Slot:
-2  PCIe x16 slot with PCIe x8 signal
-1  PCIe x16 slot with PCIe x4 signal
-1  PCIe x16 slot with PCIe x1 signal
SUMIT  A, B2  SUMIT Slot (Optinal)
显示
显卡
-  Intel UHD graphics 630
Independent  Graphics 1:By request
Independent  Graphics 2:By request
显示接口
Multiple independent  displays :
- 1  DVI-D : Up to 1920 x 1200 @60Hz
-  2 DisplayPort : Up to 4096 x 2304 @60Hz
-  By requested Graphics Card
存储
SATA2  SATA III (6Gbps) support S/W RAID 0, 1
mSATA1  SATA III (Mini PCIe type, 6Gbps)
Storage  Device2 Internal 2.5"  SSD/HDD Bracket
Audio
Audio  CodecRealtek  ALC892, 5.1 Channel HD Audio
Audio  Interface1  Mic-in, 1 Line-out
Ethernet
LAN  1Intel  I219LM GigE LAN supports iAMT 12.0
LAN  2Intel  I210 GigE LAN
LAN  3Intel  I210 GigE LAN
LAN  4Intel  I210 GigE LAN
Power
Power  Input9V  to 55V DC-in
Power  Interface4-pin  Terminal Block
Remote  Switch2-pin  Terminal Block
Surge  ProtectionUp  to 80V/1ms Transient Power
Others
TPMInfineon  SLB9665, LPC interface
Watchdog  TimerReset  : 1 to 255 sec./min. per step
Smart  ManagementWake  on LAN, PXE supported
HW  MonitorMonitoring  temperature, voltages. Auto throttling control when CPU overheats.
Software  Support
OSWindows  10, Linux
Mechanical
Dimension  (W x L x H)242.7mm  x 208.9mm x 369.2mm (9.56" x 8.22" x 14.54")
Weight                     9.0  kg (19.8 lb)
MountingWallmount  by mounting bracket
Environment
Operating  Temperature-25°C to 60°C (-6°F to  140°F)
Storage  Temperature-40°C to 85°C (-40°F  to 185°F)
Humidity5%  to 95% Humidity, non-condensing
Relative  Humidity95%  @ 60°C
Shock/Vibration
-  IEC 61373 : 2010
-  Railway Applications : Rolling Stock Equipment, Shock and Vibration Test
EMCCE,  FCC, EN50155, EN50121-3-2
  • 相关推荐
  • 热点推荐
