AIMB-786
AIMB-786
LGA1151第8代Intel Core i7/i5/i3/ Pentium/Celeron母板 支持独立三显, DDR4, USB 3.1, SATA 3.0
Intel第8代Core i7/i5/i3/Pentium/Celeron处理器, Q370芯片组
4个DIMM插槽,最高支持64 GB DDR4 2400/2666
支持三显示VGA/DVI-D/DP和双GbE LAN
支持SATA RAID 0, 1, 5, 10, USB 3.1
支持Intel vPro, AMT & TPM技术
注1: TPM模块需要使用Intel vPro和TPM技术
注2:Intel第八代处理器,仅支持Windows 10(64-bit)
研华AIMB-786G2同款产品枭杰科技ATX嵌入式工业级ATX主板IAMB-Q37JW-00AE支持8th/9th代IntelCore i7/ i5 /i3, PentiumCeleron LGA1151 Socket智能处理器
1. 英特尔 Coffee Lake 处理器 (最高 95W TDP)
2. 4 * DDR4 2666MHz U-DIMM 最高支持 128GB (ECC仅限C246)
3. 2 * 10/100/1000 Base-TX 网口
4. 1 * HDMI, 1 * DP, 1 * VGA, 1 * DVI-D
5. 10 * COM (COM1/2 支持 RS232/422/485), 4 * USB3.1 Gen.2, 4 * USB3.1 Gen.1 & 4 * USB2.0
6. 2 * PCIe x16 槽, 1 * PCIe x4 槽, 1 * PCIe x1 槽, 2 * PCI 槽, 1 * M.2 (PCIex4 SATA 接口, M-key支持NVMe, 2242/2260/2280/22110), 1* M.2 (2230, E-key)
7. 5 * SATA III (6Gb/s) 支持 RAID 0, 1, 5, 10
8. 支持 TPM1.2/2.0 (板载可选)
Model
Dimensions– IAMB-Q37JW
Dimensions– IAMB-Q37JW-00AE
 Form Factor
Dimensions– ATX (305 * 244mm)
 Processor System
CPU Generation– Intel LGA1151 Gen 8 Coffee Lake Processor (Max. 95W TDP)
CPU SKU– Core i7/i5/i3, Pentium, Celeron
Core Number– (by CPU)
Max Speed– (by CPU)
L2 Cache– (by CPU)
Chipset– Q370
BIOS– AMI Flash ROM
 Expansion Slot
PCI– 2
PCIe– 1 * PCIe x1, 1 * PCIe x4, 2 * PCIe x16. Support NVMe
* Note: there are two configurations if plug one PCIe x16 card in one slot, the other slot is disable; or plug one PCIe x8 card in one slot, the other slot is able to plug one PCIe x8/x4/x1 card
M.2 (E-key)– 1 (E-key, 2230)
M.2 (M-key)– 1 (PCIex4 with SATA interface, M-key support NVMe, 2242/2260/2280/22110)
SIM Card Holder– 0
 Memory
Technology– DDR4 2666MHz Dual CH SDRAM non-ECC
Max.– 128GB
Socket– 4 * U-DIMM
 Graphics
Controller– Intel HD Graphics
VRAM– Shared Memory
VGA– 1 (Max. Resolution: 1920×1200@60Hz)
HDMI 1.4– 1 (Max. Resolution: 4096×2160@30Hz)
DVI-D– 1 (Max. Resolution: 1920×1200@60Hz)
DisplayPort– 1 (Max. Resolution: 4096×2304@60Hz)
Multi Display– Triple Displays
 Ethernet
Ethernet– 10/100/1000 Mbps
Controller– 2 * Intel GbE
(1 * i219LM, 1 * i211AT)
Connector– 2 * RJ45
 Audio
CODEC– HD Audio : REALTEK ALC662
Channel– 6 Channel
 SATA
Max Data Transfer Rate– 5 * SATAIII support RAID 0, 1, 5, 10
 Rear I/O
VGA– 1
DVI-D– 1
HDMI– 1
DisplayPort– 1
Ethernet– 2
USB– 4 * USB 3.1 (Gen. 2) & 2 * USB3.1 (Gen. 1)
Audio– 3 (Line-In, Line-Out, MIC)
Serial– 1 (COM1 support RS232/422/485)
 Internal Connector
USB– 2 * USB3.1 (Gen. 1), 4 * USB 2.0
PS/2– 1
Serial– 9 (COM2 support RS232/422/485)
SATA– 5 * SATAIII
M.2 (M-key)– 1 (PCIex4 with SATA interface, M-key NVMe, 2242/2260/2280/22110)
GPIO– 1 (8 bit)
Chassis intrusion– 1
Audio Header– 1
SMBUS– 1
AT mode– 1
TPM– 1 (on board option)
 Watchdog Timer
Output– From Super I/O to drag RESETCON#
Interval– 256 segments (10sec ~ 255min)
 Power Requirements
Input PWR– ATX PWR (8+24 pin)
Power OnAT/ATX Supported
– AT : Directly PWR on as Power input ready
– ATX : Press Button to PWR on after Power input ready
 Certifications
Certifications– CE, FCC, LVD, RoHS, REACH
 Environment
Temperature– Operating: 0°C ~ 60°C
– Storage: -20°C ~ 85°C
现货销售研华Mini-ITX工控主板AIMB-285G2
Intel Core i7/i5/i3 LGA 1151 Mini-ITX 带 DP/HDMI/VGA, 2 COM, 4 USB3.0, Dual LAN, PCIe x 4,mini PCIE, DDR4, DC 输入
支持TPM 1.2 / 2.0 (可选)
支持12V DC输入
支持双屏显示:DP/HDMI/VGA/LVDS(可选)
支持 PCIe x 4 (Gen 3), 1个F/S miniPCIe 1个H/S miniPCIe, 4个USB 3.0和3个SATA III
两个 260-pin SO-DIMM最高可达16GB DDR4 2133 MHz SDRAM
支持 Intel 6th Gen Core i 处理器(LGA1151) 带Intel H110 芯片组
  • 相关推荐
  • 热点推荐
